• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic DAZ Importer version 1.6.0 released
«1234567…25»
  • ThomasLarssonThomasLarsson Posts: 97
    September 2021
    @N3p3nth3  I haven't used a Mac in this millenium, so I don't know. The main difference is that Mac has a case-sensitive file system. I have used it on Linux running DS under Wine. It used to work but my Linux box died so I cannot confirm that it still does. What the plugin cannot handle is if you have multiple directories which have the same names except for case, like Runtime/Textures and runtime/textures. So you need to merge such directories by hand.
  • N3p3nth3N3p3nth3 Posts: 135
    September 2021
    Allrighty, thanks to you both. I will see what I can do (and obviously I should have read what I did read a lot more carefully, the guy going on for pages about xcode threw me off!).
    As far as I know, my current filesystem is the default for modern Mac OSs, APFS, which is not case sensitive (unless you specifically choose to make it so, at which stage it is no longer default and you deserve all the issues you get), so that particular problem would lie in the past.
    I'll take a look at it this evening and see what happens!
  • florian.schurzflorian.schurz Posts: 8
    September 2021
    So I had much more success with importing an animation, when I set the Character at first to the clean Base Pose.
    Now the animation plays almost perfectly- befor the geometry was completely messed up.
    But, there is one thing still missing :)
    For a breathing animation I used Aniblocks and of course backed them into the timeline.
    They trigger ribcage size and chestwidt.
    But Im having a hard time importing this as morphs/shapekeys into the character. Like especially the pbr ripcage is just not importing. Tried to import as "crate shapekey" and all the other option but nothing happened.
    Any Ideas?
  • PadonePadone Posts: 4,001
    September 2021
    @florian.schurz If you want the daz animations to play fine then yes you need to import the rest pose since the daz animations are relative to the rest pose, same for morphs. As for the ribcage not working, if the animation changes the rest pose (bones start and end points) then it will not work in blender. You may try to animate the ribcage avoiding to scale and move bones, one way is to use shapes.
    September 2021
    @N3p3nth3  Oh, I didn't know that. There is a global setting called Case-Sensitive Paths, which by default is disabled for Windows but enabled otherwise. You should probably turn that off then.
    September 2021
    @padone thank you! Yeah i thought I could make it works as the ribcage-thing works with the d-b -bridge. But yeah in many other ways the bridge sucks unfortunetly
  • Silver DolphinSilver Dolphin Posts: 1,638
    September 2021
    Very nice. Thank you for your hard work. Very generous.
    September 2021
    @florian.schurz If the animation works fine with the daz bridge then it should work with diffeo too. This means it's not changing the rest pose. You may file a bug report providing your specs, a test scene as simple as possible, and the steps to reproduce the issue. I see Thomas is looking here so I guess it's fine both here or at diffeo.
    https://bitbucket.org/Diffeomorphic/import_daz/issues
    As a side note now diffeo supports morphing armatures, thanks to the amazing update by Thomas. But it's anyway advisable to avoid it because of performance issues.
    http://diffeomorphic.blogspot.com/2021/09/morphing-armatures.html
  • surodysurody Posts: 261
    October 2021
    I currently have issues with dev version of 1.6 with the morph rig adjustment feature. It seems to cause a error for many 8.1 characters related to the textures. A base 8.1 female works though.
    It should be easy to replicate. This is supposed to be a bug report but if there's better places to do that let me know.
    October 2021
    @surody As for HD multires this is a known issue. Basically you can't multires a base mesh with triangles that happens for most MD clothing. On the other side it is not needed to export as HD a subd mesh, so the issue doesn't arise if you keep the figure as HD and the clothing as subd.
    Then if this is not your issue please bug report.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/733/bad-hd-mesh
    October 2021
    This issue isn't related to clothing or multires. I get error with a blank 8.1 character with base resolution.
    October 2021
    @surody Please state your specs (daz, blender and plugin versions) and the exact steps to reproduce the issue. Also if needed upload a test scene as simple as possible (duf file).
    October 2021 edited October 2021
    I use the newest Daz Beta, the newest Blender 2.93 + Blender 3.0 versions and the newest 1.6.1 dev version of daz_import. I get the error with both Blender versions. I kept testing a bit more and Victoria 8.1 and Jada 8.1 seem to work but Joanna 8.1 doesn't work.
    Here's the error:
    Python: Traceback (most recent call last):
      File "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons\Diffeomorphic-import_daz-f611d2545732\error.py", line 208, in execute
        self.run(context)
      File "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons\Diffeomorphic-import_daz-f611d2545732\main.py", line 468, in run
        self.easyImport(context, filepath)
      File "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons\Diffeomorphic-import_daz-f611d2545732\main.py", line 477, in easyImport
        bpy.ops.daz.import_daz(
      File "H:\Blender 2.93 (E-Cycles)\2.93\scripts\modules\bpy\ops.py", line 132, in __call__
        ret = _op_call(self.idname_py(), None, kw)
    RuntimeError: Error: Python: Traceback (most recent call last):
        self.run(context)
      File "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons\Diffeomorphic-import_daz-f611d2545732\main.py", line 122, in run
        self.loadDazFile(filepath, context)
      File "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons\Diffeomorphic-import_daz-f611d2545732\main.py", line 206, in loadDazFile
        asset.build(context)
      File "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons\Diffeomorphic-import_daz-f611d2545732\cycles.py", line 81, in build
        self.tree.build()
      File "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons\Diffeomorphic-import_daz-f611d2545732\cycles.py", line 347, in build
        self.buildLayer("")
      File "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons\Diffeomorphic-import_daz-f611d2545732\cycles.py", line 381, in buildLayer
        self.buildDetail(uvname)
      File "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons\Diffeomorphic-import_daz-f611d2545732\cycles.py", line 586, in buildDetail
        self.buildNormalMap(weight, tex, uvname)
      File "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.93\scripts\addons\Diffeomorphic-import_daz-f611d2545732\cycles.py", line 491, in buildNormalMap
        self.links.new(tex.outputs[0], self.normal.inputs["Color"])
    AttributeError: 'NoneType' object has no attribute 'outputs'
    Post edited by surody on October 2021
    October 2021
    .. and the exact steps to reproduce the issue please.
    In Daz load in Joanna 8.1 -> save scene -> "Export to Blender " -> In Blender "Easy Import Daz" -> standard settings -> try to import the character with Daz Importer -> error
    October 2021
    I don't have Joanna, but it looks like she has some detail but no detail normal map. That case shouldn't cause errors anymore.
    October 2021
    @surody Does the fix by Thomas work for you ? I don't get errors here.
    October 2021
    It's fixed now, thanks for your hard work. :)
  • MacislavMacislav Posts: 126
    October 2021
    Is there any simple step by step tutorial on how to import true hd (not just multires) characters with hd morphs into blender. (wih diffeomorphic)
    Whenever I try to import hd characters, there are no weights, just a multires modifier and  the characters are not poseable.
  • Krys KryngleKrys Kryngle Posts: 311
    October 2021
    You can use Xin's add-on to convert to HD Mesh with HD shape keys.
    Turn off multi-res in the general settings of diffeo.
    I'm wondering, is it possible to make the new armature morph feature viable for the MHX or Rigify rigs? I tried it with both, with Rigify it doesn't seem to work at all at the moment but MHX worked mostly besides the feet and hands. Is that a possbility in the future? Would be awesome!
    October 2021
    A better answer Thomas can provide. Personally I don't think it is possible. That is, the "armature morph" featurte refers to ERCs that need the daz rig to work. One would need to "translate" the ERCs for mhx and rigify. I'm actually surprised that it works for mhx with some limits. But, I'm not too much into rigging so I may be wrong.
    It should work fine with the "simple ik" rig though, since it uses the daz rig with just some ik added.
    October 2021
    It indeed does work with the simple IK.
    November 2021 edited November 2021
    Is it currently possible to use the morph armature feature with animations? It seems to work for still images but I can't make it work for queuing up a animation for rendering and there seems to be no way to bake the rig adjustments each frame yet.
    Am I missing something or does it actually not work as of now?
    Post edited by surody on November 2021
    November 2021
    For animations you have to use the script instead of the tool. The tool is for a single frame, the script is for animations. You will have to setup the script by hand as described in the docs.
    https://diffeomorphic.blogspot.com/2021/09/morphing-armatures.html
    Yes I'm using the script but the render engine doesn't seem to memorize/adjust each frame step. It works in the viewport though. I'm using the newest version of Daz Importer Dev version (1.6.1.0673) and tried it with 2.93 and 3.0
    That's odd .. will look at it and let you know what I find. If you can provide a test scene as simple as possible it will help.
    Post edited by Padone on November 2021
     You can't test it with a A or T-pose since the deformation happens mostly on hands and feet when they're out of rest pose.
    November 2021
    No you can't share the blend files it's against the daz eula, also it's not useful anyway. I need the duf file if you like to share something.
«1234567…25»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
