• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Can't find "Daz to Blender" Add on in blender
«12»
  • Rev2019Rev2019 Posts: 180
    April 2021 edited April 2021
    TDBAGZ said:
    7. The plugin is found under View Tab in Blender Shortcut "N"
    again wrong information
    shortcut N doesnt open the plugin
    is everyone here fucking drunk or ;)?
    HOW DO I OPEN THE PLUGIN IN BLENDER?
    Post edited by Rev2019 on April 2021
  • TDBAGZTDBAGZ Posts: 165
    April 2021
    "N" Is for the Menu in Blender to access the bridge to Daz,
    I feel like I need do a fresh install and record a video on this.
    839 x 592 - 145K
  • calvincwestcalvincwest Posts: 3
    May 2021
    Is there a video on this yet?  I've been having issues in blender trying to find the "daz to blender".  The issue I'm having is at the part where you select Edit/Preferences/Add-ons and search "DAZ"......Thats where I'm stuck at and for some reason the word "DAZ" is not showing up in the search bar.  If anyone here has the exact step by step to fix this issue, that will be great.
    May 2021 edited May 2021
    Do you have the community addons enabled? Also make sure you have show "Enabled Only" filter unchecked. If its still not showing then it likely wasnt installed properly or there's a conflict with a newer version of blender and some files might need to be moved around.
    Post edited by TDBAGZ on May 2021
  • MadcowMadcow Posts: 0
    October 2021
    I was having the issue where DAZ unzipped the file and made it useless for Blender.
    Solution, navigate to C:\Users\username\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons There should be a file called "DTB" right click on it and "Send to > Compressed (zipped) folder". A new folder with the same name will appear but with a zipper on it, drag that new zipped DTB file to your desktop. Next open Blender, Edit > Preferences > Add-ons > Install. On the left hand side select Desktop > DTB.zip > Install Add-on.
  • a_foncecaa_fonceca Posts: 0
    November 2021
    You are the man, Madcow! Thank you :)
    This worked perfectly after much searching. Not sure if I was having issues because I choose to use BforArtists2 instead of blender directly.
  • jvedits018jvedits018 Posts: 0
    December 2021
    i cant download the blender addon file on the site :C
  • dave_53fd7d9299dave_53fd7d9299 Posts: 2
    December 2021
    I found the files were put in a blender 2.80 folder rather than the new Blender 3.0 folder... I copied the new folder into my 3.0 Blender folder, Blender saw the files but Im getting an error message of some sort in the belnder add-ons area.
    1330 x 1122 - 168K
  • 5656511856565118 Posts: 0
    December 2021
  • rafed_alwanirafed_alwani Posts: 26
    December 2021
    Still waiting a fix for Daz to Blender to work properly with Blender 3.0
    December 2021
    Im on a Mac 10.15.7   -  Blender 3.0
    1. DaztoBridge installs fine on  DAZ side -
    2. In Blender after hitting Install button and finding my  DTB.zip, the Add On shows up as Armature-DazToBlender , but when checking the Add On box I get an error message:
    bpy.data.window_managers["WinMan"].addon_search = "daz"
    Traceback (most recent call last):
      File "/Applications/Blender.app/Contents/Resources/3.0/scripts/modules/addon_utils.py", line 387, in enable
        mod.register()
      File "/Users/davelebow/Library/Application Support/Blender/3.0/scripts/addons/DTB/__init__.py", line 325, in register
        DtbProperties.update_config()
      File "/Users/davelebow/Library/Application Support/Blender/3.0/scripts/addons/DTB/DtbProperties.py", line 176, in update_config
        config = load_config()
      File "/Users/davelebow/Library/Application Support/Blender/3.0/scripts/addons/DTB/DtbProperties.py", line 163, in load_config
        with open(os.path.join(config, "daz_paths.json"), "r") as f:
    PermissionError: [Errno 1] Operation not permitted: '/Users/davelebow/Documents/DAZ 3D/Bridges/Daz To Blender/Config/daz_paths.json'
    2000 x 836 - 146K
  • marcm3dmarcm3d Posts: 22
    December 2021
    Hi! We need a update to Blender 3.0! only mesh and animation are working. bones and controlers do not. Thanks!
    979 x 812 - 191K
  • kyleburk98kyleburk98 Posts: 0
    January 2022
    Ok guys I have Figured out the "Not being able to find or open the Daz To Blender Add on" in blender.
    So i used daz central installed the Daz to Blender Add on or Daz to Blender Bridge what ever you want to call it. what happened to me was it installed to the wrong location.
    It installed to "C:\Users\PHNX\AppData\Roaming\Blender Foundation\Blender\BLENDER_VERSION\scripts\addons\DTB"
    I copied everything in the DTB folder went back a few folders to "3.0" or the actual version you have installed.
    Navigate to scripts addons CREATE a DTB folder and paste what you copied into that folder.
    open blender go to add on's and the DazToBlender add on should now show up in blender hope this helps.
    Blender Version: 3.0
    Daz Version : 4.16 Pro
  • alietratiKalietratiK Posts: 0
    January 2022
    ARGH THIS IS SUPER FRUSTRATING - CAN THE DEVS DO SOMETHING :)
  • admin_ff9e8ff4a2admin_ff9e8ff4a2 Posts: 0
    January 2022
    Hello,
    Thanks to kyleburk98 because this is the solution that worked for me, files installed in the wrong place... Not cool anyway.
    And now, new problem, the same problem as dave_53fd7d9299 I attach a photo of the errors...
    Thanks to Daz for making sure to fix the problem...
    Blender 3
    Daz Studio 4.16 Pro
  • satomasosatomaso Posts: 0
    January 2022
    Hello,
    I have the same problem, but on a Mac the is no appdate folder....not even in the hidden part of the mac. I cant find the DTB.zip on my computer. Uninstalled it and reinstalled it..same problem! Have also Blender 3 so anny suggestions?
    thanks
  • tbone9914tbone9914 Posts: 2
    February 2022
    February 2022
    Thanks. With 3.0 out I did not think to look in the hidden folders. Plus I was looking for a zip file. Great info!
  • vdininnovdininno Posts: 2
    February 2022
    On a Mac OS, DIM installs file to ~/Library/Application Support/ Blender Foundation/Blender Version ....
    To fix this: Navigate to the DTB folder - Copy it and paste it to the following path ~/Library/Application Support/Blender/3.0/Scripts/addons
  • vijayasimhabrvijayasimhabr Posts: 204
    February 2022
    Right Then
    My solution was to copy the folder "DTB" from the following
    C:\Users\vijay\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons
    to here
    C:\Users\vijay\AppData\Roaming\Blender Foundation\Blender\3.0\Scripts\addons
    Then, heading to addons, and enabling it.
  • brainmuffinbrainmuffin Posts: 1,273
    February 2022
    Usually, but not at the moment. How else am I to deal with my mother-in-law?
  • TsubaTsuba Posts: 78
    February 2022
    This worked, thanks. (BTW you can just copy the DTB folder from one version (in addon\) to another)
  • butaixianranbutaixianran Posts: 161
    February 2022
    Official bridge is not updated for blender 3.0, you need this updated version:
    https://github.com/butaixianran/DazToBlender
    More information check here:
    https://www.daz3d.com/forums/discussion/546316/daz-bridges-update/
  • s4113490s4113490 Posts: 2
    April 2022
    thx that worked for me
  • cgtylercgtyler Posts: 0
    July 2022
    Before attempting any convuluted searches and repacking distros etc etc etc try this if the Blender side is not showing the plugin. Install the plugin from Daz Central. In Daz under File - Send To - Daz To Blender when the dialogue box opens tick on Advanced Settings, you will now see the plugin installer for Blender. Select your version etc etc and you should be good to go.
    506 x 371 - 28K
  • evilkooladeevilkoolade Posts: 114
    January 2023
    i keep installing it and it keeps not showing up i have no blender addon panel even though it is listed and checkmarked in prefrences and for that matter i still don't have a scripts menu in my daz studio i was using a copy of the script i put in my content library but the last upgrad deleted it
    January 2023
    ok something got very currupted i still don't have ascripts menu in daz but i managed to find the install manager zip file and extract it manually. I looked at the python files in the DTB zips and everything is one the titles are all 1's if you open themn its mostly ones its messed up but the on in the DIM zip file worked but DIM couldn't do it
  • arisianaarisiana Posts: 2
    February 2023
    This... This right here solved the problem of the plugin not being available to enable in Blender. If you choose "Custom" as your option it'll just pop open a path chooser at the %appdata%/Blender Foundation/blender/ folder and let you pick your version of Blender to install into.
  • eroguysenseieroguysensei Posts: 52
    December 2023
    You are a life saver. This helped! I have no idea why they have made this so complicated.
«12»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
