Send the selected object to 0,0,0
mCasualmCasual Posts: 4,607
edited February 2023 in Freebies
attached below but also available as a zip package here:
https://sites.google.com/site/mcasualsdazscripts10/mcjgoto000
Say you create a sphere with it's origin at the center of the sphere
BUT the created sphere stands on the ground plane.
In the parameters tab you can see that its Local Coordinates are 0,0,0,
so you now have to compute the negative Y-Offset to bring its center to 0,0,0.
ex: the sphere diameter was 100 meters so you have to move the sphere (manually !!!) down 5000 centimeters ( not 500, not 50000 ).
But since you installed mcjGoTo000.dsa,
instead you select the sphere
and run mcjGoTo000
and bam it's centered at 0,0,0.
I even added an Undo, so thoughtful, so thoughtful.
//mcjVoyageToTheCenterOfTheWorld by mCasualJacques
appName = "mcjGoto[0,0,0]";
node = Scene.getPrimarySelection();
if( node )
beginUndo();
node.setWSPos( DzVec3( 0, 0, 0 ) );
acceptUndo( appName );
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    the icon
    364 x 364 - 23K
  • Very thoughtful and useful script. Thank you!
  • UnseenUnseen Posts: 824
    I agree, very useful script! Thank you so much!!!
  • Not that I am not being greedy...
    But how hard would it be to create a script where you would...
    1) Click a node in the Scene tab
    2) Click mCasual's "come-to-papa" script
    3) Then Click something in the library OR another node in the scene tab and come-to-papa would place that item/character/prop at the same location
    That way if I wanted to put a bunch of stuff on a table, I could just place the table, and then dump a bunch of stuff on it.  Of course, I would have to arrange the stuff that was dumped, but getting it near the table would be 93.7% of the battle.
    Feasible?
    There's mcjParent (which i use very often) you select 2 nodes and you can send one of the 2 to the other it can also copy the rotations optionally and parent one to the other also optionally. It can do it for the current frame or all the playrange
    Feasible?
  • manekiNekomanekiNeko Posts: 1,456
    excellent complement of the great come-here script, very appreciated, thanks a lot ^^
    edited March 2023
     I quickly wrote mcjSelectedGotoLastSelected a minute ago
    I'll post it in its own forum thread, in case it evolves ( a.k.a. gets complicated )
    so you select all your loaded props copies or instances, the last selected node position is the target position
    Feasible?
    1080 x 1640 - 855K
    800 x 500 - 279K
  • pjwhoopie4801218pjwhoopie4801218 Posts: 795
    edited March 2023
    Ahh shoot!  I think mcjCome-to-Papa would have been a great name!
    Regardless, Thank-you!
    Post edited by pjwhoopie4801218 on
  • LorraineLorraine Posts: 1,088
    Thank you!
    edited March 2023
    or mcjComeToJesus would've been a good click-bait name
    vaguely related render including the word 'come'
    1440 x 1176 - 2M
