[Released] Turbo Loader Booster Utilities [Commercial]
24
  • In my random playing with these wonderful tools I ran into a perplexing issue. I can enable or disable the character HP Uki succesfully in the main G8F manager interface. However if she is disabled and I use the "enable and load" utility it enables some eyelashes but fails to enable the three main files. Every other character I've tried works fine. I think this is the releavant section of the log file:
    2022-05-17 23:42:29.403 [DEBUG] :: Turbo Loader Open File START E:/Public Folders/Public Documents/My DAZ 3D Library/Scripts/RiverSoft Art/Turbo Loader/Turbo Loader Open File.dse
    2022-05-17 23:42:29.405 [DEBUG] :: Enabling morphs for asset, Uki: L:/DAZ 3D Libraries/Character Library/People/Genesis 8 Female/Characters/Uki.duf
    2022-05-17 23:42:29.449 [DEBUG] :: Find Related Morphs Hidden Morphs /data/DAZ%203D/Genesis%208/Female/Morphs/Hinkypunk/HP_PHMLashes.dsf
    2022-05-17 23:42:29.449 [DEBUG] ::     Morph 0 /data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/HP_PHMLashes.dsf
    2022-05-17 23:42:29.452 [DEBUG] ::     FRM: E:/Public Folders/Public Documents/My DAZ 3D Library/data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/HP_PHMLashes.tlOff
    2022-05-17 23:42:29.453 [DEBUG] :: Hinkypunk 1
    2022-05-17 23:42:29.453 [DEBUG] ::      FRM: /data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/HP_PHMLashes.tlOff
    2022-05-17 23:42:29.530 [DEBUG] ::  0 /data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/HP_PHMLashes.dsf
    2022-05-17 23:42:29.530 [INFO] :: HP_PHMLashes
    2022-05-17 23:42:29.531 [DEBUG] :: Enabling data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/HP_PHMLashes.dsf
    2022-05-17 23:42:29.532 [DEBUG] ::      Renamed E:/Public Folders/Public Documents/My DAZ 3D Library/data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/HP_PHMLashes.tlOff to E:/Public Folders/Public Documents/My DAZ 3D Library/data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/HP_PHMLashes.dsf
    2022-05-17 23:42:29.533 [DEBUG] ::  1 /data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/HP_PHMLashes.tlOff
    2022-05-17 23:42:29.533 [INFO] :: HP_PHMLashes
    2022-05-17 23:42:29.533 [DEBUG] :: Enabling data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/HP_PHMLashes.tlOff
    2022-05-17 23:42:29.534 [DEBUG] ::      data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/HP_PHMLashes.tlOff NOT FOUND.
    2022-05-17 23:42:29.581 [DEBUG] :: 2 morphs were searched for
    1 Enabled (0 failed to enable)
    0 Disabled (0 failed to disable)
    1 unchanged
    0 skipped
    in 179 msecs
    Note: Multiple files may exist for a morph if you use Daz Connect
    2022-05-17 23:42:29.582 [DEBUG] :: Merging true
    2022-05-17 23:42:29.582 [DEBUG] :: Apply Preset L:/DAZ 3D Libraries/Character Library/People/Genesis 8 Female/Characters/Uki.duf
    2022-05-17 23:42:29.583 [INFO] :: Prepare asset load (open): /People/Genesis 8 Female/Characters/Uki.duf
    2022-05-17 23:42:29.583 [INFO] :: Locking viewport redraw...
    2022-05-17 23:42:29.583 [INFO] :: Viewport redraw locked.
    2022-05-17 23:42:29.680 [INFO] :: Native format content directories: 5
    2022-05-17 23:42:29.680 [INFO] :: Poser format content directories: 3
    2022-05-17 23:42:29.680 [INFO] :: Other import format content directories: 0
    2022-05-17 23:42:29.680 [INFO] :: Begin asset load (open): /People/Genesis 8 Female/Characters/Uki.duf
    2022-05-17 23:42:29.708 [WARNING] :: ..\..\..\..\..\src\sdksource\general\dzundostack.cpp(739): DzUndoStack::clearAll() called with a non-zero hold level. Possible unclosed beginHold().
    2022-05-17 23:42:29.713 [INFO] :: *** Scene Cleared ***
    2022-05-17 23:42:29.713 [INFO] :: Determining missing assets...
    2022-05-17 23:42:29.714 [ERROR] :: Open File Failed - Could not read file: /data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/Uki/Uki.dsf
    2022-05-17 23:42:29.790 [WARNING] :: Could not resolve: /data/DAZ 3D/Genesis 8/Female/Morphs/Hinkypunk/Uki/Uki.dsf
  • RiverSoft ArtRiverSoft Art Posts: 6,827
    1 unchanged
    0 skipped
    in 179 msecs
    Something in Uki.duf is messing the script up I think.  The relevant problem is not much is found in that file for some reason, your log states:
    If I run it on something like Angel HD for G8F, I get a lot more morphs found in the original file:
    2022-05-18 06:20:45.979 [DEBUG] :: Find Related Morphs Hidden Morphs /data/DAZ%203D/Genesis%208/Female/Morphs/Mousso/Angel/MSO%20Angel%20Lashes.dsf,/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base/PHMMouthRealism_HD_div2.dsf,/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base/PBMNavel.dsf,/data/DAZ%203D/Genesis%208/Female/Morphs/Mousso/Angel/MSO%20Angel.dsf
    Please PM me.
  • NorthOf45NorthOf45 Posts: 5,739
    I had the same problem with Uki, and there is a problem with the Uki.duf file. The URL for the "Uki" modifier is incomplete, set simply to "#Uki". It should have the full (relative) path "/data/DAZ%203D/Genesis%208/Female/Morphs/Hinkypunk/Uki/Uki.dsf#Uki". (line 41166). Made the mod myself and she loads properly with TL Open File and TL Merge File from an originally disabled status.
  • Yup! that worked, Thank you.
    Thanks @NorthOf45
  • MouserMouser Posts: 675
    Hmm, 30% off is pretty good but I can just wait until it gets a bigger discount with time.
    All I need is will-power & patiance.
    So much for will-power & I dont have the patiance for the characters to load.
    But now the characters are loading in single seconds, worth it;)
    LOL! laugh  You just described why I create a lot of my products for DS!  I don't have the patience with something, which gives me the will-power to do something about it! laugh  Thanks for the support!
  • Mark_e593e0a5Mark_e593e0a5 Posts: 1,603
    Another proof for the proverb "Necessity is the mother of invention" laugh
    edited May 2022
    Interesting, I created & saved a profile as a test and made sure the related resources where included.
    The resources under the shaping tab do not apear but can be loaded and do function.
    Is this how it should work? (note: it does work when I load from content)
    Post edited by Mouser on
    Not sure what you mean.  The open/merge do not really work with shape presets as shape presets just set a property value.  If the morph and its property value have not been previously loaded by DS, there is nothing to set even if the open/merge reset the morph to enabled.
  • takezo_3001takezo_3001 Posts: 2,035
    As far as the shapes/JCM morphs are concerned, they are used by my characters by default; so having them in my scene is mandatory, as I won't be disabling them in the least anyway, but the thousands of other morphs definitely needs truncation, thanks to PAs like you DS is much more pleasurable to use!
    I am glad you like it! smiley
    I'm assuming I am doing something wrong here.
    I followed the youtube tutorial and created a toon profile including many toon character items etc.
    Worked fine, saved it and then rechecked adding all, worked as expected.
    Loaded my toon profile but no change all items are still checked and not just the toon related ones.
    Am I missing a step?
    Hmm restarted and now the config loads okay, no idea why, no errors listed in the log.
    Must be the eternal mystery of Daz Studio which has the usual computer states of Yes and No but with the additinal state of MAYBE.
    The configs save either CHECKED, UNCHECKED, or BOTH.  They do NOT save the opposite.  For example, if you have 10 morphs CHECKED and 1000 UNCHECKED, the CHECKED config will only have 10 items in it.  This means that if later you load the CHECKED config onto the morph list where everything is already checked, nothing changes as the thousand UNCHECKED items were not saved with the config. You would have to UNCHECK everything and then load the CHECKED config to see changes.
  • RiverSoftArt said:
    Thanks @NorthOf45
    These are still absolute must have tools for productivity but I spoke too soon. Uki is quite a character... With NorthOf45's edit to the main .duf file she does load properly with the utilities and still enables/disables properly with the main GF8 manager. However, she won't enable using the open file utility for a scene file she shares with several other characters; all of the other 8 characters enable properly. In order to eliminate the possibility that something "hinky" was left over in the previously saved scene, I enabled her first, loaded the scene succesfully, and then saved over it. After disabling all the characters again she still would not cooperate and remained disabled when using the file open utility. For now I have worked around it by moving her to the reserved morph list. Hinky indeed... wink
    greg_82000392 said:
    RiverSoftArt said:
    Thanks @NorthOf45
    Okay, I like a challenge...
    So, I took a closer look at Uki, both the character preset (.duf in Genesis 8 Females\Characters) and at the morph files (.dsf in data\\DAZ 3D\Genesis 8\Female\Morphs\Hinkypunk\Uki). Not sure if these changes will make a difference, but I had no problem loading Uki from a clean configuration using the Turbo Loader Open File utility before doing any of these changes, but it does remove some potential conflicts. Copy the originals before making any changes in case you mess it up. Sorry if this gets too technical...
    I found that the "modifier_library" section was repeated in both Uki.duf and Uki.dsf. Comparing to several other characters, the "modifier_library" section is always only in the .dsf file. Following that hunch, I removed it from Uki.duf (from Line 14 to 61). Uki loaded properly and is controllable with sliders for the whole character, and the head and body independently. (Having it in the Uki.duf file is probably why it worked in the first place where the "Uki" modifier URL was simply set to #Uki, but Turbo Loader Open File didn't like it.)
    I wondered why the figure loaded named as Genesis 8 Female, and not Uki. Turns out the node label is not set to Uki, but to Genesis 8 Female. Simple modify Uki.duf, in the "scene" section, "nodes" sub-section, change the "label" property from "Genesis 8 Female" to "Uki". [Optional, but while you are in there anyway...]
    Now, to get back the microthumbnail on the People controller to show Uki instead of nothing, the Uki.dsf file needs to be modified (because I removed the modifer_library from Uki.duf, where it was originally defined). Edit Uki.dsf, look in the first section in modifier_library and set "presentation" -> "icon_large" : "/data/DAZ%203D/Genesis%208/Female/Morphs/Hinkypunk/Uki/Uki.png". It could also be done in the Parameters tab, Uki control, Parameter Settings, Card, drop-down list, Browse..., navigate to "data\DAZ 3D\Genesis 8\Female\Morphs\Hinkypunk\Uki" and select Uki.png. Don't forget to save modified assets (File -> Save As -> Support Asset -> Save Modified Assets...)
  • NorthOf45 said:
    greg_82000392 said:
    RiverSoftArt said:
    Thanks @NorthOf45
    Thanks for allthe effort. Correct me if this less technical translation is missing anything: delete lines 14 to 61 in uki.duf. Optionally change "Genesis 8 Female" to "Uki" in the label property. Optionally change the empty string for the icon_large property to the correct path.
    I did all and all are improvements I'm sure. The open file utility still works for the character when she is disabled and everythg works fine in the G8F Turbo Manager. In fact a scen file that contains only Uki works fine, but using the open file utility for the scene file with 7 other characters still chokes on Uki. She is back in the reserved list for now but tomorrow I will try deleting all the other characters from that scene, saving it under another name and see how she behaves.
    That about sums it up, so far ;-) Can the scene load any other character after the first 7? The scene might have saved a different version of Uki, it saves a lot of information, even if there are existing presets. Also, when modifying files like this (outside of Studio), the memory cache doesn't know that something has changed, and might re-use a previously loaded Uki version. Best to start clean, or purge memory (there's a script for that in Scripts -> Utilities). Load the scene, remove Uki, save the scene, restart Studio, re-open the Uki-less scene, add new improved Uki, save the scene, restart Studio, open scene. You get the picture...
    What does the log say? Any error messages would be handy.
    You could be running into the Daz Studio cache.  I can load the exact same figure (not using TLBU) and the first time can take twice or more longer.  EDIT: It also depends on how the character was saved.  If the character preset has every morph in it for some stupid reason, it WILL be slower.  But that is a mistake of the PA who saved the character, not TLBU.
    That said, it should not be pulling in all morphs.  What is your "Enable Morph Detected Behavior?"  The fastest will be to pull in only the "Detected Morphs."  How many morphs do you have total (enabled and disabled?)  What is the figure?  And what does the log say?
    I appear to have this problem with my own characters that I dialed from presets, existing characters and my own sculpting work. How can I save the character without it thinking every morph on my system belongs to it?
    I am no expert on that stuff.  Are you saving as Character Presets?
    Character preset, but mostly I hope the characers via a scene subset with thier hair, jewelry, etc., loaded.
    As I said, I am no expert on this stuff.  Have the morphs you have imported from your own sculpting work been saved as morph files?
    Since I am very comfortable with looking at the scene file, I personally would open it in Notepad++ or other text editor and ripping out anything that should not be there.
  • kregersekregerse Posts: 0
    Hi!
    Somewhat I am not able to load the scene with Turbo Loader Open File. What am I doing wrong?
    Cheers!
    2022-06-16 14:55:22.711 [INFO] :: Loading Layout: C:/Users/USER/AppData/Roaming/DAZ 3D/Studio4/layout.dsx
    2022-06-16 14:55:22.937 [WARNING] :: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(660): sync completed successfully, 1 items succeeded, 0 items failed.
    2022-06-16 14:55:22.937 [INFO] :: Metadata update succeeded.
    2022-06-16 14:55:41.731 [DEBUG] :: Turbo Loader Open File START D:/Users/Public/Documents/My DAZ 3D Library/Scripts/RiverSoft Art/Turbo Loader/Turbo Loader Open File.dse
    2022-06-16 14:55:41.736 [DEBUG] :: Enabling morphs for asset, W4D2 4 CA 31: D:/Users/USER/Documents/DAZ 3D/Studio/My Library/Scenes/37 CAFE 2/W4D2 4 CA 31.duf
    2022-06-16 14:55:41.736 [INFO] :: Loading D:/Users/USER/Documents/DAZ 3D/Studio/My Library/Scenes/37 CAFE 2/W4D2 4 CA 31.duf
    2022-06-16 14:55:47.512 [INFO] :: Enabling Morphs...
    2022-06-16 14:55:47.513 [INFO] :: Enabling data/sugatak/Yamachan Ramen 1961/YR Hashi 1zen/Morphs/sugatak/Base/On Ramen Donburi.dsf
    2022-06-16 14:55:47.513 [INFO] ::      data/sugatak/Yamachan Ramen 1961/YR Hashi 1zen/Morphs/sugatak/Base/On Ramen Donburi.tlOff NOT FOUND.
    2022-06-16 14:55:47.514 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/sugatak/Yamachan Ramen 1961/YR Hashi 1zen/Morphs/sugatak/Base/On Ramen Donburi.dsf
    2022-06-16 14:55:47.514 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.515 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.515 [INFO] ::      data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/tilt.tlOff NOT FOUND.
    2022-06-16 14:55:47.515 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.516 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.517 [INFO] ::
    2022-06-16 14:55:47.517 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.518 [INFO] ::      data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/level.tlOff NOT FOUND.
    2022-06-16 14:55:47.518 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.519 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.519 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.520 [INFO] ::      data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/level.tlOff NOT FOUND.
    2022-06-16 14:55:47.520 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.521 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.521 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.522 [INFO] ::      data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/tilt.tlOff NOT FOUND.
    2022-06-16 14:55:47.522 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.522 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.523 [INFO] ::
    2022-06-16 14:55:47.523 [INFO] :: Enabling data/sugatak/Yamachan Ramen 1961/YR Hashi 1zen/Morphs/sugatak/Base/On Ramen Donburi.dsf
    2022-06-16 14:55:47.523 [INFO] ::      data/sugatak/Yamachan Ramen 1961/YR Hashi 1zen/Morphs/sugatak/Base/On Ramen Donburi.tlOff NOT FOUND.
    2022-06-16 14:55:47.524 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/sugatak/Yamachan Ramen 1961/YR Hashi 1zen/Morphs/sugatak/Base/On Ramen Donburi.dsf
    2022-06-16 14:55:47.524 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.524 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.525 [INFO] ::      data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/tilt.tlOff NOT FOUND.
    2022-06-16 14:55:47.525 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.526 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.526 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.527 [INFO] ::      data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/level.tlOff NOT FOUND.
    2022-06-16 14:55:47.527 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.528 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.528 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.529 [INFO] ::      data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/level.tlOff NOT FOUND.
    2022-06-16 14:55:47.529 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.530 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.530 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.531 [INFO] ::      data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/tilt.tlOff NOT FOUND.
    2022-06-16 14:55:47.531 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.531 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.531 [INFO] :: Enabling data/sugatak/Yamachan Ramen 1961/YR Hashi 1zen/Morphs/sugatak/Base/On Ramen Donburi.dsf
    2022-06-16 14:55:47.532 [INFO] ::      data/sugatak/Yamachan Ramen 1961/YR Hashi 1zen/Morphs/sugatak/Base/On Ramen Donburi.tlOff NOT FOUND.
    2022-06-16 14:55:47.533 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/sugatak/Yamachan Ramen 1961/YR Hashi 1zen/Morphs/sugatak/Base/On Ramen Donburi.dsf
    2022-06-16 14:55:47.533 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.533 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.534 [INFO] ::      data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/tilt.tlOff NOT FOUND.
    2022-06-16 14:55:47.534 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.535 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.535 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.535 [INFO] ::      data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/level.tlOff NOT FOUND.
    2022-06-16 14:55:47.536 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall3/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.537 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.537 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.538 [INFO] ::      data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/level.tlOff NOT FOUND.
    2022-06-16 14:55:47.538 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/level.dsf
    2022-06-16 14:55:47.539 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.539 [INFO] :: Enabling data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.539 [INFO] ::      data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/tilt.tlOff NOT FOUND.
    2022-06-16 14:55:47.540 [INFO] ::     Loading D:/Users/Public/Documents/My DAZ 3D Library/data/maclean/Everyday Drinks/glassTall1/Morphs/maclean/Base/tilt.dsf
    2022-06-16 14:55:47.540 [INFO] ::     Enabling Morphs...
    2022-06-16 14:55:47.540 [INFO] :: Enabling data/DAZ 3D/Genesis 3/Female/Morphs/Lyoness/LY_EveryGirl/FBM_EveryGirl02.dsf
    2022-06-16 14:55:47.541 [DEBUG] :: 0 morphs were searched for
    0 Enabled (0 failed to enable)
    0 unchanged
    0 skipped
    in 5 secs 809 msecs
    2022-06-16 14:55:47.542 [WARNING] :: Script Error: Line 407
    2022-06-16 14:55:47.542 [WARNING] :: TypeError: Result of expression 'dir.exists' [undefined] is not a function.
    2022-06-16 14:55:47.542 [WARNING] :: Stack Trace:
    <anonymous>()@D:/Users/Public/Documents/My DAZ 3D Library/data/RiverSoft Art/Common/RSTurboLoaderFunctions.dse:407
    Hi!
    Cheers!
    0 unchanged
    0 skipped
    in 5 secs 809 msecs
    kregerse said:
    Hi!
    Cheers!
    0 unchanged
    0 skipped
    in 5 secs 809 msecs
    Sorry for just seeing this.  You need to update ALL of your Turbo Loader products.  It looks like TLBU is pulling in an old data/RiverSoft Art/Common/RSTurboLoaderFunctions.dse as that function is not even called in the current version.
  • sberlinssberlins Posts: 128
    In middle of session, started getting error message shown in attached file.  Also attached partial log file.
    609 x 187 - 12K
    txt
    txt
    Log file partial 7-16-22.txt
    7K
    Daz Studio cannot find the data/RiverSoft Art/Common/RS2022HelperFunctions.dse.  Did you change the Content Manager directories?  It is trying to find the data/RiverSoft Art/Common/RS2022HelperFunctions.dse concatenated with one of the directories specified in your Content Directory Manager:
    No, I didn't change any directories at all.  I went to open a file after closing a file that I had opened with Turbo Loader Scence Configuration.  On attempting to open a character file with Turbo Loader Open, that's when i first got the error message in the picture above.  I did not change any content configurations for the content library.
    Here is my Riversoft folder.
    1431 x 731 - 282K
