Daz Central question
Hi, I'm back after a long break from ds and I want to download Vue Frontier which I bought here. However the only way seems to be via Daz Central.
Can anyone explain to me what this is and the pros and cons of using it?
I would prefer to do a manual download as I already have DIM installed. Is there any way to do a manual download on items?
thanks for reading
Pen
  • If any product in your Product Library in your Account has a "manual" button, you can download it manually. {I don't have Vue so can't check mine}
  • PendraiaPendraia Posts: 3,629
    This didn't for some reason, Bryce does but this seemed to want me to use Daz Central. It was the only choice I could see. I might have to do a screenshot and contact support about it.
  • There is ONE product of all the kazillions I've purchased here where the download options appear at the very bottom of the page.
    I am not aware of there ever being times when "only" Daz Central can be used for downloading so yes, if I were you I would certainly contact support. They can manually put things right.
  • If "Daz Central" is the only install method listed it usually means there are no files associated with the product, which is definitely a matter for support.
    Thanks Richard and Catherine. I will double check and look right at the bottom like Catherine has suggested and if I still can't locate a download I will contact support about it.
    thanks for your help...
