How to handle buttons and dforce cloth?
James_1597261
How to handle buttons, so they work with dforce cloth?
Post edited by James_1597261 on
James_1597261
You can use rigid follow nodes, check this thread: https://www.daz3d.com/forums/discussion/203481/setting-up-items-with-rigid-follow-nodes-tutorial
They are time-consuming to set up, but well worth the effort, at least if there are a few!
If I had 10 buttons, Do I have to do rigid follow nodes, one by one?
Yes, each location must have its own rigid follower node. A rigid follower node is a polygon reference, so unless 2 buttons is placed in the same spot, they should have each own.
