Fitting Michael/Victoria 2 to Genesis/Genesis 2?
FMM_UWF_6b886030dbFMM_UWF_6b886030db Posts: 24
So I read up on how to fit Gen3 and Gen4 to Genesis 2, but I haven't found anywhere how to fit the classic Gen2 clothes to Genesis and Genesis 2.
So how would it go?
  • FSMCDesignsFSMCDesigns Posts: 12,855
    I doubt it is supported since it is so old. You could try the transfer utility. Getting gen 3 and gen 4 support was a miracle in itself when you actually think about how things were before genesis and that you are working with digital mesh.
  • almahiedraalmahiedra Posts: 1,374
    You need XD4 (crossdresser 4) + M4 and V4 licenses to convert clothes from Generation 2 to Generation 4. XD4 is free but licenses need money.
  • HavosHavos Posts: 5,685
    edited November 2014
    I have done this. I used Wardrobe Wizard to convert the M2/V2 stuff to M3/V3, and then autofit after that. The result may not be perfect, but it did work. Using cross dresser, as gilikshe said, or clothing convertor (http://www.daz3d.com/clothes-converter-4-0) will also do the tricky bit of getting the clothes from M2/V2 to another shape.
    Post edited by Havos on
