Registering problem
BheathBheath Posts: 0
edited December 1969 in Bryce Discussion
Hi, i just downloaded bryce on my mac. I have installed ect but when i open it it asks for my name and code. I had a code thing that came when i downloaded it. but when i enter it it just crashes and closes.
Any solutions?
Thanks
  • Dave SavageDave Savage Posts: 2,435
    Which Mac and OS are you running?
    Bryce doesn't like 64bit nor the latest versions of the OS.
  • BheathBheath Posts: 0
    Macbook pro OS X 10.8
    not sure if its 64 bit or not.
    Bryce & will not currently work on OSX 7 or OSX 8.
    THey are hoping to sort this out the next time Bryce enters the dev cycle
  • ziggy_10f187f27aziggy_10f187f27a Posts: 4
    I'm seeing something similar with Bryce 7 and OSX 10.6. The software starts to load, comes up with a registration window (that I can't enter anything into) and then I get the spinning beachball of doom.
    Now that is unusual. Most people can work fine with 10.6
    Bummer... I was hoping for one of those "Everyone sees that, you just need to do X and it'll work" kinda answers :)
    Sorry. I don't use a Mac, so am not a lot of help. I know there are other problems with Bryce on 10.6, but haven't seen anyone having trouble like that.
    You may be better to make a thread, with a tilte about Registering problems with OS X 10.6 or someting, so people can see what your actual problem is.
  • Dan WhitesideDan Whiteside Posts: 507
    Two things that can cause this are not installing/running as Administrator or a Permissions error . Command+I click on the Bryce App Icon will tell you if you have Administrator privileges. You should also try running Utilities>Disk Utilities >Repair Disk Permissions.
    There also were some problems on early Macbook Pro models but I thought that was fixed.
    It works for me under 10.6.8/MacPro and B 7.1.0.109.
    This was one of those cases that was fixed by rebooting the machine. Thanks for the responses!
