• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Texture Painting Problem
Gemini QueenGemini Queen Posts: 263
December 2021 in Blender Discussion
I'm following the tutorial by Blender Guru and everything is going great so far. However, I've hit a snag on step/video 8. He's painting in texture mode and he's able to pain directly onto the donut. However, when I attemp to click on the donut on the right hand side to pain on it like he does, it's for some reason posting to the underside of the donut like it's upside down or something? I'll see it come up on the map and it's really weird. I did back track to try and figure out what I did wrong, but I can't find it and I'd like to be able to follow the tutorial as closely as possible. Could someone explain what I did wrong?
Picture 1 - What he's doing in the video
Picture 2 - What I'm getting
  • benniewoodellbenniewoodell Posts: 1,999
    December 2021
    It's been so long since I've done this tutorial, I was thinking of redoing it now that he has a 3.0 version. But just looking at the two photos I'm seeing the photo on the left has icing selected, and the one on the right has the view for icing turned off and the donut is selected. Not sure if that will solve your problem, but it's the only thing I can see on here that looks like it could be the case.
    If that didn't help, when I did the tutorial series, I ran into a number of problems as well and every single time I found the answer in the comment section of the video. It seems the sticky spots are pretty universal and there's always someone that points out what the issue is.
  • stem_athomestem_athome Posts: 526
    December 2021
    Gemini Queen said:
    ............. it's for some reason posting to the underside of the donut like it's upside down or something?
    Hi,
    Sounds like the model has inverted normals (polygons/faces pointing in the wrong direction, which will make painting on the mesh project to the back faces).
    In the 3d viewport, press "Tab" key (edit mode). Then "Alt+N" (which brings up the "normals" menu). Select "Recalculate Outside"
  • Gemini QueenGemini Queen Posts: 263
    December 2021
    benniewoodell - You were absolutely right. The first like 3 comments had the answer that I was looking for, so it worked out well. As for the ones I had selected, I incorrectly labled them. I hadn't even noticed that till you mentioned something.
    stem_athome - It was inverted as all get out, thank you for pointing that out for me! I couldn't figure out what inverted was or how it got that way, but I was able to fix it eventually and moved along with the other stuff that I needed to do.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
