The Mac FAQ
Adding to Cart…
Thanks for the info and links. No, I haven't recently purchased an Apple product nor an Apple One account. But I did recently go into the Apple Store on line and look.
@inquire Apparently Apple sends out that message fairly often and they probably detected your Mac visiting their online store. Apple just wants to make sure they have a trusted phone number associated with your Apple ID account. Apple can then text you a security code to enter when it detects you are trying to login on a device you haven't used before, or had not logged-in to Apple online sites in a long time. For example, if I try to login to my AppleID or iCloud.com from my Mac, I will get a text notification on my iPhone asking if I want to "allow" the device, and if I click allow, it will then give me a verification code to enter, since i'm using 2-factor authentication.
If you don't want to click the link in that pop-up message on your Mac, then you should just login directly to your Apple ID account and check your phone number here:
Apple ID:
https://appleid.apple.com/
Just look in "Sign-in and Security" (on left) and then the "Account Security" section for a list of your trusted devices.
Look in "Personal Info" (on left) for the "Reachable At" section for your AppleID email address, and there is another section for your phone number.
If you prefer, you can also use a mobile number as your Apple ID (instead of your Apple email address), see this article...
Use your mobile phone number as your Apple ID
https://support.apple.com/en-us/HT207944
A few more helpful links...
Security and your Apple ID
https://support.apple.com/en-us/HT201303
Two-factor authentication for Apple ID
https://support.apple.com/en-us/HT204915
@robertswww: Thanks for all the info and all the links.
Probably around 30+ mins before I give up and force quit.
11 G8/8.1 characters in the scene, no scenery yet.
Haven't checked CPU activity tbh, I'll have a look next time.
thank you, I'll try that
Just checked...
10 minutes after quitting DS, 101.3% shows on the CPU. Memory usage sitting at 21gb. 'Application Not Responding' is displayed next to Daz.
Another 10 minutes later, CPU is almost identical and memory usage is at 20.5gb
I don't know what the following are but I assume they relate to failed attempts to close the application...
It reports 60 'hangups', a number that increase by 1 every time it checks (5 second intervals). It also reports more than 14,000,000 'faults'.
Hi everyone,
I have a quick question to ask folks who have some knowledge and / or experience with Daz3D on new Mac M1.
I work on a mid-2015 MacBook Pro, with the following specs:
I am considering upgrading to a new 16 inch M1 Macbook Pro. Do you have any advice regarding the specs that would be best for Daz3D? That will be much appreciated.
Thanks in advance!
MF
@MultiverseFantasies On the M1 Macbook Pro, your Daz will render via the CPU and RAM, so get as much RAM as you can afford...
With the M1 Pro you can get up to 32GB and with the M1 Max you can get up to 64GB
If you also use your MBP for video editing with Apple ProRes, then the M1 Max has 2 ProRes engines, as the M1 Max chip has double the memory bandwidth of the M1 Pro chip.
For Daz content storage: I would recommend keeping Daz Studio and Daz Install Manager (DIM) on your internal drive, and then map all your Daz content to an External drive via one of the Thunderbolt 4 (USB-C) ports.
NOTE: M2 chips will begin shipping in Apple products this year.
@robertswww Thank you for your detailed answer!
I heard that M2 Macbook Pros are likely to ship in 2023 (see https://www.macrumors.com/2022/03/20/gurman-macbook-air-delayed-to-second-half-of-2022/), so I might get an M1 Max with 64 GB of RAM.
That rumor is probably correct as it looks like the computers with M2 chips that may ship this year are the updated Macbook Air (M2), the Mac Mini (with possible M2 and M2 Pro chip options) and the Mac Pro desktop (M2 Ultra?). If you are planning to hang onto your upcoming Macbook Pro for a long time, then the M1 Max with 64GB should serve you well. But, if you won't hold it that long, or plan to upgrade, a M1 Pro with 32GB should suffice.
This tip works very well, Daz shuts down almost instantly if I do this. Takes a while to open that new blank but at least it closes now.
Thanks for this tip!
Any word about how the Mac Studio runs DAZ Studio? It seems that the M1 Ultra combines GPU and CPU. What will that do to rendering in iRay? If I do get the Mac Studio, it would be to run DAZ Studio, so I'd really like more info on that.
It doesn't really "combine" GPU and CPU anymore than a regualr M1. It has more of both, and can access more RAM, but it'll stll only be using CPUs for rendering iRay. It'll render using iRay faster than a less-powerful M1, but still nowhere near as fast as a PC with a decent video card.
-- Walt
With all the videos on youtube about how Macs perform and with what applications, I should think someone would focus in on DAZ Studio.
I just set up my new Mac|Studio Max with 10-core CPU, and 32-core GPU. It's a speed demon with Daz|Studio 4.20. It can actual process iRAY view, something that my old iMac 27 5K failed at. No the same speed as my Dell RTX -3070, but workable. Quick on full renders too. No complaints!
About how does the rendering speed compare to the Dell RTX-3070? And the Dell has an nVidia Graphics Card, right? If you do get a chance to make some comparisons, please let me know. But thanks for this info also.
Is filament available on Mac yet?
If so, how do you access it?
Sounds great, colour me jealous!
When you have a moment, I'd love to hear a comparison between your Dell and your Mac with a 3Delight render.
-- Walt
Filament is not yet available directly on a Mac, that's theoritically going to be available in DAZ Studio 5 (we were told it was working in the pre-alpha). For now, you can use a Windows partition on a Mac using Boot Camp, VM Fusion, Parallels, etc.
-- Walt Sterdan
Watch the change log http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log and, when a new version is released, check for the Highlights thread in the Daz Studio forum. If Filament isn't listed in at least one of those it isn't yet available.
Hi there Mac Gurus, I could use a bit of advice. Currently using DS 4.9 on a (late 2015) i5 quad/8Gb RAM iMac. I'm about to get a new monster rig for CPU rendering this week Long story short- how can I be sure this version works with the newest OSX? I suppose I could run my current OS El Capitan on the new rig?
Find a bit of context here, MacPro specs I'm considering and the PC alternative, thank you!
First, the Mac Pro should be compatible unless it's very old:
https://www.macrumors.com/2021/06/07/macos-monterey-compatibility/
Are you purchasing an older, used machine, or a new or Apple-refurbished machine? I'm just curious, since Apple's prices for even a refurbished Mac Pro are higher than getting a much more powerful Mac Studio with more cores and RAM. If the prices are comparable, and you don't have any important software that's incompatible with the M1 chipset, I'd lean towards the M1. Even my m1 iMac is considerable faster than my Intels, and DAZ has stated that they're workiing making DAZ Studio Apple Silicon-native (not promised, but working on it).
-- Walt
Tks Walt, it's a brand new one:
I don't want to upgrade my DS 4.9 version if I can avoid it, which is why I kinda skipped the thought of getting a M1 processor. Also I use audio hardware/software that I think will not survive a transfer to the new tech...but that ProMac is insanely expensive lol.
Ah, right, my apologies, I totally missed that you were hoping to still run DA 4.9 and instead focused on the machine/OS. Obviously time for a second cup of coffee.
Agreed on the Mac Pro's price, especially when compared to the new machines.
-- Walt Sterdan
The 20-core M1 Ultra is impressive, but the only Mac that is customizable to atleast a significant degree is the Mac Pro, if I got it about right...and it can host 1.5 TB RAM hehe.
I'd have to mortgage my house for that much RAM.
You'd need a 24- or 28-core machine to install that much RAM, though.
I'm sure you'll be happy with either.
-- Walt
At least I'd know I'm grabbing one of the last Intel- based machines on this planet for a very long time. There might be another ice age coming up...
I just ordered a MacPro 16core/48GbRAM (4 weeks delivery). I intend to run DS 4.9 on it but testing on my Macbook reveals that Monterey and 4.9 don't play well together, greyed out file options, can't browse for textures, splash screen loads upside down etc. (Yup I can drop scenes from Finder and render.) Apple refuses to sell anything but the latest OS, so my question is:
Can I just clone the entire IMac I'm currently working on, OS (El Capitan), software and content? Or can someone recommend a network solution that would let me utilize both 4.9 and the Mac Pro CPU?
Thanks!
@Sven Dullah You may want to consider keeping Mac OSX Monterey on one drive or partition to run the latest apps and the forthcoming Daz Studio 5. Then install Max OSX El Capitan on another dirve or partion to run DS 4.9. Basically, make a dual-boot Mac. If you do decide to wipe Mac OSX Monterey, make sure you make a Recovery disk first, in case you ever need to go back to the factory install.
As for cloning, Apple has the Migration Assistant (https://support.apple.com/en-us/HT204350). However, cloning your iMac might not work, as the build of OSX that ships with each Mac is somewhat tailored to that specific hardware model. It's probably better to download Mac OSX El Capitan as a sepearate installer that can configure itself to your new Mac hardware.
You should be able to download Mac OSX El Capitan via the link on this page... Scroll down to this section, "How to download Sierra, El Capitan or Yosemite".
https://www.macworld.com/article/671911/how-to-get-old-macos-download-big-sur-catalina-mojave-and-more.html
