Daz Studio Pro BETA - version 4.22.0.15! (*UPDATED*)
145791030
  • Daz3d 4.21.1.29 figure and geograft FBX file crashed on 3dcoat.
    Blender with "better FBX importer" load the figure without the mesh.
  • Saxa -- SDSaxa -- SD Posts: 882
    edited January 2023
    Hand Pose - likley alias - how to clear keyframe - delete keyframe not possible cos alias
    in further reply to question on previous page
    see images below
    1286 x 928 - 149K
    1394 x 995 - 176K
    Post edited by Saxa -- SD on
  • marblemarble Posts: 7,500
    edited January 2023
    see images below
    Actually, I wasn't using a pose from my library, I was posing using the hand pose controls. Here's what I mean (see screenshot):
    1152 x 1022 - 166K
    Post edited by marble on
    I don't know why but when I just tried with the scene in the screenshot (just a G8F development figure) I used the pose controls to grasp the hand and hit the Add Keyframe button on the timeleine. This time I could delete the selected keys. So I have no idea as to what conditions are needed for this to work or not.
    Another question I have is how to clear the movement or posing in frames between keyframes? There are some things which don't create a keyframe when posed or moved. This was the case for the hand grasp just described - I had to manually add the keyframe using the +key button.
    edited January 2023
    Another observation (see attached screenshots).
    Again using the pose controls to grasp the hand at frame 5 on the timeline, I checked with the old GraphMate add-on that I have. Here there is clearly a keyframe marker at frame 5 which can be moved using GraphMate.
    I checked using the DAZ timeline Graph Editor and I see nothing at all.
    521 x 822 - 53K
    865 x 847 - 87K
  • marble said:
    johndoe_36eb90b0 said:
    You should not render icons to 800x800 -- for asset.duf you should render asset.png at the icon size (91x91), and asset.tip.png at the size you want (say 800x800). That way icon doesn't have to be resized to be displayed in the user interface, and when you mouse over the icon you get shown larger image as a tooltip.
    I don't understand the point of the 91x91 image. Why not just render out the larger image instead of creating an extra .tip.png? I always save my icons at larger resolutions precisely because I want something my old eyes can see when I hover over them with the mouse.
    When you hover over the asset.duf that's when 800x800px asset.tip.png is loaded and shown in its original size. Until you hover, only the 91x91px asset.png is shown.
    Basically by using 800x800px image as an icon you are wasting CPU and RAM resources because Daz Studio has first to resize each 800x800px to 91x91px in order to show the icons.
    If you are OK with that, just ignore what I said -- I was just trying to explain why there is a separate .tip.png image and why it should be used especially if you are selling assets.
    [MODERATOR REQUEST]
    Mods, please could you consider moving the above timeline-related posts to a new thread I have just started so as not to derail this Beta thread. I feel this is a subject that needs a separate focus. Thanks.
  • marble said:
    [MODERATOR REQUEST]
    It may have a quick reply - which properties are set to show in the Timeline pane?
    edited January 2023
    Richard Haseltine said:
    marble said:
    [MODERATOR REQUEST]
    I am not sure what propertieds you mean but I think that might be TRSHA (without the O). By the way, there are already several posts in the new thread. It might be worth adding that other thread asking about deleting keyframes to that too?
  • With the latest Daz studio and latest nv studio drivers, I can't render OOT hairs.
    If I switch to Iray Preview, it never finishes switching to Iray. I had to restart the studio in order to stabilize it and the following is logged (always) :
    2023-01-23 14:56:56.791 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.4   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Kernel [4] (ShadowEvalFS      ) failed after 0.022s
    2023-01-23 14:56:56.792 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.4   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): an illegal memory access was encountered (while launching CUDA renderer in <internal>:908)
    2023-01-23 14:56:56.792 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.4   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Failed to launch renderer
    2023-01-23 14:56:56.792 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Device failed while rendering
    2023-01-23 14:56:56.792 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER ::   1.5   IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 3090) is no longer available for rendering.
    2023-01-23 14:56:56.793 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): [Guidance sync] Failed master device (remaining 1, done 0).
    2023-01-23 14:56:56.793 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): an illegal memory access was encountered (while de-allocating memory)
    2023-01-23 14:56:57.568 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER ::   1.2   IRAY   rend warn : All available GPUs failed.
    2023-01-23 14:56:57.568 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.2   IRAY   rend error: Fallback to CPU not allowed.
    2023-01-23 14:56:57.569 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER ::   1.2   IRAY   rend warn : Re-rendering iteration because of device failure
    2023-01-23 14:56:57.572 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: All workers failed: aborting render
    2023-01-23 14:56:57.572 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): an illegal memory access was encountered (while de-allocating memory)
    2023-01-23 14:56:57.573 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): an illegal memory access was encountered (while de-allocating memory)
    2023-01-23 14:56:57.574 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): an illegal memory access was encountered (while de-allocating memory)
    2023-01-23 14:56:57.575 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): an illegal memory access was encountered (while de-allocating memory)
    2023-01-23 14:57:26.815 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - OPTX:RENDER ::   1.14  OPTX   rend error: Error synching on OptixPipeline event (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
    2023-01-23 14:57:26.815 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - OPTX:RENDER ::   1.14  OPTX   rend error: Error destroying OptixPipeline event (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
    2023-01-23 14:57:26.829 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.14  IRAY   rend error: optixPipelineDestroy(pop_ptr(m_pipeline)) failed: CUDA error
    2023-01-23 14:57:26.830 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - OPTX:RENDER ::   1.14  OPTX   rend error: Error synching on OptixPipeline event (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
    2023-01-23 14:57:26.830 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - OPTX:RENDER ::   1.14  OPTX   rend error: Error destroying OptixPipeline event (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
    ... (last optx render is repeated lots of times)
    2023-01-23 14:57:26.921 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2023-01-23 14:57:26.921 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): 0 iterations, 4.885s init, 0.919s render
    2023-01-23 14:57:26.921 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): an illegal memory access was encountered (while de-allocating memory)
    (last repeated lots of times)
    Then log finishes.
    Then log finishes.
    There is an issue with some OOT hairs. Select the hair, switch to the surfaces tab, make sure all the surfaces are selected. Scroll down to the Transmitted Color channel, and remove the map(s) for that channel.
    It doesn't seem to affect the hairs for Genesis 9, or the ones named in the year format.
    Thank you very much!
     same here. crashes CC4 and loads with no mesh in blender, even if i used the offical DAZ2Blender exporter.
    the FBX exporter is completely broken in this latest beta build
  • Looks like deforce is still broken. Tried adding the deforce modifier on a surface and it did not work.
    nVidia driver version? dForce is working with adequate drivers, including the nearly latest crop.
    Can the file be imported back into DS? If it won't make a round trip that may well be a bug, and should be reported (ideally using the simplest possible steps to reproduce). The FBX exporter writes files that Maya can open, so if another application can't it merely shows theer is an incompatibility but doesn't prove that there is a fault in DS - unfortuantely FBX seems to be a problematic format all round, and trying to figure out incompatibilities can be a pain.
  • crosswindcrosswind Posts: 9,690
    edited January 2023
    Does not work for me... For instance, I installed the update of Classic Bob Hair that OOT just released for latest iray version. There's no problem in 4.21.0.5 but still cannot preview or render in 4.21.1.29. I could only convert OOT Hairblending shader to Iray Uber, it finally worked but I had to tweak a lot of parameters... However for Mega Updo 2, with the same Hairblending shader, it works fine in both DAZ versions...  It's really weird~
    Post edited by crosswind on
  • barbultbarbult Posts: 26,439
    Classic Bob Hair was updated January 24, 2023, and the readme says the shader was fixed to work with the latest Iray, but it is NOT fixed. There is still an image loaded in the Transmitted Color channel.
    637 x 337 - 51K
    edited January 2023
    I just tried a few other OOT hairs that were updated. Martha's Everyday Bob, Rose Hair, and Charlene Hair also still crash DS 4.21.1.29. Their readme files claim the shader was updated to work with updated Iray. But they still load an image in the Transmitted Color channel and crash DS, so they are not really fixed. I have other OOT hairs that were updated, but I am tired testing, since the results have been so poor. However, 3-in-1 Ponytail Hair looks like it was really fixed (or maybe never broken, I don't know).
    I guess I'll submit a ticket, but since the tech support ticket I submitted on December 29 hasn't even had a human response, I am not hopeful.
    Edit: Ticket submitted:
    Request #429861 Recent updates to OOT hair have not fixed the Daz Studio crash problem
    636 x 326 - 50K
    637 x 328 - 50K
    632 x 379 - 52K
    Post edited by barbult on
    Interesting.
    I've just updated various OOT hairs, e.g. Marthas Everyday Bob, Classic Bob, no maps in the Transmitted Color channel and they all rendered.
    471 x 360 - 27K
    Interesting.
    Your attached image shows the Cap. The Cap never had a transmitted color image. What about all the other surfaces?
    Oops.
    The other surfaces don't have a Transmitted Color channel.
    471 x 369 - 26K
    Oops.
    They do for me, as shown above. This is what happens when I try to render.
    1279 x 810 - 218K
  • How are you installing? I just tried a couple installed through Connect and have yet to see a transmitted colour mapped.
  • OK, I do haev Rose hair and I do see maps on its Transmiited Colour, both versions of the hair. Tried a couple of materials presets without changing that.
    I use DIM.
  • cain-xcain-x Posts: 210
    Is the play/pause timeline shortcut (default to spacebar) fixed in BETA?
    NorthOf45 gave me the clue I needed to solve my OOT hair problem. Daz Connect was the source of my problem. Although I don't use it anymore, there is still some old junk there. There was one old OOT hair product still installed there (not one of the ones I tested today). Once I uninstalled and deleted that product and reinstalled it with DIM, everything was fine. Oh, I also cleared the DSON cache for good measure.
    edited January 2023
    That's it!  I disabled DAZ Connect years ago, and clearing cache did not work. The reason on my side is that I have 2 DAZ libraries, those 2 hairblending .dsf files in 'data\outoftouch\OOT Hairblending 2' have not been updated in the old library, I replaced them with the latest versions, all problems have gone. Thanks for the instruction!
  • Richard HaseltineRichard Haseltine Posts: 109,088
    edited January 2023
    If you use Connect, have legacy Connect files with a DIM workflow, or have multiple content directories so that you get an unupdated copy of the hair blending file, find a good copy of the file* and copy it, then execute this script in DS and it should open a file browser to the copy that DS will actually use - paste the updated version over it and the issue should be resolved 9obviously my testing was just on my own system).
    // Find the active copy of the Hair Blending file
    // get the content manager
    var oCntMgr = App.getContentMgr();
    // get the locations for the file in question
    var aLocations = oCntMgr.getAbsolutePaths( "/data/outoftouch/OOT Hairblending 2/OOT Hairblending 2 Hair/OOT Hairblending Hair.dsf" , false );
    // assuming we have a hit
    if (aLocations.length > 0 ) {
    // Get a file info object for the first entry
    var oPrefFile = new DzFileInfo ( aLocations[ 0 ] );
    // now tell the OS to open a folder to show that location,
    // so we ignore the filename and just take the path from the file info
    App.showURL( "file:/" + oPrefFile.path() );
    * You can get the updated files from the /data/outoftouch/OOT Hairblending 2/OOT Hairblending 2 Hair/ in your main directory if you mainly use DIM, from an updated zip, or you can right-click on one of the updated OOT hair products in Smart Content>Browse to Product Folder and then find the file in there if using Connect.
