No one asked me - Diomede screenshots on whatever - Warning AI Discussion OK
1353638404150
  • DiomedeDiomede Posts: 15,398
    edited September 2021
    Load the texture maps to the custom leaf grid.
    Save the custom grid leaf to the custom leaf browser folder.
    1281 x 631 - 136K
    1887 x 1051 - 269K
    Post edited by Diomede on
    Tree - Time to add the leaf to a tree.
    Start a new medium scene.
    Insert the default tree.
    Go to leaf tab.
    Select the default leaf.
    Click remove.  The branch should have no leaves in the preview.
    Click Add - the custom folder should be included in the menu, in my case Dio Leaves.
    Choose the saved leaf grid and accept the option for including the shader.
    Default Tree with Custom Leaf - Test render
    1890 x 984 - 185K
    1410 x 892 - 121K
    1660 x 973 - 171K
    640 x 480 - 19K
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,297
    you can use Philemo's cutouts to make leaves and plants of course too
    some great resources here https://www.heritagetype.com/pages/free-vintage-illustrations
    and here is one of my photos of a foxglove
    1068 x 1726 - 3M
    OBJs for Export
    Save the tree to the custom plant preset folder.
    Start a new scene.  Load the custom plant from the preset folder.
    Use the Assemble Room Edit Menu to convert to another modeler, in this case vertex model.
    Enter the vertex modeler and select all.
    Untriangulate the model.
    Return to Assemble room and duplicate.
    Choose the first and enter the vertex modeler.  Do not edit the master; instead, choose create a new master.
    Select the by shading domain, choose the leaves, and delete.
    Export the trunk/branches as an obj and use the Daz Studio preset
    In assemble room, select the duplicated plant.  Enter the vertex modeler.  Create a new master.
    Select the leaves.  INVERT to select the trunk and branches.  Delete.
    Export the leaves as an OBJ using the Daz Stduio preset.
    jj01 make sure display is set to tree and the box for full detail mesh is checked.jpg
    1845 x 996 - 213K
    1826 x 1027 - 245K
    1823 x 977 - 331K
    1815 x 997 - 309K
    1680 x 970 - 360K
    1420 x 868 - 175K
    1622 x 916 - 315K
    Test if Trunk and Leaves Fit Together in Daz Studio and if Leaves Texture Maps Correct
    Start new Studio scene
    Inport the trunk obj and use Carrara preset
    Repeat for leaves obj
    In surfaces tab, apply the IRAY uber shader to each obj
    In surfaces tab, load the diffuse map in the leaf color channel
    In the surfaces tab, load the alpha mask in the cutout opacity channel
    In the main room confirm that the alphas of the leaves appear to be working.
    Test render of leaves
    NOTE - There is a standard Daz Studio Content system for folders.  The texture maps would have to go to a runtime / textures folder.
    1602 x 950 - 185K
    1685 x 998 - 207K
    1178 x 846 - 140K
    1087 x 951 - 171K
    1329 x 937 - 186K
    1600 x 2400 - 1M
    Editing the Trunk and Branches in ZBrush, 3D Coat, or similar
    The fully textured leaf canopy 'fits' the trunk and branches.  The trunk and branches can be sent to a sculpting program to make additional edits, especially creating normal maps oor displacement maps for the bark.  Speaking of bark, bark can be painted on using Substance Painter or similar.
    1308 x 790 - 155K
    Reserved for ZBrush or 3DCoat
    Reserved for Substance Painter or similar
    Reserved for Final Folder Structure and Test Loading in Daz Studio and Poser
    Headwax said:
    Wow wow and wow! Thanks for all this. A veritable wiki on trees :)
    as an aside, have you tried replicating trees on the branch tips of another tree?
    from memory you add a new shader on the tips of the mother tree branches and replicate on that shader
    That is a good idea.  I have tried replicatin branches on a tree I tried to model in the vertex modeler but not on one converted from the plant modeler.  Thanks for the suggestion.  Worth some more experimentation.
    Thank you very much for the resources.  Excellent.  Will experiment some more.
  • HeadwaxHeadwax Posts: 10,435
    look forward to the results , wasnt my idea, many years ago someone was developing the idea as a commercial product for carrarar , never saw the light if day i think, and the user dissappeared . He used to do nice car renders , worked commercially with 3d too i think, had a sleek user name that i cant recall !
    Here is a proof-of-concept for using a surface replicator with a Carrara plant modeler tree.
    - I inserted a hybrid tree that I've used for other stuff and removed all the leaves, bark is a gray-ish color.
    - I added a sphere colored red.
    - I added a surface replicator and applied the sphere to the whole tree.  Seems to work as expected.
    - I then limited the surface replicator to only the 'branch2' domain.
    - The spheres replicated only on the outer branches.
    My initital thought is that replacing leaves with branches, etc, and applying to either the outer branches, branch 1 or trunk, is a viable option.
    hh01 scene with plant no leaves and a sphere and empty surface replicator.png
    1873 x 990 - 875K
    1903 x 977 - 304K
    640 x 480 - 37K
    1901 x 1010 - 316K
    640 x 480 - 37K
    very nice work Diomede
    edited October 2021
    Dug this old model out of my pile of models.  It is mostly spline objects.  It was made for a monthly challenge.  Trying to break through some minor lack of creativity.  This robot needs a project.
    800 x 600 - 28K
    Diomede said:
    gee you must be old, that guy looks like Bruce Dern -
    nice Bot too.
    I used to do illustration Friday for inspiration - seek and yeah shall find
    Not sure if this is it?
    I used to be chomping at the bit to find out what the week's topic was. Then there was Monday Art day I think...
    Welcome to Illustration Friday - The Art of Education University
    Some more leaf experiments.  Here is an idea to have two leaves per Carrara leaf, each at different angles so at least one shows up in any camera angle.  Hope you can see the uvmap in the pic with the mesh.  I can't share this leaf because I got these particular oak leaves from the web for proof of concept.  If I get OK results with this approach then I will share when I use some reference leaves I took myself.
    1892 x 892 - 348K
    810 x 753 - 22K
    1011 x 772 - 174K
    And here is a comparison of applying my custom dual leaf (oak leaf) to the Carrara content included oak leaf.
    800 x 600 - 54K
    800 x 600 - 43K
  • Bunyip02Bunyip02 Posts: 9,278
    Looking good !!!
  • mschackmschack Posts: 337
    Nice solution!  Always wished they implemented random leaf angles...
    edited October 2021
    Halloween season.  Decided to model a carved pumpkin.  Started with a sphere and used booleans, which I usually try to avoid.  Then relied on trangulate > N and the smoothing subdivide to get back to quads.  In hindsight, I did not have enough vertical sides for the pumpkin but I think the expression turned out OK.  The shaders are all procedural.
    1200 x 900 - 81K
    edited October 2021
    And the cap fits.
    1200 x 900 - 86K
    Souper cheeky
    get it laugh
  • StezzaStezza Posts: 8,819
    edited October 2021
    that is one cool pumpkin... yes
    my eldest granddaughter loves pumpkin soup...
    how did you cut the top off?
    Post edited by Stezza on
    Thanks, Wendy and Stezza.  For the booleans, i used the front orthoganal camera and drew on the back drawing plane.  I drew the shape I wanted to cutout using the polyline tool.  I extruded the polyline to get a mesh for the boolean tool instead of trying to mess with the cut tool.  To make the cap fit, I saved a copy after I extruded the polyline but before I applied the boolean.  I then did the boolean twice, once for the main pumpkin and once for the cap.
    nice work and thanks for the detailed explication :)
    edited December 2021
    Here is what I am currently working on.  A castaway island.  Am having some hiccups along the way.  For example, Carrara freezing up.
    1600 x 900 - 133K
