Lumina Hair MATs
MilosGulan
I hope someone can help me with this. It was Christmas freebie and I am not sure how to make it work. I tried enabling gamma on 2.2 but result looks pretty much the same. Here it is, maybe I am doing something wrong, i just apply shader to the hair, is there anything else that needs to be done? I am not using textues of the hair, maybe i should?
Post edited by MilosGulan on
That looks like the dreaded shader not loading correctly bug.. you can try saving the scene and closing DS and then opening it all back up again.. that usually fixes that particular bug. But first, try applying the regular hair materials and then instead of just clicking on the Lumina presets, hold down control key while you click them and chose ignore in the box that pops up.
I haven't played with those shaders so I'm just guessing off the top of my head, things to try for the time being until more people wake up in this half of the world that might know better.
Thanks for your help. I tried with Ctrl and then Ignore but result is the same. But at least i learned something :)
Do you have UberSurface 2?
I think not, I have only UberSurface in my Shader Presets Folder. I am running DS 4.7 updated recently. I never used UberSurface before.
That's the problem, Lumina requires UberSurface 2.
How can I get it ?
http://www.daz3d.com/ubersurface2-layered-shader-for-daz-studio
Thank You very much. I added it to my wish list. Need to learn to use the basic ones first and other Uber Presets. I like them a lot.
