Help with genesis 8 and 8.1 tear showing black line artifact ?
Can anyone help  with the tear on Genesis 8 and 8.1  showing black line all around the eye
  • MoogooMoogoo Posts: 136
    sorry not seen that try deleting and re loading one from the genesis base character, gen 8 does not have a tear does it?
  • margravemargrave Posts: 1,822
    Black lines are usually caused by Z-fighting when your figure is too far from 0,0,0. You can fix it by setting Instance Optimization to Memory. Not sure if that's the case here, since "black line" isn't all that descriptive. If changing your Instance Optimization doesn't fix it, post a screenshot.
  • HylasHylas Posts: 5,344
    edited December 2021
    Can also happen if you use geoshells, even if the opacity is zero for the eye-related surfaces.
    Disable the appropriae parts of the geoshell in parameters instead of making them invisible in the surface tab.
    Post edited by Hylas on
  •  Not sure  what i did but I have seemed to have sorted it out thanks :)
