• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Parts of objects fall off in Marvelous Designer simulating
acdum1857acdum1857 Posts: 105
October 2021 edited October 2021 in Blender Discussion
I exported the clothes as obj in blender, and simulated them in MD, then the clips fall off.
(This bra is not made in MD, it is a Daz outfit.)
Among the UV islands, those that do not have a vertex connection to the main island fall off. (in this case clips)
This 'fall off' problem occurs with all obj clothes, and also occurs with Blender simulations.
(But I use MD because blender simulation gives bad results.)
So, what I've tried to solve the fall off is :
1) Before exporting, separate only the clips, then join it after MD simulation.
However, since this changes the UV, the existing texture does not match.
2) After MD simulation, only the clips that have fallen off move to their original positions.
But this is too hard as it has to be done every time it is simulated.
Any other suitable solutions?
Please advise.
Post edited by acdum1857 on October 2021
  • PadonePadone Posts: 4,026
    You could pin the clips where you want them, that is, position the clips part of the bra and exclude them from the simulation. Then simulate the rest of the bra. But personally, if fitting the bra is all you need, I'd rather try to shrinkwrap in blender first.
    Post edited by Padone on October 2021
  • acdum1857acdum1857 Posts: 105
    Padone
    Thank you for answer.
    I also posted this on the BA forums and had similar discussions.
    https://blenderartists.org/t/parts-of-objects-fall-off-in-marvelous-designer-simulating/1334280/7
    In conclusion, I prefer to use MD simulation rather than Blender simulation.
    This is because Blender Simulation is fine for normal clothes, but not suitable for close-fitting clothes such as underwear.
    October 2021
    In your case what I'm proposing is shrinkwrap that's not a simulation.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/226/importing-the-daz-smoothing-modifier
    Padone
    I thought I'd explain why I use MD simulation first.
    Daz's auto-fitting is definitely a convenient and great feature, but it's not satisfactory for those who want something more realistic.
    The images below are just some examples.
    This problem occurs with most clothes, and the more the character's body is deformed, the larger the pose, the greater the distortion.
    This is because, as you know, clothes are autofitted along the geometry of the figure.
    In the case of low distortion, I only need to edit or sculpt a little in Blender, but in cases where the distortion is large and occurs in many places, a simulation-like method is more efficient and effective.
    This may sound too finicky, but I'm trying to implement it even if it takes time, as I'm considering a very effective-efficient and at the same time high quality modeling and animation.
    In the long run, it will greatly shorten my work time.
    So, after testing shrink wrap, soft wrap, simulation, soft body, fit control, etc., in many cases, especially for underwear, the MD simulation had the least destruction and the most realistic fit.
    Of course, I used the original clothes from Daz that are not worn on the figures.
    For this reason, the shrink wrap you mentioned seems a bit far from my purpose.
    (If you said something else, I may have misunderstood.)
    It seems that the results of your discussion on the link page are organized into the 'Visibility Section'.
    A while ago, I referenced it to effectively change and manage clothes in Blender.
    (I am always grateful for the work of you and Thomas.)
    2076 x 1131 - 362K
    October 2021
    Yes the daz autofit works following the figure morphs and tends to distort some areas. Unless the outfit provides a custom shape for the figure. I agree in this case some simulation may help to limit the distortions.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
