CARRARA CHALLENGE #64: Old egypt..... WIP
1234568
  • Bunyip02Bunyip02 Posts: 9,345
    ed3D said:
    And ,  a  couple  of   W.I.P.'ers  _
    same Scene  ,  just Differnt Camra Views  -  Thanx
    Nice start !!!
    Diomede said:
    Argh, and more argh.  I am just having all sorts of trouble this time around.  Another scene, another crash.  In this, I had 2 Genesis 9 figures, one set to my G8 Male Mummy morph and one set to Victoria 9.  I had one Carrara hair for V9 which I liked and did not save (argh, that was very stupid of me).  I had maybe 4 or 5 props with some tiled shaders of Egypt-themed texture maps.  I had one vertex object to be V9's clothing/wrapping.  Lighting was set up.  All was well and I was getting close to doing test renders.  I decided to try to add some detail to a prop by adding Carrara hair - and crash-o freeze-o.
    Argh, argh, argh.
    What a PITA - was hoping your troubles were behind you !!!
  • ed3Ded3D Posts: 2,656
    Nice start !!!
    well ,.,.Thanx   _  kind of lik the Closer View ,  somehow  , But , not sure which   //
    edited November 2022
    Diomede said:
    Thanks for the comments, UB, Stezza, and Bunyip.
    Looking good, ed3D.  Did you decide to import the Bryce pyramids?  Or are those Carrara objects?
    And  only Sphere is an Carraia object  +   All others is Blenders  -  And  Thanx
    Post edited by ed3D on
  • DiomedeDiomede Posts: 15,470
    Yay.  I managed to actually render a scene with Genesis 9 morphed to the shape of the G8 Male Mummy and Victoria 9.  The wrapped male mummy with the ankh is a prop from a Daz Egypt set, as is the open sarcaphagus.  Created a procedural skin shader for the G9 Male Mummy instead of trying to figure out how to get G8 maps to G9.  The skin is a mixture of the skin that comes with Carrara in the organic folder and some 'freaky skins' Carrara product and some of my own playing around.  Lost a lot of the bump/normal detail by not using the maps that come with the G8 Male Mummy.
    Another note when using G9 in Carrara.  Always check conformed items when you change a pose.  I had to unfit and then 'fit to' the eyebrows, the eyes, and eyelashes to G9 a couple of times.  Ditto for the bandage wrapping I modeled and attached to the G9 skeleton.
    The title is a Carrara text object with a bulge modifier applied.
    Will probably be making some more adjustments but here is the raw render from Carrara, and the scene setup.
    1067 x 1600 - 905K
    1482 x 1012 - 211K
    Post edited by Diomede on
    Note - this is a NNVIATWAS
    Nearly Naked Vicky in a Temple with a Soulmate.
    Provisional Entry
    Assuming still permitted, I may swap this out after some more adjustments.
    1067 x 1600 - 219K
    Thanks Ted and Bunyip02 - unfortunately doing funeral stuff . Don't have much time for Carrara at the moment.
    Here's the setup in Carrara and the prepost job. At first I rendered with alpha on - hence the black sky in the final.
    2000 x 2642 - 2M
    2450 x 1386 - 1M
    Post edited by Headwax on
    More Inspiration
    Getting closer to the deadline, but atill time to get entries in.  Here is a 3-D related exhibit in Los Angeles.
    Beyond King Tut
    https://beyondkingtut.com/city/los-angeles/
    Sending Condolences & Man-hugs !!!!!!
    Blessings to you and your family.  heartbroken heart
  • rk66rk66 Posts: 452
    Maybe for a delta etc - River Styem plug-in by Sparrowhawke3D
    > https://www.patreon.com/posts/river-system-72665767
    sending condolences heart losing one's Mum is the hardest thing for anyone
  • Richard HaseltineRichard Haseltine Posts: 112,033
    Post moved to WIP thread
    Thanks.  That suggested plugin would be a great help for my Nile Delta project.  I asked that the comment be moved to this WIP thread.
    Diomede said:
    Provisional Entry
    Definately a near naked Vicky !!!
    Nice scene !!!
  • KhoeKhoe Posts: 347
    it's a pity that the plugin doesn't exist for MAC. Maybe someone can compile it. I would like that
    @Khoe
    A few plugins for Mac you can find here (scroll down)
    > http://www.sparrowhawke3d.com/Sparrowhawke3DLaboratory.html
    Another inspiration that I will try to implement in the future.
    The image was generated by AI software (midjourney). At the moment I'm wondering how I could best implement the pyramids, especially the textures give me headaches. If anyone has any ideas...
    1024 x 1024 - 1M
    Post edited by Khoe on
  • ProPoseProPose Posts: 550
    Looks mighty good from here.  Nice render
    On pyramids and textures.  As a starting place, I think I would experiment with displacement map textures.  Displacement works better when subdivision smoothing is enabled.  Therefore, I recommend using the fillet tool on the edges of the pyramid model before smoothing in order to keep the shape.  Here, I took a square grid and some scratch maps into an image editor and made a quick displacement map.  Here is an experiment of using the displacement map on a simple pyramid made and uvmapped in the vertex modeler.  This is just a starting point.  I think some of the pyramids have a step structure so that should probably be modeled in instead of relying on the texture.
    2407 x 1263 - 304K
    800 x 800 - 230K
    2517 x 1195 - 309K
    1600 x 1200 - 200K
    Increase subdvision smoothing strains computer but gets better results.
    1600 x 1200 - 212K
    Apply Yellow Mesa terrain texture that comes with Carrara.
    1600 x 1200 - 206K
    Nice !!!
  • Bunyip02 said:
    Nice !!!
    +1
    I was thinking of doing something similar.  Good use of that mesa texture.  A rather obvious choice in hindsight, but I probably wouldn't have thought of it.
  • Diomede said:
    Provisional Entry
    Well done.  It looks like a 40's pulp magazine.
    The scratch texture (a good idea) you applied doesn't show up unless you enable a larger view, which you didn't do.  But even if it was bigger, I think that you could make the scratches stronger and more obvious.
    Thank you, Bunyip and UnifiedBrain for comments on Mummy's Bride pulp book cover and the demonstration of using a displacement shader for a pyramid.  On my actual entries, I feel like I am too little too late with 3 of my 4 entries. Aaargh.  My apologies to Khoe.
    In hindsight, one thing I would very much have liked to have tried would have been to use Alberto's Fluidos plugin to part the Red Sea.  I think Carrara could probably animate that well.  No animation entry from me this time. My intention had been to try to do one animation in any challenge allowing for multiple entries.  Argh.  Spent too much of the time period without my main PC.  Including now.  Traveling for American Thanksgiving.
    another wip picture. Trying to recreate the image I posted from ai program Midjorny. I was able to find a 3d scan of the pyramids on Sketchfab But now I have to hurry to finish the picture. there are still many things to be done.
    1190 x 1397 - 1M
    810 x 1080 - 86K
    Time is ticking by - nice render !!!
