• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Problems with shading (Fine in Blender, but not in Daz)
omen.krisomen.kris Posts: 13
January 2023 edited January 2023 in Blender Discussion
I have a problem with normal shading in Daz. In Blender everything looks smooth and fine, but imported to DAZ it does not anymore. See screenshots. It's the very same mesh. I tried wried fbx and dae import.
Content creators out there... Any ideas on this? Thank you in advice
Post edited by omen.kris on January 2023
  • Richard HaseltineRichard Haseltine Posts: 109,018
    January 2023
    What does the topology look like (post a wireframe or hidden wire version)?
  • omen.krisomen.kris Posts: 13
    January 2023
    Here's image of wireframe. Mesh is cleaned. No dublicated verts
  • felisfelis Posts: 6,046
    January 2023
    I would keep it as quads, and avoid tris going in different directions.
    And for the bumps I would have a more loops to define them.
    January 2023
    Yes, I think it's the triangles that are the main cause of the shading if you compare the wireframe with the smoothed version, and adding an extra loop above and below each ridge might also help to define the shape.
    January 2023
    Thanks, I will try with the suggested topology and report back. :)
  • PadonePadone Posts: 4,055
    You may also try not to export/import normals if you have the option, so to force daz studio to rebuild them. Unless you use custom normals for your model that would be bad anyway for export purposes.
    Post edited by Padone on January 2023
    February 2023
    Well, I tried all kind of things and there is no solution to this issue. I have other meshes that also shade like s**t. There is nothing I can do about it. DAZ is messing those up. I can not even see broken normals in any other software. I don't know how others make assets for DAZ. There must be a secret noone is telling :( Otherwise there would not be good looking objects. When DAZ is calculating them on iit's own uncontrolable, how must the file be in blender to not get messed by DAZ?
    well, there is no option in Blender to do that. Besides how should this help, when the problem clearly is DAZ messing up objects that are shwon correct everywhere else
    February 2023
    @omen.kris If you can share the file I can try to import it in daz studio and see if can be fixed.
  • RL_MediaRL_Media Posts: 339
    February 2023 edited February 2023
    One thing to note. Dont look at meshes in DS until you add a iray material, then play around with the angle slider. I find the sweet spots are usually somewhere around 30 or 60 for some reason
    Post edited by RL_Media on February 2023
  • novoluz1novoluz1 Posts: 0
    June 2024
    thank u SOOO much for this tip on the angle slider!!! i was also struggling with some stupid shading problem from a blender mesh i imported into daz. i thought it was something i did wrong, but nope, it was just good ol' daz throwing me a Very unnecessary curveball! *smh* thx again, u rock!!! yes
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
