Default Studio View Control settings?
SnowSultan
in The Commons
Could someone kindly remind me of what the default keyboard shortcuts are for Studio's view controls (located at the bottom of the Customize menu)? I changed them a while back to try to better work with a tablet, but now I've ended up disabling being able to use Ctrl to select more than one item at a time and need to change them back to their defaults without changing everything else I've edited in the Customize panel.
Thanks very much.
Doesn't the Default button rset them? As long as you have saved your layout you can reload it after checking.
Yes, but I've changed a lot of other keyboard shortcuts that I use often, like for the Surface Selection tool and for dual views, and would like to not have to redo all of them as well. I'm just hoping someone who hasn't changed theirs can simply post the default key combos.
If you saved your layout you can just reload it after setting to defaults and noting what that uses.
Here u go, hope this helps :-) !
Orbit: Ctrl+Alt+LeftMB
Rotate: Ctrl+Shift+LeftMB
Pan: Ctrl+Alt+RightMB
Dolly: Ctrl+Alt+MidMB
Bank: Ctrl+Shift+MidMB
Zoom (Dolly): Ctrl+Shift+RightMB
Zoom (Focal Length): No Shortcut
Just what I needed, thank you!
No problem just glad I could help :-)
