Adding to Cart…
Philemo, how's this one tracking ?
ah yes, looking forward to more brilliant work :)
Headwax - thanks for the comments. I appreciate the encouragement.
~ and "when Is the actually End Time of the 15th ? _ suppose could Scoot In " Thanx
Boohoo. "An error has occurred." Carrara does not like me rendering an animation with one of the GMIC filters applied. I've tried it sequenced png and I've tried it to avi. Errors for both. No error when rendering to the standard photoreal without a post render filter.
Simple scene. Single figure with NLA clip for movement. Solid color as backdrop. Only mildly complicated scene element is some Carrara dynamic hair.
For the moment, I will abandon the idea of rendering to GMIC filters unless I hear from people. But if anyone has had success rendering animations with a post-render-filter such as Toon! PartIII or GMIC or YAToon, I'd appreciate any tips or suggestions.
you can render the image series in the backdrop using GIMIC and very low settings except pixel size
I do it all the time
Hmmm. I wonder what the problem is.
ah misread thought you were rendering the scene
some filters give me issues particularly the ones using a brush
maybe it's the particular filter
Now that I think about it, my prior attempts at animations generally did not have humans. I did a car race, balls rolling down ramps, and crystal balls. When Mike Moir was doing the animaiton group, I always just modeled elements and let others handle the posing and rendering. All sorts of inconveniences.
Hya be good if you could, the time of end is nominal, usually we do Daz Utah time - so by the end of the 15th Daz Utah time. But life is short and I am flexable ;)
hmm sorry you have problems,
I have rendered the commercial toon just as lines (can't recally what the commercial name is) with a an alpha channel and then superimposed them in post over an avi I made from a sequence of images
that I'd fed into Carrara and used as a changing texture - gah could have explained that better
If you want Gmic maybe you could render out a seequnce of non Gmic images and then batch file postwork them in GIMP - assuming you can do that with Gimp.
Save the Clown
I'll get you, my pretty, and your little dog too! Great one, Stezza.
Too many 'I have never...' for now, but I will file that suggestion away. Thanks. I'm sure it will come in handy.
Next problem. I am trying to create and save some NLA clips for my custom figures. They have inverse IK chains for the legs and feet. For some strange reason, I am getting a wierd constraint-type-effect on a hand. It happened in my fat clown and now it is happening on the female clown. The first pic has my default load for this figure. The second pic is after I selected the hip and moved it slightly in the Y axis direction. Only the hip. See how the left hand snaps to a strange pose? Experimenting with turning off and on constraints, etc., something in the hand is caught up in the feet IKs, I think - but I am not sure.
hmm you don't have a target helper somewhere Diomede ?
here's that animation I made with sequenced png's on top of each other https://www.facebook.com/andrew.finnie.artist/videos/10214052512896567
PS great character this girl is :)
Wonderful Stezza, I had to look twice then laughed then thought 'what if I am the clown?" !@! :)
calling @Philemo_Carrara
Well, Cecil B DeMille need not worry about my foray into film making yet. Yet.
Here is my attempt at having two of my silly clown figures dance to circus clown music. Music is called Circus Clown Music from Archive dot org and is freely available. Had lots of unanticipated problems, but I should have anticipated that. But if I had anticipated that, then the problems would not have been unanticipated.
For your enjoyment. (Wendy - this animation exprience has reinforced just how truly awesome you are!)
no you are awesome Ted
I just use DAZ dollies and canned motions, you create your own dolls
Thanks, Wendy. For some reason I sometimes feel the need to reinvent the wheel, even if my wheel is not as functional.
I should have said that I arranged the Carrara video output and the Archives.org music file in Lightbox, free trial version.
Kind of disturbing to hear this. I am not yet to the point where I can test it. My vision of art is currently tied to GMIC, and if post-render effects will not animate, animation is out for me.
That said, it seems illogical for them to not render.
I got partial renders. I don't remeber which was which, but I believe 80-something percent of one output rendered before I got the error and 90-something percent of the other. Wendy reports success with post render filters. It must be something about either my files, my computer, or something specific in my scene. But whatever it was, you can see the unhelpful error code 'an error has occurred' with no helpful information. In some ways it was even more painful to get the error after 90%.
Anyway, I recommend doing a quck test of about 5-10 frames with the filter combination you are planning before rendering the whole animation.
That sounds reasonable.
This is kind of embarrasing to ask, but what are the best render settings for an animation? I have only replicated 6 or 7 of Phil's videos so far, but I have closely examined the titles of the rest of the videos. None of the video titles actually say anything about rendering! He must slip it in there somewhere, but I can't find it.
Are you outputting PNG? JPG? How do these individual images magically turn into a video? If for example, you have two seconds of animation, what is actually outputted, what does the output file look like, and how is it edited?
Not sure I have much advice to offer, but for what it is worth... The duo dancing clowns that are my final were rendered as an avi file. I knew we the deadline was approaching and that I had little time to edit individual frames. I set my render settings at low quality for several reasons. First, Lightbox limits the quality of its exported finished video so no reason to have better quality in than out. Second, increasing video quality increases time. Third, I'm not going for realism. Note that some of my early WIPs in Carrara were rendered as sequenced PNG because I heard that way is more stable and ease of editing individual frames. But I gave the avi a chance at the end and it worked. I am the blind leading the blind on most of your questions.
OK,thanks. Hopefully Wendy and others can chip in.
Where the hell is Dart when you need him?
CORRECTION
Everywhere I said 'Lightbox' please insert Lightworks
Lightworks
https://lwks.com/
Substitution
I am substituting this improved (hopefully) version for my attempt above. I rearranged my NLA dancing clips and click-dragged to compress them, thus speeding up the clowns' movements. I also substituted a different rendition of 'Entry of the Gladiators' from the same Archives.org for the music.
@UnifiedBrain, I don't know about the software you will be using, but Lightworks has a menu option to detect image sequences. So if you render to sequenced images, you should be able to load them. Whichever software you choose will have something similar. I am using the free trial stripped down version of Lightworks.
I use image series
