• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Manually Installing an old version of Daz to Blender on MAC
lucashorowitzlucashorowitz Posts: 4
September 2021 in Blender Discussion
Hi all! I am trying to install an older version of Daz to Blender (2.2.2) on my Mac. However, I'm having trouble manually installing the new plugin. Everytime I try to replace it it reverts back to the current update (2.4.0). Has anyone attempted to do this before? Thanks so much for all the help!
  • pretendforreal_707d4f4a31pretendforreal_707d4f4a31 Posts: 47
    September 2021
    Hi!
    Yes. I posted the bellow a few months back and have done it several times. Personally the new bridge is better at bringing over materials and some other fixes but I often find that the older versions have less bugs. Good luck!
    Hi all!
    Sam from the dev team was nice enough to walk me through how to re-install older versions of the DazToBlender bridge. This worked great for me to revert to a previous version and avoid some of the bugs I was excpereincing with 2.3.
    Here are the steps written out:
    Manual Re-Install of DazToBlender Older Versions
    Download older version of DazToBlender from:  github.com/daz3d/DazToBlender/releases
    SCROLL DOWN> NEXT> Locate the previous version you wish to install. Download “Source Code” Zip file.
    BLENDER SIDE MANUAL INSTALL
    UNZIP Source Code folder INSIDE FOLDER> Blender> appdata_common> Blender Foundation> Blender> BLENDER_VERSION> scripts> addons> DTB
    COPY DTB FOLDER
    NAVIGATE/GO TO:
    %appdata% in windows browser
    AppData> Roaming> BlenderFoundation> Blender> select the version of Blender you are using.
    “version”> scripts> addons> DTB
    DELETE existing DTB folder and paste in DTB folder from the downloaded “Source Code” folder.
    BLENDER> ADDONS> check to see if it is available to install, trouble shoot by “Remove” and then repaste the DTB into the above mentioned folder.
    DAZ SIDE FRESH INSTALL (easier than replacing the script)
    GO BACK TO : “Source Code” folder.
    Daz Studio> appdir_common> scripts> support> DAZ> Select all .dsa files (there will be 3 or 4 depending on version)
    GO TO WHERE YOU KEEP YOUR DAZ LIBRARY “My DAZ 3D Library” > Scripts> Paste in ,dsa files, accept “Replace the files in the destination”
    OPEN DAZ STUDIO > Content Library> My DAZ 3D Library> Scripts> Daz To Blender> Right Click> Create Custom Action> Rename as desired (I added the version #)> Accept> OK> it will now appear under scripts tab at top of the window.
    Hope this is helpful. :)
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
