No one asked me - Diomede screenshots on whatever - Warning AI Discussion OK
1394042444550
  • use xNormal to add back the details
  • DiomedeDiomede Posts: 15,398
    Displacement Brush in General
    - click the displacement brush on top menu and model goes white
    - the brush tool will appear on the model as a blue circle within a circle, for brush size and brush hardness
    - control brush size and hardness with settings in right hand side
    - click and drag to pull model out toward camera, hold shift key to push model in away from camera
    - the default settings are very powerful relative to a Genesis 9 face
    - can Edit UNDO a displacement brush stroke
    - reduce strength of brush on right side menu.  Here I reduce to 3.  Can also change brush size.
    1723 x 940 - 153K
    1646 x 1002 - 152K
    1747 x 979 - 154K
    1778 x 969 - 155K
    How do you do that?
    edited November 2022
    Some settings
    - hold shift to displace inward.  See cheek
    - can set brush to smoothing instead of displacing- will probably want to increase brush size and strength for most smoothing
    1083 x 908 - 87K
    1368 x 901 - 115K
    1570 x 972 - 136K
    Post edited by Diomede on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,299
    Diomede said:
    How do you do that?
    obj exports
    https://xnormal.net/
    Malwarebytes is flagging the download though surprise
    Zbrush Zprojection to a subdivided mesh and multimap exporter may be a safer option
    I already have xNormal from years ago
    Complete Shaping, Return to Modeler, and Reduce Smoothing to 0 for Export
    1686 x 983 - 146K
    1902 x 964 - 285K
    1918 x 996 - 304K
    WendyLuvsCatz said:
    Diomede said:
    How do you do that?
    obj exports
    Thanks.  I have edited the first post of the series.
    Setting Smoothing to 0 and Exporting as a Morph
    - make sure smoothing is at zero (much of detail appears to disappear)
    - return to assemble room
    - export the file
    - in OBJ dialogue, choose Daz Studio (Morph) preset
    1131 x 978 - 106K
    839 x 838 - 59K
    1626 x 990 - 214K
    1172 x 693 - 130K
    774 x 690 - 79K
    Open a new Daz Studio Scene and Use Morph Loader Pro
    - Load Genesis 9 base in Studio
    - Use the edit menu to start morph loader pro
    - Load your morph obj
    - In dialogue, generally a good idea to get in habit of using 'deltas only' even when not needed.
    - If works, will get a confirmation screen.  Yay.
    1809 x 970 - 225K
    1730 x 978 - 239K
    25 morph loader pro menu carrara scale deltas only might need reverse defomrations sometimes but not this time.jpg
    1795 x 968 - 241K
    1283 x 897 - 147K
    Save the Morph Asset - Check ONLY the New Morph
    1291 x 982 - 185K
    30 save as morph asset then CHECK ONLY WHAT WANT MOROHED IN THIS CASE HEAD and choose only your current morph loader morph.jpg
    1736 x 954 - 231K
    31 give product name vendor name and check only the morph and area affect.jpg
    1084 x 779 - 98K
  • I sent you a message
    Got it.  Thank you.  Will probably have questions down the line.
    edited December 2022
    Modeling for a Targeted Shape of Genesis 9 - Marvelous Designer
    I posted another screenshot tutorial in the Art Studio Forum.  Before the release of Genesis 9, I went through an example of creating a skirt for Genesis 1 because G9 was rumored to be like G1 in a unified shape.  Rumour turned out to be true.  In this screenshot turoial, I use Marvelous Designer to create a simple loose skirt with many folds designed for the Victoria 9 shape.  The resulting figure might be optimized for Victoria 9, but it can also be used with any G9 shape, such as a kilt for Michael 9, or a battle dress for a male demon.  The tutorial also includes creating shader domains and UV Mapping in Marvelous Designer.  I then export the OBJ to Studio where I rig from the V9 shape back to the base shape.  Demonstrate a couple DForce posing and morph shape examples.
    Might be useful for Carrara users intending to make G9 items for use in Carrara as conformers or with VWD.
    https://www.daz3d.com/forums/discussion/comment/7884426/#Comment_7884426
    Genesis 9 Shaders: Using Carrara 3D Paint to Create Opacity Maps
    First Prepare a Genesis 9 Base Figure Blended Weight and Save as a Character Preset
    - Load Genesis 9 base in Studio without any eyeballs, mouth, eyelashes, etc.
    - Use the Edit menu to Edit Figure Rigging change to Blended weight
    - Save the result as a character preset
    - The character preset can be loaded in Carrara
    - Going to use Carrara's 3D paint tool to create an opacity map for the body surface that could be shorts.
    1500 x 1800 - 2M
    Prepare Genesis 9 Base in Carrara
    - load the blended weight Genesis 9 base character preset compatible with Carrara without any textures
    - select the actor level which allows access to the mesh
    - the 3D Paint tool is in the upper left of the Assemble Room menu.  It is next to the wrench.  looks like a hand brush over a plane
    01 open Carrara and load a G9 base figure no eyes no etc after convert to blended weight and saved as character preset.jpg
    1917 x 1014 - 303K
    1911 x 1019 - 296K
    562 x 429 - 40K
    Initiate the 3D Paint Tool
    - Locate and click the 3D Paint tool in the upper left area of the menu.
    - Ignore the warning that there are no active textures.  Will be creating some.
    - A texture menu appears in the upper right.  It lists types of channels to paint, such as color, bump, etc.
    - Open the color channel and click the magic wand looking thing to create a new texture map.
    - A notice lets you know a new texture will be created.
    - a create textures menu appears
    - for this project, select only the body, set the base color to white, and increase the map size
    - will be prompted for save file info, pick a name (I inserted Body) and file location.  I keep the tif format.  Have had issues with some of other formats and can always change later in an image editor.
    - I turn off compression
    - the result is that the body surface material of the new map turns white
    857 x 588 - 65K
    1038 x 776 - 107K
    372 x 476 - 29K
    1459 x 975 - 176K
    1377 x 853 - 155K
    09 change texture menu choose only body change color to white and map size larger.jpg
    1298 x 897 - 154K
    1361 x 912 - 160K
    1302 x 891 - 151K
    1453 x 967 - 176K
    Set Up Brush Tool
    - the tool menu tab is next to the texture map menu tab
    - Enable symmetry at the top.  Choose X axis.
    - Change the brush color to complete black.  Will be painting where we want things to be invisible.
    - Change the brush size.  The default brush is way to big for this project.
    - Change brush hardness.
    824 x 878 - 105K
    14 cheange settings symmetry in x color brush black brush size down to 5 smoothing 0.jpg
    813 x 877 - 106K
    Begin Painting Invisibility Areas
    - Will be creating shorts so paint away the top of the torso.  Start at the waist.
    - Once a rough job is done at the waist, increase brush size.
    - Paint away the rest of the upper torso with larger brush.
    1171 x 701 - 88K
    328 x 367 - 27K
    1188 x 1004 - 150K
    571 x 621 - 61K
    Use Line Tool for Straight Line at Belt Level
    - change color to white
    - enable line tool in upper left
    - adjust line tool settings in upper right
    - draw a white line on side
    - draw line in front center connecting sides
    - repeat for back
    319 x 210 - 12K
    672 x 423 - 20K
    556 x 242 - 13K
    23 draw line on back stray marks are because symmetry but uvmap artifacts.jpg
    619 x 332 - 16K
    Continue Editing with Line Tool and Brush Tool
    - brush away imperfections
    - the symmetry tool may have introduced some stray marks at sides
    - turn off symmetry to address side details
    - continue line tool and brush tool until get desired result
    440 x 306 - 20K
    472 x 768 - 57K
    1399 x 977 - 179K
    Save the Painted Texture Map as the TIF file (or format you chose)
    - return to texture map menu in upper right
    - right click on the small map in the color channel t bring up the menu
    - Save will save as name you chose in location you chose in format your chose in the beginning
    - In my case, I save as body color map in my tutorial folder
    405 x 466 - 33K
    450 x 417 - 36K
    1225 x 906 - 163K
    Using the New Map as Opacity Blender in Carrara Shader
    - this is for Carrara users. Daz Studio Users skip down to geoshell discussion.
    - Create a new shader, of type complex shader, using the new map in blender channel - for the body shader domain.
    - In this case, with actor level still selected, I entered the texture room, and created a new shader for the body.
    - new shader tree menu appears
    - change the shader type to complex shader, multichannel mixer
    611 x 646 - 61K
    1722 x 871 - 262K
    1055 x 633 - 140K
    Set Channel 1 Shader to Genesis 9 Base Male Texture
    - in first shader of complex, change color channel to texture map and navigate to location of Genesis 9 default male body taxture maps
    - can also load the normal map for the body in the bump channel set to normal.  will be very strong so might want to lower bump effect
    - can continue loading maps and creating a carrara skin shader but beyond current scope
    1740 x 957 - 279K
    814 x 638 - 103K
    Set Channel 2 Shader to Any Color Not Skin
    - change color
    1194 x 878 - 190K
    Load Painted Opacity Map in Blender Channel
    - Load Painted Opacity Map in Blender Channel
    1281 x 717 - 128K
    Test Render of Torso Changes in Carrara
    - ideally, would set all the skin maps and do a proper test render
    - maybe later.  for right now, this image confirms the torso opacity map allows for a separate shorts shader in Carrara
    800 x 600 - 16K
    Set Up Daz Studio Geoshells
    - load Michael 9 or any other G9 character in Studio.
    - use the create menu to create a geoshell
    - give a name etc
    - result is default geoshell for various material zones of the main G9 figure - will look milky gray
    988 x 533 - 99K
    1082 x 528 - 111K
    671 x 390 - 55K
    1149 x 845 - 120K
    Set Opacity of Non-Body to 0, such as arms
    - use surfaces tab. select arms.  find opacity channel.  set to 0 to make geoshell invisible.
    - repeat for fingernails, etc
    - got to surfaces tab of G9
    - select the Arms surface
    - find opacity strength channel and set to 0 to make geoshell on arms invisible
    - repeat for head, nails, etc
    985 x 741 - 87K
    1306 x 844 - 166K
    44 find opacity channel and set to 0 notice arms appear normal in viewport.jpg
    1400 x 875 - 154K
    1456 x 888 - 164K
