Error in morph loader
iacoposk8iacoposk8 Posts: 76
edited September 2022 in Daz Studio Discussion
Hi everyone! I'm not an expert, but it's not the first morph I create. I'm probably doing something silly wrong.
I have a shirt (left image) that I quickly edited to show you what happens to me (right image, the central part is narrower)
I imported the t-shirt into daz (left image)
With morph loader I imported the model in the right image, I set it to 100% and this is the result:
Why? thank you
Post edited by iacoposk8 on
  • If you are using Blender make sure that the option to preserve vertex order is set on both importing the base shape for editing and exporting the new shape.
  • lilweeplilweep Posts: 2,860
    If you forgot to keep vertex order on importing to Blender, and then did a lot of work in Blender, you can use the free add on by bartoszstyperek called 'Transfer the vertex order' to copy vert order of a mesh with correct vertex order.
  • Thanks so much for the quick reply! You are right. The blender update I read has changed the position of this entry
