How do I make this look like the promos?
edited August 2022 in Carrara Discussion
Hi! I'm very new to Carrara and I thought I'd start with premade scenes. I picked up the World Gardens Maze by Howie Farkes, but I can't get the azaleas to look like azaleas, I just get green shrubs. What setting am I missing? Thanks for your help.
Post edited by jhogenboom_da69c035a9 on
  • Steve KSteve K Posts: 3,534
    My only guess would be to try the "Custom Leaf Objects - Azalea Flower" listed with the product.  The complete scene file may have somehow left these out.
  • Thanks. This shows how very new I am. Daz Install Manager has put the file here:  /Data/World Gardens/Maze/HF_AzaleaFlower.car
    How do I get at it? I tried the content tab on the browser, but I don't see anything to open.
  • 3drendero3drendero Posts: 2,033
    Here is the online readme, there is a file list, check if something is missing. It could all be installed in the Carrara folder, I guess depending on how DIM is setup. http://docs.daz3d.com/doku.php/public/read_me/index/15969/start
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,446
    Carrara very fussy about leaf location and will load the default leaf without a whimper if they are not where it expects them, DIM is particularly bad at putting them where Carrara doesn't look, I end up searching the installed files and finding them and replacing them manually
  • RuudLRuudL Posts: 227
    edited August 2022
    All the files of the original Data-folder needs be placed in the /Data/Plants/World Gardens/Maze/ folder located within the application-folder.
    After you have done that open the original unchanged scene-file. If you have opened and saved the original scene file eariier Carrara will have replaced all the leave reference, that it can not find, with the default leave. A simple green one.
    1226 x 523 - 161K
    Post edited by RuudL on
    I don't know, but the other folks here have good advice.  I do not as a rule use DIM, but download the products to my own folder, then use that folder to load products.  I have always been able to find and load *.car files.
  • Ooo. Look at that! It's magic! Thanks RuudL and everybody.
    400 x 520 - 44K
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Nicely done!
    Welcome to Carrara.
