My screen got lost (no viewport and tabs)
DAZ started and i got the bug report.
I tried to restart Daz Studio and got the screen in my image.
Restarted my computer and still got this image.
Anyone any idea what could have happened and how to solve it. (Preferbly without reinstalling DAZ Studio)
Thanks in Advance
  • felisfelis Posts: 6,527
    What happens if you go to Windows > Style and select a Style?
  • MescalinoMescalino Posts: 436
    edited May 2022
    I tried all 3 styles,  it changes the color but not the layout.
    EDIT:
    Ok i tried change layout and now im back with a default layout. I can go from there...
    Thanks
    Post edited by Mescalino on
    Does the log give any information?
    Not much except:
    2022-05-16 19:23:07.878 [INFO] Iray :: Loading Plugins...
    2022-05-16 19:23:07.879 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\aix.dll".
    2022-05-16 19:23:07.880 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avcodec-58.dll".
    2022-05-16 19:23:07.880 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avcodec-58.dll: symbol "mi_plugin_factory" not found.
    2022-05-16 19:23:07.882 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avfilter-7.dll".
    2022-05-16 19:23:07.882 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avfilter-7.dll: symbol "mi_plugin_factory" not found.
    2022-05-16 19:23:07.884 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avformat-58.dll".
    2022-05-16 19:23:07.884 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avformat-58.dll: symbol "mi_plugin_factory" not found.
    2022-05-16 19:23:07.884 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avutil-56.dll".
    2022-05-16 19:23:07.885 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\avutil-56.dll: symbol "mi_plugin_factory" not found.
    2022-05-16 19:23:07.888 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\axf_importer.dll".
    2022-05-16 19:23:07.888 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\AxFDecoding.1.8.1.dll".
    2022-05-16 19:23:07.888 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\AxFDecoding.1.8.1.dll: symbol "mi_plugin_factory" not found.
    2022-05-16 19:23:07.889 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\blend_render.dll".
    2022-05-16 19:23:07.889 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "C:\Program Files\DAZ 3D\DAZStudio4\libs\iray\cb_importer.dll".
  • Richard HaseltineRichard Haseltine Posts: 111,472
    EDIT:
    Thanks
    Yes, Style chnages the look of the UI elements - Layout is the one that controls which elements are shown.
