The We Will Miss You, Chohole Complaint Thread
1…3132343637…100
  • carrie58carrie58 Posts: 4,178
    edited September 2021
    PerttiA said:
    Sfariah said:
    carrie58 said:
    @frank0314 ,personally I'd also recommend ,depending on your age , avoiding doorways. I swear the older I get  that every time I go through a door way I forget what ever it was I was gonna do ...... except for the potty ,when I can't remember what I was gonna do I figure it must be go to the bathroom,and it doesn't matter what door way .......
     It is easy to remember when you gotta go.  Your bladder make sure of that!
    Do not forget to check that the seat is down and the lid up
    Since I live alone I only have to worry about that when I've had company ,and it is with great chagrin I admit to not checking  once ......3 am in the dark and that squat becomes a lot lower then your knees allow , and the porcelain is way cold ....... alot of cussing now wide awake ......yup now I turn the light on and double check whether there has been company or not ....
    Post edited by carrie58 on
    frank0314 said:
    PerttiA said:
    Sfariah said:
    carrie58 said:
    @frank0314 ,personally I'd also recommend ,depending on your age , avioding doorways. I swear the older I get  that every time I go through a door way I forget what ever it was I was gonna do ...... except for the potty ,when I can't remember what I was gonna do I figure it must be go to the bathroom,and it doesn't matter what door way .......
    There are 3 guys and one girl in this house and she has us trained good, not to mention we are all scared the crap of her, rofl.
    I'm gonna guess SHE married one of you and gave birth to the other 2 so you should be scared of her ,she keeps you alive and has the power to take you out ,sooooo some healthy fear can be a good thing .It's nice to know some men can be trained (ROFLMAO) Now somebody needs to help me up off the floor.laugh
  • RezcaRezca Posts: 3,393
    Hoffmeyer has three different tyrannos in their store. Only the '3rd generation' one has the nifty saddle prop, but been picking away at it to fit it onto the 2nd tyrann lately little by little.  I like all three of them for different reasons, each has their own appeal. But of course it means painting textures for one can't apply to another haha, have to do it per-dino.  I like that blue'ish one with the yellow head I did, I might try painting a similar one for the 3rd tyranno sometime.
  • LeatherGryphonLeatherGryphon Posts: 12,531
    The doorway thing is a known phenomenon.surprise  Although I forget what it's called.  But yeah, studies have shown that doorways erase thoughts.indecision  The best way to counteract it is to know that you will have to go through a doorway to complete your task so you should be voicing your task as you get ready to go through the doorway to keep it active in your brain.
    Don't worry, it gets worse as you get older.  I forget things I was ready to do on the computer if I start closing windows to get ready to do the thing I was thinking of.  It's the process of changing your environmental context that erases thoughts.  I keep a note pad (yes, a real physical paper notepad and writing impliment) handy to jot down a key word when I have an important thought about a task to be done.indecision
    Think of it like this...  The thought of doing something is initially stored in your brain's  cache memory but unless you refresh that memory quickly and convert it to organized structured action, it will melt away when the environmental context changes.  Getting it back often requires revisiting the environment where you first thought of it and try to find the trigger that made you think of it the first time.  However, it doesn't always work for me, so I've learned to not care until the pot burns on the stove or the bathtub overflows.  At which point I know exactly what it was I forgot.frown
    Think of it like this...  The thought of doing something is initially stored in your brain's  cache memory but unless you refresh that memory quickly and convert it to organized structured action, it will melt away when the environmental context changes.  Getting it back often requires revisiting the environment where you first thought of it.  Doesn't always work for me, so I've learned to not care until the pot burns on the stove or the bathtub overflows.  At which point I know exactly what it was I forgot.frown
    hehehehe , yeah I've learned to not leave the kitchen while cooking and just lately I had to take one of the burner knobs off the stove because even though I only use the front 2 burners ,suddenly I was turning on the back burner instead of the front burner that had the pot sitting on it.Happened twice ,burnt up my burner covers which were stacked on the unused burner the first time ,smelled the hot burner the second time ,and pulled the knob off and stuck it in a drawer. Hopefully I'll remember which one if I actually need that burner . If I had my way I'd have a single great room ,just a bathroom door and a closet door inside the space ,would cut down on memory loss I think ....
  • kyoto kidkyoto kid Posts: 42,472
    ...yeah I have that happen now & then. I go back and wonder why what I put on the stove hasn't cooked yet.
    What makes it tougher we have these so called "smart rings" that are solid, not the conventional coil loops and they don't glow so it's even more easy to turn the wrong one on, particularly if you are dyslexic like I am.
    The stove only has one single light to indicate a surface unit is on but it doesn't indicate which one.  Really bad for as not seeing any glow you could accidentally touch an active ring and burn your finger or hand. Stoves like this need an indicator light by each cook unit to let you know which ones are on. or a display on the panel which indicates which rings are active, or just don't belong in a building where most of the tenants are seniors.
    Already had one of the rings burn out as it is the one in the back which is also over the vent for the oven and being solid, heat doesn't escape as well, but with Covid restrictions we've been under, can't have maintenance  replace it as it isn't considered a "critical" emergency like say, a pipe bursting or dunny totally backed up..
    Post edited by kyoto kid on
  • frank0314frank0314 Posts: 15,115
    The wife will call out all three of our names if the seat is up or if the toilet paper roll is on upside down. It has to unroll from teh top and not the bottom, lol. Yes my wife and 2 adult children, 23 and 20yrs. One graduates college this summer and the youngest graduates college next year after his first semester even though he's 3 years younger.
  • N-RArtsN-RArts Posts: 1,609
    Who knew one little vent could cause so many problems. Having said that, the bit that was overheating, still hasn't cooled down like the rest of the computer (whatever it is, is underneath/beneath the mouse/touchpad). The crack in the casing is getting worse, too.
    Oh boy! That new checkout is going to take a while to get used to.
    Why is it, when I'm trying to do something, I'm constantly being talked at (not to - that doesn't happen in this house).
    Post edited by N-RArts on
  • /Not a Complaint:
    1) Mom-in-Law is still recovering from her infection but is so much better than she was at the beginning of the week.
    2) Got my results from my fasting blood draw.  Despite being overweight, my levels are still where they need to be.  I can now go from every 6 months to once a year for fasting blood draws.
    3) Hardback book went live on the store.  Some of my co-workers have been teasing me about buying the movie rights to the book for X amount or Surface Pro.
    4) It's Friday!
    Hope everyone else is having a wonderful Friday.
  • I don't know about cats, but for dogs one can teach [some] of them to be "kitchen dogs" ... you put some meat on to cook, something they REALLY want. Go sit down in the other room. When the pot starts boiling or whatever and IF the dog starts making a fuss, PRAISE it and immediately cut off a piece of the cooked meat, cool it and give it to the dog. IF the dog does not respond, let the meat burn. Yup. Might want to use cheap meat if it's a slow learner. Before the smoke detectors go off, retrieve the shoe leather from the pan, cool it and give it to the dog. They don't like burnt meat anymore than we do. Concept is NEXT time, they go a little more balistic in trying to get you into the kitchen to "save their meat" :-) Always praise and reward them of course. It becomes a habit and even for food they're not interested in, for the praise and regular dog treat perhaps, they'll still alert to any activity happening on the stove or in the oven. Some are much better as kitchen dogs than others. Best so far was my late Bulldog. He REALLY liked his meat ;-)
    Fyredrygyon said:
    /Not a Complaint:
    4) It's Friday!
    ...good to hear on all counts.
  • McGyverMcGyver Posts: 7,103
    Years ago I left the toilet seat up and my wife "fell in" (her words), and despite all my laughter and heckling, she was not amused... so in an a act of remorse (I was acting remorseful), I haven't left the seat up in probably twenty years or so...
    A couple of days ago I was disposing of assorted expired (toilet safe) liquidy foods in the commode and forgot the seat up... basically because I wasn't finished going through the fridge... so of course one of my daughters runs in there and repeats her mom's mistake and of course my laughter and heckling was NOT appreciated by an new generation... so once again in an act of remorse (I'm still acting remorseful, because it's actually kind of funny) I have vowed to inform everyone if the toilet seat will be up for some reason because apparently looking before you sit is not an option.
    Seriously, you live in a house with me and you don't look before you sit?... like what if I adopted a piranha and was looking for a bowl to keep him in and I needed a temporary spot for him to wait... or far more likely, what if I removed the toilet altogether because I was conducting some experiment that went wrong and I broke the bowl (I actually did that once, but it wasn't my toilet, though it was my dry ice)...
    I know if that happened to me it would be funny, but it's not (supposed to be) funny when it happens to a lady... it is... funny.
    I look before I sit anywhere, on a toilet or a seat of any kind... pants up or down... what's the big deal?...
    Maybe it's because I grew up in NYC and you don't sit without looking or you'll find yourself soaking in someone else's pee... or god knows what... you should see the horrible things I've witnessed festering on subway seats.
    I understand like if you are little and you fall in and a sibling tries to flush you down the toilet, that could be traumatic... it's a little funny, but it's still probably traumatic... I'm actually laughing because that happened to a friend and her younger sister did try to flush her and when she tells the story I always snicker because of how maniacal she was as a kid and how it was really poetic justice... She's always like "That's so mean..." but god forbid I tell my story about being in a bus accident on the way to camp and how I was the only one they left behind on the wreaked bus, she thinks that's hilarious.... I mean come on... toilet fail versus upside down bus in the woods... I dunno...  l do kinda tell it in a funny way... but still.
    I should probably stop talking about this before someone thinks I'm unsympathetic or something and I have act all remorseful again.
    ...now the cat falling in once while strutting around on the rim was amusing. Fortunately the dunny had been flushed earlier and it was clean water. Never saw him move so fast for such a big cat.
  • TJohnTJohn Posts: 11,448
    Just lurking and playing with my new computer.
    Now a pre-Caturday thing...
    @TJohn ummm no picture shows....
    It's a video. Some films won't show in all countries [yet].
    Here's a pinterest one of a cat [somehow I feel my dog sagas get ignored amongst all these cat people so I carefully picked this, looks reminiscent of a mime in a box].
    ...nothing like goofy kitty vids.
    Now it's there fun giggles
  • edited September 2021
    Bandit the puppy meets a member of the CCC (The Committee of Cantankerous Cats).
    Just a funny idea that all cats are part of a committee once they survive kittenhood.
    Post edited by donahue_shelly9250229 on
  • XyetztXyetzt Posts: 27,576
    I don't have a roommate yet, but maybe soon.  I was wondering if I should tell her that I have fish or keep it a secret?  Wait how would I keep my fish a secret when their filter isn't quite quiet.
    Now have three sets of custom textures for Hoffmeyer's  T-Rex 2!  :D  It's been a lot of fun painting, even a bit relaxing.
    1920 x 1080 - 222K
    1920 x 1080 - 237K
    1920 x 1080 - 223K
    Post edited by Rezca on
    Ooooo.... Nice!
  • I ordered my new computer.  It should arrive next week on Friday or Saturday maybe.  Now I need to buy an HDMI cable.
    What did you end up getting?
    oh were you asking me?
    4032 x 3024 - 5M
    TJohn said:
    Ooooo.... Nice!
    Thanks!  Maybe at some point I could share some of these~  Got to find a place to do so and a way to do it.  Just the textures? Or would someone here who knows how to D|S/Poser make a MAT file for it? etc
    I need to do a paint for the v3  dino too though as well.
    No, was wonder about starionwolf new computer
    I so badly want to ask the staff to get the mail since she won't let me get it.  I'm expecting a package for an outfit for my doll.  I'll show it on her as soon as I get it and on her.
    reason I'm not asking is because she doesn't like to be bothered about mail.
    Tough crap. I guess she should allow everyone to get their own mail. When she doesn't it becomes her job to do it regaardless of the time of day.
     The issue might be afraid someone might steal another's mail?
