Starion's WIP and test thread
1…2224262728
  • starionwolfstarionwolf Posts: 3,670
    I finally found the error message. Looks like there is an issue with Nabila or End of Summer hair. I'm going to run some tests now.
    Compiling Shaders - 1/1
    Rendering Image
    Rendering...
    3Delight message #147 (Severity 2): R2077: trying to access element 0 of array 'stdin' of size 0, run-time check failed (line 143 of file f) (in shader 'brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement' on object 'shapematerial_Face_4504_6a0')
    3Delight message #147 (Severity 2): R2077: trying to access element 0 of array 'stdin' of size 0, run-time check failed (line 143 of file f) (in shader 'brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement' on object 'shapematerial_Head_4872_6a0')
    3Delight message #147 (Severity 2): R2077: trying to access element 0 of array 'stdin' of size 0, run-time check failed (line 143 of file f) (in shader 'brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement' on object 'shapematerial_Shoulders_5056_6a0')
    quick test render in yellow light. I changed the group ID of Nabila's skin surface.
    798 x 861 - 192K
    Lighting commentary continued.
    Advanced spotlight only; no ambient. I'm just showing the contrast between the light and dark areas. I finally found the morph to fit Genesis 2's feet into the high heels. A dial called Pred_FitShoes controls the morph, not a thumbnail script in the content library.
    803 x 602 - 144K
    I'm too lazy to change her outfit again. Advanced spotlight with one distant light.
    803 x 602 - 192K
    edited March 2015
    fun with sub surface scattering. I applied a green color to the shoes via sub surface scattering. The diffuse color is still red.
    297 x 110 - 12K
    803 x 602 - 208K
    Post edited by starionwolf on
    The same scene (minues the green shoes) in Iray. I'll edit the settings after I reboot my computer. Iray makes my computer run hot too.
    465 x 193 - 43K
    803 x 602 - 345K
    CPU rendering is slow. I can't afford a new video card and power supply for Iray. I'll upload the finished version later.
    830 x 754 - 276K
    I'm back from lunch. I used a null light as the sun.
    366 x 167 - 21K
    803 x 602 - 202K
    I meant to change the shading rate but I accidental changed the gamma.
    3D delight with advanced spotlight and 1 distant light.
    803 x 602 - 163K
    Posing figures on a curved ground is tricky. Uber area light in 3Delight.
    803 x 602 - 221K
    playing around with lights and shadows again. The advanced spotlight is below the characters pointing up. Yes, the scene is supposed to be dark.
    803 x 602 - 173K
    edited March 2015
    UltruMarine Ocean
    I need some aquatic plants.
    800 x 600 - 112K
    I forgot what I wanted to do with this scene. Hmm. Maybe I'll remember later.
    1000 x 562 - 258K
    edited April 2015
    playing with Courtly intrigue poses. Genesis human has a fairy morph. I forgot the name of the morph.
    Memory usage: 1.4 GB.
    1000 x 562 - 243K
    The sky is too bright. I should adjust its ambient level.
    803 x 602 - 147K
    edited May 2015
    Use Easy Environments with Iray
    1st test: Luminance is set to 10,000. Oops, that is too low.
    edit: I'll update the render soon.
    803 x 602 - 142K
    I'm going to have heart surgery soon. Yay!  I'll try to finish some of my current 3D scenes before I go to the operating room.
  • bighbigh Posts: 8,147
    wish you the very best !
  • ps1borgps1borg Posts: 12,776
    God bless and keep you always, and guide the surgeon's hand :)
  • DanaTADanaTA Posts: 13,419
    You come back healthy, you hear?  wink
    Dana
  • atticanneatticanne Posts: 3,009
    Have you had your heart surgery yet?  I hope everything is progressing well for you, Starion.
    I still don't have a date for my surgery.  I will have an appointment with the surgeon on the August 20.  Maybe he will schedule the surgery on that date.  I still feel sick.  Thanks for asking.
    Great to hear from you again.  The waiting can really get to be a downer.  You are still in my thoughts and prayers.
    I don't mean to whine, but living with shortness of breath, high blood pressure and a fast heartrate is no fun.  Thanks for the comments everyone.
  • frank0314frank0314 Posts: 15,117
    Hope everything goes well for you and you start feeling better.
  • kyoto kidkyoto kid Posts: 42,499
    ...in my thoughts and prayers.  I want you to be able to make that trip to Australia you talked about
    edited August 2015
    Thanks.  There is a furry convention in Melbourne, Victoria in January.  There is a big easter show with agriculture exhibits in Sydney in March.  I think that there is even a small equestrian show at the royal easter show. I still want to see the Blue Mountain National Park.  I should make a list of all the cities that I want to see and post it in this thread.
    My old friends from high school invited me to dinner next week.  Sorry for the short post but my arms are getting tired.
    Bye
  • McGyverMcGyver Posts: 7,112
    Good luck starionwolf.
    Please keep up your positive attitude and no matter what, remember you have a lot of people here who are wishing you the best and speediest recovery.
    Yes!
    Dana
    I'm going to have open heart surgery next month.  I'm not saying the exact date for privacy reasons.  The surgeon wants to patch a hole in my heart and to replace a leaking valve.
    I need to finish some artwork before I go to the operating room.  Bye
