My screen got lost (no viewport and tabs)
Mescalino
DAZ started and i got the bug report.
I tried to restart Daz Studio and got the screen in my image.
Restarted my computer and still got this image.
Anyone any idea what could have happened and how to solve it. (Preferbly without reinstalling DAZ Studio)
Thanks in Advance
What happens if you go to Windows > Style and select a Style?
I tried all 3 styles, it changes the color but not the layout.
EDIT:
Ok i tried change layout and now im back with a default layout. I can go from there...
Thanks
Does the log give any information?
Not much except:
2022-05-16 19:23:07.878 [INFO] Iray :: Loading Plugins...
2022-05-16 19:23:07.879 Iray [INFO] - PLUG:PLUGIN :: 0.0 PLUG plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\aix.dll".
2022-05-16 19:23:07.880 Iray [INFO] - PLUG:PLUGIN :: 0.0 PLUG plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avcodec-58.dll".
2022-05-16 19:23:07.880 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - PLUG:PLUGIN :: 0.0 PLUG plug error: Library C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avcodec-58.dll: symbol "mi_plugin_factory" not found.
2022-05-16 19:23:07.882 Iray [INFO] - PLUG:PLUGIN :: 0.0 PLUG plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avfilter-7.dll".
2022-05-16 19:23:07.882 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - PLUG:PLUGIN :: 0.0 PLUG plug error: Library C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avfilter-7.dll: symbol "mi_plugin_factory" not found.
2022-05-16 19:23:07.884 Iray [INFO] - PLUG:PLUGIN :: 0.0 PLUG plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avformat-58.dll".
2022-05-16 19:23:07.884 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - PLUG:PLUGIN :: 0.0 PLUG plug error: Library C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avformat-58.dll: symbol "mi_plugin_factory" not found.
2022-05-16 19:23:07.884 Iray [INFO] - PLUG:PLUGIN :: 0.0 PLUG plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avutil-56.dll".
2022-05-16 19:23:07.885 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - PLUG:PLUGIN :: 0.0 PLUG plug error: Library C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avutil-56.dll: symbol "mi_plugin_factory" not found.
2022-05-16 19:23:07.888 Iray [INFO] - PLUG:PLUGIN :: 0.0 PLUG plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\axf_importer.dll".
2022-05-16 19:23:07.888 Iray [INFO] - PLUG:PLUGIN :: 0.0 PLUG plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\AxFDecoding.1.8.1.dll".
2022-05-16 19:23:07.888 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - PLUG:PLUGIN :: 0.0 PLUG plug error: Library C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\AxFDecoding.1.8.1.dll: symbol "mi_plugin_factory" not found.
2022-05-16 19:23:07.889 Iray [INFO] - PLUG:PLUGIN :: 0.0 PLUG plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\blend_render.dll".
2022-05-16 19:23:07.889 Iray [INFO] - PLUG:PLUGIN :: 0.0 PLUG plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\cb_importer.dll".
Yes, Style chnages the look of the UI elements - Layout is the one that controls which elements are shown.
