How to handle buttons and dforce cloth?
James
How to handle buttons, so they work with dforce cloth?
Post edited by James on
James
You can use rigid follow nodes, check this thread: https://www.daz3d.com/forums/discussion/203481/setting-up-items-with-rigid-follow-nodes-tutorial
They are time-consuming to set up, but well worth the effort, at least if there are a few!
If I had 10 buttons, Do I have to do rigid follow nodes, one by one?
Yes, each location must have its own rigid follower node. A rigid follower node is a polygon reference, so unless 2 buttons is placed in the same spot, they should have each own.
