Help with genesis 8 and 8.1 tear showing black line artifact ?
in The Commons
Can anyone help with the tear on Genesis 8 and 8.1 showing black line all around the eye
sorry not seen that try deleting and re loading one from the genesis base character, gen 8 does not have a tear does it?
Black lines are usually caused by Z-fighting when your figure is too far from 0,0,0. You can fix it by setting Instance Optimization to Memory. Not sure if that's the case here, since "black line" isn't all that descriptive. If changing your Instance Optimization doesn't fix it, post a screenshot.
Can also happen if you use geoshells, even if the opacity is zero for the eye-related surfaces.
Disable the appropriae parts of the geoshell in parameters instead of making them invisible in the surface tab.
Not sure what i did but I have seemed to have sorted it out thanks :)
