Breast Utilities 2 for Genesis 8 and 8.1 Females [Commercial]
2»
  • Okay, I'll be the crass SOB and ask an obvious question: Do you plan on making a similar one for the Buttocks? wink
  • Sorry guys, I am new. How do I apply to the whole body like others mentioned? Do I do it under surfaces for skin?
  • SotoSoto Posts: 1,451
    Hi again!
    After a lot of work, I expanded the shader into something much bigger. I am still giving the final touches, but if you would like to beta test it and give ideas and feedback, please, PM me your mail! :D
    Breast Utilities 2 was born from the need to fix the UV stretching on the breasts. Is this something that also troubles you enough about glutes to require a similar product? Because I'm all for it if there is interest in something like that.
    Thanks!
  • GatorGator Posts: 1,320
    Hellboy said:
    cridgit said:
    Would I be able to use the shader on non-G8F characters or does it depende on the G8F/G8.1F UV's for example?
    it's a shader preset you can apply to whatever you want regardless of UVs. :)
    LOL, wish I read this thread earlier. The included tile able maps are EXCELLENT, I used them and Photoshop to edit the maps of a Genesis 3 figure. I converted the G3's skin shaders to G8. I just assumed it wouldn't work. I'll have to give it a try. Question: is it possible to get nipple bump and normal TIFs on a transparent background? Used one and it's good but had to delete out the surrounding part of the image to use.
  • Is there no way to change the color of the areola/nipple independently of the rest of the shell?
  • leewhite82leewhite82 Posts: 0
    edited July 2023
    I had the same question. I dont want teh areola to be the same skin tone as teh breast. I am looking to change the areola tone but it isnt clear if this product does that...
  • Hi soto.
    are you going to release Breast Utilities 3 for genesis 9?
  • The product doesn't work on Genesis 8 Characters in Daz 6. Looks like a script issue, it won't copy the character's materials to the shell, it just stays white. Anyone else has the same issue?
  • LeanaLeana Posts: 13,609
    A lot of scripts need to be updated to work in DS6, both the scripting engine and the SDK changed.
    I know, that's why I left a message here to let the author know if he's/she's unaware.
    I messaged other creators too and from what they've told me thankfully these script issues usually need just a small fix.
    I wonder if a possible workaround is if we setup the geoshell in Daz 4 and save the character preset there and load it in Daz 6.
    I don't think a character preset would save the geoshell, you would likely need to save either a scene subset, or a material preset for the shell. Those should indeed work in DS6 afterwards.
    A Persona Preset or a Wearables Preset  would loasd a Geoemtry Shell.
