UltraSceneryXT - large terrain/landscape generator
1568101142
  • This is my first time posting on the forum, but I wanted to let Howie have a heads up.  I just submitted a ticket because fully installing UltraSceneryXT causes my DazStudio to quit. This is a copy of what I put in the ticket.
    "When I try to install UltraSceneryXT I have a problem.  When using the Install Manager, DazStudio will quit if UltraSceneryXT for DAZ Studio 4.5+ (Mac 64-bit) is installed.  If I uninstall that with the Manager, then DazStudio opens as normal.  The UltraSceneryXT - Expansive Landscape System part installs without problem.  Then I tried manually downloading the zip files from my product library to see if I could install that way. The  84924_UltraSceneryXTforDAZStudio45Mac64bit_1.0.0.16_ds.zip unzips into an application that I think is supposed to install the part that is causing problems through the Install Manager, but when I try to run the application I get a message that I don't have permission to open the application, even though it's my computer and I am the administrator.  Trying to change permissions has no affect.  I know Howie develops on a Mac, so this should be working for my computer as well.  I have the original UltraScenery and never had a problem with it. (Also, this originally happened with DazStudio 4.15 but then I upgraded to DazStudio 4.20 and still had the problem, so I don't think it's the version of DazStudio that is any problem.)"
    I really hope they can find a solution soon, because I was really excited for this product.  I love Howie's UltraScenery which I use for all my rendrs that need a complex landscape.
  • DaventakiDaventaki Posts: 1,624
    My first go with USXT, love it!
    I am having issues with trees being in the water though.  This is one of the presets but if I change settings and create my own look I end up with trees in the water.  I haven't figured out how to stop it from doing that.
    1500 x 1021 - 2M
  • HowieFarkesHowieFarkes Posts: 628
    Set the Min Altitude (m) in the Biome section to the same value as the water level - so probably want it set to 0 (zero)
  • barbultbarbult Posts: 27,410
    richardandtracy said:
    I wonder if I can ask for some advice. There are 5 files on the download page. I'm running Win7 and can only do manual download due to the machine being internet expired and Install Manager doesn't work on an Android Tablet (my internet machine). Three of the files are available for manual download:
    1. 4924_UltraSceneryXTforDAZStudio45Mac64bit_1.0.0.16_ds.zip
    2. 84924_UltraSceneryXTforDAZStudio45Win64bit_1.0.0.16_ds.exe
    3. IM00084924-01_UltraSceneryXTExpansiveLandscapeSystem.zip
    Item 1 is Mac only, so, can I ask are 2 & 3 the complete installation, or will I need to ask customer support help to download the file below like I did with the US accelerator?
    • IM00084924-02_UltraSceneryXTforDAZStudio45Win64bit.zip
    Many thanks in advance for your advice.
    Regards,
    Richard
    I now think my original guess that 1 and 2 were the plugin was wrong. The plugin and manual are in IM00084924-02_UltraSceneryXTforDAZStudio45Win64bit.zip. I don't understand why 1 and 2 do not have standard IM000 prefixes and why the Windows file is an exe, not a zip file. They must be the rest of the content, but exe is not a DIM file type as far as I know. It is puzzling. Does DIM download different files than what the manual installation from the Product Library offers?
  • TugpsxTugpsx Posts: 909
    edited March 2022
    This is a great prduct and does work in Daz Octane plugin. You will have to adjust the water to somewhere near Specular Material IOR 1.5 Film IOR 1.45 Opacity 0.89 maybe add displacement if needed. These settings were provided by LittleFisky.
    1059 x 854 - 136K
    1068 x 851 - 175K
    1066 x 852 - 142K
    Post edited by Tugpsx on
    Those Octane renders look very nice.
    edited March 2022
    Thanks, they are fast and even with a 1024x1024 terrain the drone flies great.
    BTW those images are XT only I didnt mix any foreground and background.
    I like the transparency of the water. It is interesting to see the ground underneath. I want to see your drone animation.
  • jag11jag11 Posts: 885
    edited March 2022
    Mixed forest.
    1280 x 720 - 1M
    Post edited by jag11 on
    Regards,
    Richard
    Well, I used the .exe (2) and did my usual on the zip (3) and it worked, so I am one happy bunny. A render took 2hrs:47mins in my GTX1060, just great. From Task Manager, it should be possible to have an US foreground and a character or two in the machine's 24Gb ram, though the second character may prevent the GPU rendering. I shall try.
    USXT is an absolute masterclass in minimising memory usage for the maximum effect. Very impressed.
  • NathNath Posts: 3,048
    Greybro said:
    Nath said:
    Nothing clickable - I'll give it another deinstall/reinstall.
    I needed to close Daz Studio after install to find the option to open the Tab under Windows/Panels. Then start the steps on page 6 (for me) of the manual.
    Rebooting (regular overnight switch-off) solved the issue - should have tried that yesterday LOL.
    Here's a quick test.
    2500 x 893 - 4M
  • alexhcowleyalexhcowley Posts: 2,408
    Regards,
    Richard
    The .exe file installs the plug-in program into the appropriate part of the Window's system directory. The .zip contains the .duf and png files for the DS content library and the all important .PDF manual.
    I'm not a Mac user so I can't speculate as to exactly how the installer for Macs works.
    Cheers,
    Alex
    Regards,
    Richard
    Cheers,
    Alex
    When you say the content is in "the zip", do you mean  IM00084924-01_UltraSceneryXTExpansiveLandscapeSystem.zip or IM00084924-02_UltraSceneryXTforDAZStudio45Win64bit.zip?
    Regards,
    Richard
    Cheers,
    Alex
     Barbult,
    Sorry, I should have been a little more precise;
    Cheers,
    Alex.
  • AnEye4ArtAnEye4Art Posts: 867
    edited March 2022
    Quick tests.
    1000 x 562 - 818K
    1280 x 720 - 2M
    Post edited by AnEye4Art on
  • MartialMartial Posts: 431
    edited March 2022
    Hello
    For now i didn't success with the product Maybe i have an installation problem.I have acces to the  interface pane But i cannot find , for example , the presets ,Where can i find it ?
    i have installed
    My main DAZStudio exe is in D:\DAZStudio4 64 bits where 84924_UltraSceneryXTforDAZStudio45Win64bit_1.0.0.16_ds.exe have been installed by defaut
    I have many contents installed in E:\ DAZStudio Library\My library sur E and normally i can use it , as i did many time  and i have manually installed there the content of IM00084924-01_UltraSceneryXTExpansiveLandscapeSystem.zip
    AND finally using the parameters of the pane interface  it seems a terrain was generated but impossible to render the scene (see capture screen)
    1435 x 952 - 329K
    1710 x 1148 - 539K
    Post edited by Martial on
  • Hi everybody
    The biome never appears... I try all the presets (terrain and water are OK, but no biome).
    I dont understand...
    940 x 160 - 41K
    550 x 422 - 345K
    943 x 397 - 97K
  • rochard.frantz said:
    Hi everybody
    It is only visible when making a real render. Not in Iray Preview mode!
  • davesodaveso Posts: 8,225
    My first render using XT ... I like it although a bit long to render, I'm impatient, but considering the result I quess not too bad. 21 minutes 16 seconds
    One important TIP that was given somehwere up above, YOU NEED TO SET BIOME MIN ALTITUDE TO 0 OR HIGHER, otherwise, the trees will be in the water. I see a lot of expreimentation here. So many possibilities.
    I like the fact you can change parameters, hit render, and the changes are applied.
    CAMERA POSITIONING. This is huge scenery so it takes a lot of scrolling to bring the scenery into a decent camera range.  This is camera position Z=15,000, Y=3100, X= -6500. I imagine this would change when a USC terrain is used however. Any advice on camera positioning?
    IMAGES: biome min alt 0, 2nd image biome min alt 5.   huge difference
    1500 x 1125 - 3M
    1500 x 1125 - 4M
  • GreybroGreybro Posts: 2,703
    Got a stunner after letting this work a while.
    Stunner
    The huge scenery does take a lot of scrolling but I guess it's a good problem to have, though, considering ultrascenery was not big enough for huge sceneries. But I wonder how others deal with finding a good spot to scroll to; I sometimes load a small prop or character that I can position in place and "jump" to that spot.
  • Peter WadePeter Wade Posts: 1,696
    I've bought this and I've tried several times but I can't get it to render an image. I've created the terrain, set the save location, applied a preset, updated the maps and set instance optimisation to memory. When I try to render I get a box saying UltraSceneryXT is doing something, then I get a box saying. Error during rendering. I cancel this and the render window appears with nothing in it. After I close this the Studio interface is working, I can move the camera and change parameters but if I try to render again it says the renderer is already in use. The only way to get out of this is to exit Studio and start it again.
    Maybe my computer is under-powered. I've got a 6 core  i7 running at 3.47 GHz with 12GB Memory and a GTX 1050ti graphics card with 4GB video RAM, 64 bit Windows 10 Pro, Daz Studio 4.20. Is anyone running UltraScenety XT on anything like this?
  • DoctorJellybeanDoctorJellybean Posts: 10,080
    Try setting instance optimisation to Auto or Speed.
    The first time I tried it was set to auto because I forgot to change it. The PDF that comes with this says set it to memory. Setting it to speed is almost certain to cause problems due to the number of instances used.
  • nabob21nabob21 Posts: 1,058
    edited March 2022
    Hello,
    I seem to be having issues with UltraSceneryXT as well. The interface pane doesn't look anything like the images shown above and I get error message when I try to open a preset. I have attached screen captures of the interface screen and the error message as well as my log file. Hopefully someone can help me with this.
    Editeed to re-attach the log file.
    348 x 327 - 17K
    509 x 189 - 17K
    txt
    txt
    log.txt
    51K
    Post edited by nabob21 on
    nabob21 said:
    Hello,
    Have you selected New UltrasceneryXT Terrain off the create menu first?  Once this is done, the terrain should appear in the scene pane. Select this and all the options should appear in the USXT pane.
    Cheers,
    Alex.
    Hi alexhcowley,
    I did try that but it didn't work initially. However, I have since done a re-install and it now appears to be working. I must have had a corrupt install when I did it the first time. Thanks for you help though. It is appreciated.
  • bohemian3bohemian3 Posts: 1,035
    edited March 2022
    Great product - I look forward to seeing it evolve.  This product with VDP clouds finally allows me to create entire large scenes in DAZ without relying on stock photos for dramatic skys and vistas.  And will follow the camera preciesely.  Here's a quick kick of the wheels - I look forward to deeper understanding of the product.
    1080 x 1350 - 2M
    Post edited by bohemian3 on
    edited March 2022
    Hiya - Eye4Art - I always keep my primary model at 0,0 along with the camera - I move all large props and scenary around the model, not vice versa.  With a large terrain, I find it easier to rotate the terrain on y around my model to find a visually interesting spot to use.  Also I use my auxilizary viewport extensively on top view to move things around (especially cloud groups) kinda like a map locator in a game.  Be sure to lock things you don't want to move, also.  And groups are your friend.
  • TotteTotte Posts: 15,082
    edited March 2022
    I've also been playing with this new toy (at least as much as time permits).
    The second the terrain is based on a terrain heightmap generated with World Creator and imported into heigjtmap, and some noise added to it.
    1200 x 511 - 433K
    1200 x 510 - 991K
    Post edited by Totte on
