Low quality backgrounds
So I am in need of backdrops. Something to look out a window and see besides a sky that doesn't have ny ground. every HDRI I have is grainy and maybe about looks to be about 1K at most. I have no idea what to do with them I have to think I am doing something wrong.
  • solissolis Posts: 124
    Besides downloading higher HDR sizes (16K and above) at https://polyhaven.com/hdris (which can potentially bog your scene down due to large file size) you could try making a simple primitive (plane or flattened cube) to put outside your window, search for & add a suitable image to it.
  • margravemargrave Posts: 1,822
    Polyhaven HDRIs come in multiple sizes, as low as 1K.
  • NorthOf45NorthOf45 Posts: 5,814
    Check your Iray advanced render settings for texture compression. The defaults are quite low. Bump them up to 4096/8192 (or higher if you've got the memory).
