Show Us Your Bryce Renders! Part 8
1…1718202223…50
  • David BrinnenDavid Brinnen Posts: 3,136
    Fishtales said:
    A lot of nice renders coming on here lately.
    This was an attempt to see if the camera in Bryce could be made to sit half in and half out of the volume water plane. You will probably have seen the pictures where the camera is submersed in water and the picture shows the above and below scene at the same time. After hours of fiddling with it I gave up as it wont :) It comes close but even moving it by 0.0001 up or down either takes it under or above the surface. Not unless Horo or David have already done it and can let us into the secret :)
    Anyway this is as close as I can get it.
    Beneath the Ship
    Yes here is a challenge I have faced in the past when I made this image http://countrytraveleronline.com/wp-content/uploads/2010/07/finders-poster.jpg
    The "trick" is to use a solid terrain instead and position your camera along the edge. You can boolean cut a hole for the terrain and camera combo into an infinite plane and that lets you goto the horizon if you want to. See image 1 for untextured view.
    Image 2 with textures applied and a second transparent cube used as a cutter to remove the back three solid faces of the terrain.
    In the poster image I used the rocks to hide the join between terrain and what lay beyond it. And plants and other details hid any troublesome shadows caused by the cutting.
    850 x 850 - 270K
    850 x 850 - 112K
  • Tim82Tim82 Posts: 859
    @ Fishtales - nice looking scene you have there
    @ David - the dragon scene looks great :)
    @ Horo - that terrain scene looks amazing! :)
  • FishtalesFishtales Posts: 6,233
    Roland4 said:
    This picture looks very very cool.
    Thank you.
    Your work with the jewellery and eggs is excellent.
    David
    The workaround looks good but it doesn't really have the feel or look that the 'real' pictures have. For all that I still ended up with a half decent image in the end.
    its amazing the effect's you can get with just a tiny bit of bump and the default grey material :)
    1194 x 563 - 249K
    A space background and a space ship wouldn't be out of place :)
    @ Fishtales - that's not a bad idea, I will try a few thing's and see what i can come up with :)
    @ Fishtales - is this kind of what you had in mind ? :)
    1194 x 563 - 193K
  • GussNemoGussNemo Posts: 1,855
    @Sandy: That's a wild looking image.
    @Tim Bateman: My thoughts mirror Sandy's. Actually my first thought was of that image being a lunar landscape of some kind. What you've added it right on the money.
    @ Guss - thanks :)
  • mermaid010mermaid010 Posts: 6,292
    Horo - another beautiful render
    David - another cool video, thanks
    Fishtales- interesting effect more like a mirrored abstract
    Tim Bateman - as usual lovely renders especially the space one, I must try the default material with bump, Thanks for the tip :)
    That's it, much more space/planet like :-)
    Fishtales said:
    David
    So is the effect you are looking for optical rather than diagrammatic? I'm not familiar with the "real" pictures so it would help if you could point us at one and I'll maybe understand the question better.
  • HoroHoro Posts: 11,726
    edited November 2014
    @David - thank you. Gems look great and the method applied to the dragon shows it off nicely.
    @Sandy - not the easiest topic to tackle.
    @Tim - thank you. I agree with you, I'm always amazed how good a terrain can look in default grey if it is at a good resolution and the light right.
    @mermaid010 - thank you.
    Post edited by Horo on
    Fishtales said:
    David
    A few here.
    http://www.uwphotographyguide.com/over-under-split-photography
    Loads here, some better than others.
    https://www.google.co.uk/search?newwindow=1&safe=off&client=opera&biw=1261&bih=565&tbm=isch&sa=1&q=over+and+under+water+images&oq=over+and+under+water+images&gs_l=img.3...10345.13023.0.13373.6.6.0.0.0.0.139.784.0j6.6.0....0...1c.1.58.img..6.0.0.i03Zt2iFWKY
    Especially the Crocodile one and the first one on this page.
    http://www.uwphotographyguide.com/laups-2011-international-contest-winners
    The problem with Bryce is that even with the waterline level with the centre of the camera 'lens' it is either above or below the waterline even moving it the slightest amount, +0.0001 or -0.0001, instead of splitting the image top and bottom. One way around it is to render the above image and then the below one and combine them in Photoshop but that is adding an extra process that I thought I would cut out :)
    @Sandy - particularly the first link shows what we often forget: air and water have different refraction indices. Some very good examples.
  • Roland4Roland4 Posts: 0
    Today i try to upload a scene file on sharecg. But it does not work, what i am doing wrong ?
    edit: sorry, i have found the error. I have upload the last scene Faberge Egg. The scene is without lights and colors and only for learning.
    If someone wants to have a scene he has seen once, sent me a PM and i will upload the scene on sharecg.
    Post edited by Roland4 on
    The knack is to balance the aperture and speed to get enough light from the underwater area and not blow out the air side or introduce too much noise :) If Bryce had allowed the lens to be split top and bottom then adding lights to the underwater part would compensate for any loss of light coming from above. With Bryce it would also be possible to set ideal conditions with good light and clear water. Hmm, I've had a thought on that one. Time for more experimenting :)
    Have added some DOF and some murkyness to the water - as well as modifying the refraction of the cutter.
    The blue cube uses the process as explained in the recent video plus a bit of Horo's Garage Closed HDRI for good measure.
    850 x 850 - 222K
    600 x 850 - 140K
    @David - looks quite good, the water thingy. I'm currently working on the other, expect results per email soon.
    An icasohedron and a sphere is all that was needed. Within the tiny icasohedron is an HDRI that casts light and shadow onto the sphere that is a bit transparent and has some reflection. All stars are connected by lines - though I have no idea where the stars come from. The camera is looking through the GWL (gigantic wide angle fisheye lens) and covers about 300 degrees.
    1067 x 800 - 141K
    David
    Re the above/below image. That is brilliant, it looks just as good as the images taken with the cameras.
  • Fencepost52Fencepost52 Posts: 513
    I'm way out of the loop on this thread and don't know if Robin Wood's tutorial regarding above/below water renders has been discussed, and if it has, please accept my apologies. This may be helpful: http://www.robinwood.com/Catalog/Technical/BryceTuts/BryceClasses/IBryce5/IBryceLesson5-5.html Again, if this has already been discussed, please forgive me. I'm more of a troll these days. :(
    Art
    Again a Faberge Egg. It looks a bit older.
    500 x 500 - 139K
    i liked the look so much i had to have a go at this :)
    1194 x 563 - 232K
  • OroborosOroboros Posts: 326
    Nice work, Tim. What are you using for the caustics?
    @ Oroboros - thank's, and i used a square parallel light, and used this image as a gel :)
    800 x 800 - 223K
    i have know idea why! ...but i thought i would share :)
    1194 x 563 - 87K
    Ooh, tile-able too, excellent :)
    I love caustics. Here's an old product image I did for a company launching a new sonar/radar/chart interface. The modelling was all done in SolidWorks (not by me), but as is usually the case, the company needed product images before the product was actually built. So I stuck my hand up and said "Gimme the bits, I'll throw it in Bryce".
    1082 x 909 - 428K
    Post edited by Oroboros on
    @ Oroboros - wow that's not a bad render at all, nicely done :)
