Adding to Cart…
Figure Prep for Animation - Joint Constraints and IK Chains
Joint constraints. In properties tray, under motion tab/constraints. I went through my first clown model and edited the joint constraints. For rotation order, I used ZYX for vertical bones like the chest and thigh. I used X ZY for horizontal limbs like the shoulder and fingers. For the most part, I used ball joint limits or locked the bone. End bones were generally locked, like the top of the head or the tips of the fingers and toes. Hopefully, the limits to the ball joints I chose make sense. I may have set the ranges a little to large, but I am hoping exaggerated movements are OK for a toon clown. I saved the constraints to my browser hoping to be able to use the same constraints for the 2nd clown, and as a starting point for the other figures.
IK Chains. Planning on extensive use of IK chains applied to one of my custom figures in Carrara is a first for me. Hope it works out. To set up the IK chains, select the inner bone first, click the IKChain tool from the left menu, then select the target bone in the assembly room. For example, for the arms, the shoulder would eb the inner limb and the wrist/hand would be the target. The target is giant for some reason, so I reduced its scale. rename the IK chains so you remember which one goes with which limb.
Here is my clown with joint constraints applied, IK chains set, and a running pose created by moving the IK targeted feet and wrists. I am also attaching some screen shots of the joint constraint and IK chain processes.
Diomede - looking good !!!
Me - am reusing my Aiko 3 scene for my animation.
Animation is a BVH file from cgspeed. Downside is that there are 25 frames per second for over a minute of animation, may be biting off more than I can chew for the adjusting of feet, hands and arms !!
Bunyip - Yay for Aiko 3. Classic. I have confidence you can manage it. The various Carrara tutorials should be up to date for classic Aiko 3 rigging. Let us know if you get stuck and we might be able to find some vintage help resources.
** Apply Clown Joint Constraints and NLA to RingMaster **
Recall that my circus models start from a few bases, along with matching bone skeletons. Sort of like my own Genesis Male, Female, and Kid. The Fat Clown and the RingMaster are derived from the same base. Here I applied the constraints from the clown to the RingMaster and applied the same NLA clip for a running pose. Appears to be off to a good start. Something strange happened to the left eye, so I better check to see if I inadvertantly attached that eye to the skeleton instead of parenting. Overall, I'd say the saved joint constraints worked out OK. Should save a lot of time for the constraints/rigging of the other characters.
- PIC 1 - Ringmaster Figure loaded in scene. Thigh selected, notice no constraints yet in upper right properties tray.
- PIC 2 - Figure after dragging and dropping the ThighL constraint from the browser tray to the Constraint tab in the Properties Tray. See rotation order, ball joint and limits all load.
- PIC 3 - Apply same clown running pose that was saved as NLA clip to the sequencer for the RingMaster. Adopts running pose.
Stezza - that is one creepy clown. Him in the duck prop makes me think of a classic line from Thunderbolt and Lightfoot, which I can't print here.
HW - neat looking cannon scene!
Philemo - glad to see you entering! Animation looked interesting, like interpretive dance. Good music choice.
Bunyip - wow, you are way ahead of me. I haven't watched any more of Phil's tutorial since my last post, unfortunately. But the story I want to tell is now getting clear. Probably way too ambitious, but WTH.
Diomede - Thanks for the blow by blow. A lot of steps. I don't know half of what you are doing yet, but hopefully headed in that direction. :)
how good is that!
dowloaded and deboned and then reboned again on my body! thanks @diomede
that bear! lol.... some great animations happening... good luck with yours @Bunyip02
thanks for the comments on my images... mine pales into insignificance watching all you Carrara'ist works
What is the point of using Mixamo? Is it simply easier to animate with it than using Carrara?
if you don't mind handkeying the entire "Thriller" choreography go for it
Paid options for DAZ figures also exist in DAZ store but need AniMate Carrara plugin or bake to key frames in DAZ studio and save pose
Mixamo free
I own the Chriller Aniblocks though too
OK, thanks, I assume that you are talking about this. I bought the pro bundle years ago in anticipation of eventually doing animation. Maybe soon. :)
Adding a female clown.
Screengrabs attached of modeling the costume in the vertex modeler after detaching the mesh from the generic skeleton, painting the face using Carrara's 3D paint tool, posing the figure using the IK target helpers, and a test render. The hair is 3 pieces. The main hair is grown on the generic hair cap. I used the brush tool to pull the hair towards the sides. I then modeled two cylinders to grow the pigtails from. Not sure I am satisfied with the hair. My next task, and my first entry, will be trying to animate a short dance routine with the 3 clowns.
wow Ted, that's very kind of you to run down your work flow! And thans for the figures!!!
rilliant looking character (still cant type capital bee) cute and suites the part - looking forward to the animation :)
thanks Stezza, sorry to be tardy I have been up the coast :)
Thanks Ub :)
looking forward to this one - I'm sure you;ll do a good jonb - if the feet slide just crop them out :)
wonderful thanks again, I'm amazed at what a mine of information you are
thanks Bunyip02 !
terrific you are entering, your first half wip is mesmerising !!!! and thank you for that workflow!!
~ and then ~
coming along nicely - mysterious indeed :)
Update: Glitches caused by the BVH file on Aiko have been corrected. There is a bit of foot sliding but not too noticeable.
Next up to render out the animation in Carrara (probably a weekend job), then into Pinnacle Studio to add Titles, Credits etc.
~ thanx kindly
_ do'nt guess , will make any Animations but , alrite then thanx
Sorry for appearing not to acknowledge some recent comments or reply to recent issues. I wrote a long post which got boinked by the forum hiccups.
Request for Info
How do you get a keyframed animated figure to follow a motion path? I have been working on a walk cycle for my fat clown. Mixed results so far, but making progress. I see there are motion paths, but that is a different animation setting from keyframe. So I thought I would get around that by inserting a target helper, moving the target helper along the motion path, and then parenting the figure to the target helper. Instead my walking clown loses it walk cycle when parented in this way. Not sure what is going on. The alternative of keyframing each step doesn't seem correct. The dark recesses of my mind remember a walk cycle motion path tutorial, but I think that was for Dork and Posette in Poser 4. The manual (Carrara 7) did not not clear it up for me, but I could be looking in the wrong place. I got some good tips from a Carrara 5 Pro Handbook (Chapter 15) on walk cycles in general, but the example of forward movement did not use a motion path.
I use a target helper and create a path for that and parent it to it.
you can then duplicate the paths and put other things at different points along it too
For some reason, I my animation keyframes became inactive after I parented my figure to the motion path. It is a mystery.
yes they will because you changed the motion type, that's another reason to use a null object or target helper
I meant parented to the target helper.
To clarify. I inserted a target helper. I set its motion to the path. I parented my figure to the target helper. Is that the wrong way to do it?
well that should work
I have no ideas, I have parented cars to target helpers on paths, animated the wheels and people parented to and sitting in them, maybe it's a setting somewhere?
Hi,
try this, dont parent figure to the target helper
instead
take your figure and group it to itself, add a track modifier to the group.
choose target helper as the object to track in xyz
should work
ps can't add a modifier to a figure i don't think - hence the grouping
Thanks for the suggestions, Wendy and Headwax. I bet the second grouping, or 'supergroup' is what I was missing. That is how the newer Daz figures are configured, an animaiton group within a larger supergroup. Fingers crossed.
