Daz Central question
Pendraia
Hi, I'm back after a long break from ds and I want to download Vue Frontier which I bought here. However the only way seems to be via Daz Central.
Can anyone explain to me what this is and the pros and cons of using it?
I would prefer to do a manual download as I already have DIM installed. Is there any way to do a manual download on items?
thanks for reading
Pen
If any product in your Product Library in your Account has a "manual" button, you can download it manually. {I don't have Vue so can't check mine}
This didn't for some reason, Bryce does but this seemed to want me to use Daz Central. It was the only choice I could see. I might have to do a screenshot and contact support about it.
There is ONE product of all the kazillions I've purchased here where the download options appear at the very bottom of the page.
I am not aware of there ever being times when "only" Daz Central can be used for downloading so yes, if I were you I would certainly contact support. They can manually put things right.
If "Daz Central" is the only install method listed it usually means there are no files associated with the product, which is definitely a matter for support.
Thanks Richard and Catherine. I will double check and look right at the bottom like Catherine has suggested and if I still can't locate a download I will contact support about it.
thanks for your help...
