Default Studio View Control settings?
Could someone kindly remind me of what the default keyboard shortcuts are for Studio's view controls (located at the bottom of the Customize menu)? I changed them a while back to try to better work with a tablet, but now I've ended up disabling being able to use Ctrl to select more than one item at a time and need to change them back to their defaults without changing everything else I've edited in the Customize panel.
Thanks very much.
  • Doesn't the Default button rset them? As long as you have saved your layout you can reload it after checking.
  • SnowSultanSnowSultan Posts: 3,820
    Yes, but I've changed a lot of other keyboard shortcuts that I use often, like for the Surface Selection tool and for dual views, and would like to not have to redo all of them as well. I'm just hoping someone who hasn't changed theirs can simply post the default key combos.
  • If you saved your layout you can just reload it after setting to defaults and noting what that uses.
    Thanks very much
                   Here u go, hope this helps :-) !
    Orbit: Ctrl+Alt+LeftMB
    Rotate: Ctrl+Shift+LeftMB
    Pan: Ctrl+Alt+RightMB
    Dolly: Ctrl+Alt+MidMB
    Bank: Ctrl+Shift+MidMB
    Zoom (Dolly): Ctrl+Shift+RightMB
    Zoom (Focal Length): No Shortcut
    Just what I needed, thank you!
  • No problem just glad I could help :-)
