Registering problem
Hi, i just downloaded bryce on my mac. I have installed ect but when i open it it asks for my name and code. I had a code thing that came when i downloaded it. but when i enter it it just crashes and closes.
Any solutions?
Thanks
Which Mac and OS are you running?
Bryce doesn't like 64bit nor the latest versions of the OS.
Macbook pro OS X 10.8
not sure if its 64 bit or not.
Bryce & will not currently work on OSX 7 or OSX 8.
THey are hoping to sort this out the next time Bryce enters the dev cycle
I'm seeing something similar with Bryce 7 and OSX 10.6. The software starts to load, comes up with a registration window (that I can't enter anything into) and then I get the spinning beachball of doom.
Now that is unusual. Most people can work fine with 10.6
Bummer... I was hoping for one of those "Everyone sees that, you just need to do X and it'll work" kinda answers :)
Sorry. I don't use a Mac, so am not a lot of help. I know there are other problems with Bryce on 10.6, but haven't seen anyone having trouble like that.
You may be better to make a thread, with a tilte about Registering problems with OS X 10.6 or someting, so people can see what your actual problem is.
Two things that can cause this are not installing/running as Administrator or a Permissions error . Command+I click on the Bryce App Icon will tell you if you have Administrator privileges. You should also try running Utilities>Disk Utilities >Repair Disk Permissions.
There also were some problems on early Macbook Pro models but I thought that was fixed.
It works for me under 10.6.8/MacPro and B 7.1.0.109.
This was one of those cases that was fixed by rebooting the machine. Thanks for the responses!
