• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Having Trouble Rendering Hair Amara Braids in Cycles
hello_4493841hello_4493841 Posts: 7
October 2022 in Blender Discussion
I'm having trouble rendering the Amara Braids in Blender Cycles. I'm using the DazToBlender bridge to transfer the character and hair and leaving nodes setting as they were.
My first render the braids were very shiny and with no detail. I added some roughness to the braids on the second render and that helped with the shine but they still seem to lack detail.
I've used some other iRay hair products that transfer nicely so not sure if there's something I'm missing or if anyone has suggestions on a better node setup.
Thank you
  • PadonePadone Posts: 4,276
    October 2022
    The daz bridge has a limited support for converting materials. You may try diffeomorphic that generally works much better. But keep in mind that you always convert iray materials to cycles materials that are not native to blender, so it is just normal that in some cases you may have to fix the material.
  • hello_4493841hello_4493841 Posts: 7
    October 2022
    Thanks for your reply!
    I had at one point tried to use the diffeomorphic add-on but was running into trouble getting it to work, I'm on a Mac and couldn't find much info about how to install or troubleshooting errors.
    I did come across another post talking about the DazForBlender add-on that also mentions converting iray materials to cycles and "handles tiled material". I haven't had a chance to try that add-on but it did get me thinking the braids looked like a tiled material that was being stretched and was losing detail. So I setup a texture coordiante node for the braids and scaled like 10x and also cranked up the bump strength.
    The attached render is not perfect but definitely a lot better then the original glass look.
    4096 x 2160 - 357K
    October 2022 edited October 2022
    FYI diffeomorphic handles uv tiles just fine, among other things. The official daz bridge misses a lot of features as geografts, shells, instances etc. that's why most daz users use diffeomorphic. To install is just a matter of copying the scripts in the right location so really easy. But not Thomas nor I have a mac to test so may be there's some caveats with the case sensitive file system ?
    If you want to try let me know I'll follow you to help.
    Post edited by Padone on October 2022
    October 2022
    I gave it another try and did get Diffeomorphic installed on the Mac. In Daz I saved the character as a Character Preset, but when I import the file into Blender it does not load the character morps, tear shape, eyelashes or hair ... it seems to just load the default Genesis 8 female character with the custom characters skin maps applied.
    Do you have an idea of something I'm missing?
    October 2022
    You have to load your preset in daz studio and save the scene. Then diffeomorphic will import the scene, not the character preset.
    October 2022
    I went back and read the instructions again and realized I had not copied the scripts into Daz and did not do the export to Blender step and so it wasn't loading the .dbz file.
    Everything is setup and working now.
    Are there any articles or anything I can read about how you got to these conversions? Is it just converting the programming or something more based on artistic decisions? The reason I ask is because it’s interesting to see how drastically different the import results are between the DazToBlender, DazForBlender and Diffeomorphic and how the nodes are setup.
    Thanks again.
    Yes all the technical details for issues and materials are in the tracker but it's huge. If you have a specific question about a particular conversion I can point to the specific discussion. Below it's the skin basic for example, then we evolved from that but it's lots of articles. The conversion is made by faithful comparison and some artistic decision when a 100% match is not possible for technical reasons, that happens often.
    The best way to study the materials is to export a specific material then look how it is made in blender.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/24/
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
