• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Blender Shader Question...
Write IdeaWrite Idea Posts: 490
April 2022 in Blender Discussion
I recently began working with shaders in Blender, so I'm not that well versed in how to use them.  I was wondering how I might be able to make one part of the object one shader and the other part another shader.  In the image below, I want to make the flat part a wood and the more ornate part golden.  I know I can just paint it, but that would be too long.
Thank you in advance for any suggestions...
  • PadonePadone Posts: 4,315
    April 2022 edited April 2022
    You can drive a mix with the texture, simple as that.
    766 x 177 - 26K
    Post edited by Padone on April 2022
  • RL_MediaRL_Media Posts: 339
    April 2022
    If there is good seperation of the two zones polygonwise, you can asign different surfaces. Tab into edit, select the polygons you want to assign. Go into material properties, add a material slot, click new material, name it, then hit the asign buttom. Then select > inverse and do it again for the other materail slot. Tab out of edit, highlight the material slot that used to be on it if there was one and click remove material slot. Finito.
  • Write IdeaWrite Idea Posts: 490
    The problem is I'm using a multires modifier to sculpt the ornate parts on.  So, I can't create a new material zone.
    And I've looked into mix nodes with (I believe is called a) denoise nose, but the denoise node isn't precise enough for the ornate parts of the mesh.
    Thank you for the suggestions, though!
    Post edited by Write Idea on April 2022
  • SDevSDev Posts: 158
    April 2022
    Applying the multires modifier and setting the mat zone isn't an option?
    April 2022
    Below is the actual mesh I'm working on.  The ornate parts are done with an alpha sculpting brush on a multires modifier (4 times).  Highlighting all of those face would take forever (and I have to do twelve individual chest pieces).  I was hoping to use some special node trick to make the basic parts leather and the ornate parts gold/silver/metalish; bake it into a diffuse map/normal map/etc, and keep it a low poly mesh to use in DAZ.
    1000 x 800 - 447K
    1000 x 800 - 593K
    Hmm, this might help ... link to github and bm is shown below the vid:
    Another one which I'm using frequently when editing my characters in Blender:
    ring select, then double click an inner part to select everything to the boundaries.
    HTH!
    PS: I would keep the low poly as a copy, then do the multires stuff, apply the modifier, bake a displacement and use it for the low poly mode. Texturing maybe via substance/quixel or via pbr painter directly inside blender... Jaynam has a very simple way to bake the displacement map...
    (or you can use his free jbake tools and do it by some clicks^^)
    https://github.com/jayanam/jbake-tools
    Post edited by SDev on April 2022
    April 2022
    Perfect Select and Power Select look like great tools to look into!  Thank you for suggesting them!
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,336
    April 2022
    For me, it's always been better to model the ornamentation separately, and then do this.
  • Krys KryngleKrys Kryngle Posts: 319
    April 2022
    You could try baking a displacement map using the 'bake from multires' option.  This would give you a black and white height map that you could edit in a photo editor.  Anything black should be the low poly base and anything gray to white would be the high def details.  Change the gray/white to pure white using an automatic selection tool, levels adjust, or threshold (affinity photo).  Now you have a mask to mix two materials on the same mesh.  I didn't try it, just tossing out an idea.
    April 2022
    Your random idea just saved me so much time!  It worked out perfectly!
    Thank you so so much!
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
