• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Are there Horizontal and Verticle tiles in the Material Editor for Blender
tam_c3df5332fctam_c3df5332fc Posts: 122
September 2021 in Blender Discussion
Hey guys,
I am able to use Horizontal and Verticle tiles with Daz> Surfaces to keep an image from repeating - see attached file
When I send this file to Blender, it begins to repeat the image - see attached file
As a result, I went into the Material Editor and changed the settings from Repeat to Extend - see attached files
Then I begin to render, but now, the texture is not visible - see attached file
I can only assume that it is there, but I need to set some type of Horizontal and Verticle tiles to be able to view the texture.
Where is that setting in Blender?
Thanks in advance
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,254
    September 2021
    It looks like you probably just need to uv unwrap the bass drum.
  • margravemargrave Posts: 1,822
    September 2021
    You can either unwrap the UVs, as TheMysteryIsThePoint said, or you can go into the Shader Editor and add both a Texture Coordinate & Mapping node. The Scale option on the mapping node is functionally identical to the Horizontal/Vertical Tiles option in the Uber shader.
    https://docs.blender.org/manual/en/2.93/render/shader_nodes/vector/mapping.html
  • tam_c3df5332fctam_c3df5332fc Posts: 122
    September 2021 edited September 2021
    Thanks for replying @TheMysteryIsThePoint,
    Nothing is showing up in the UV Mapper - see attached screen shot. All indications are that this should be working
    Edit: I was able to see the image in the UV Mapper by selecting it from the list of images at the top, but it is still not showing up in the rendered mode - see attached screenshot
    1892 x 925 - 520K
    1291 x 753 - 559K
    Post edited by tam_c3df5332fc on September 2021
    OK, I figured it out.
    1) Go into Object mode and select the item that you want to apply the texture
    2) After selection, switch to the Edit mode
    3) Go to the Select menu and choose All
    4) Go to the UV menu and choose Unwrap
    see attached screenshot for the result
    Now the images are not aligned correctly, but if someone could tell me how to correct that, then this will be working to my satisfaction
    Edit: I was able to select the object and rotate/move them into their correct positions/rotations - see attached screenshot.
    Just in case anyone else has a hard to moving/rotating objects, as if they were cemmented into their positions/rotations, then go into the Tool menu (right hand side drawer menu), under Options - unselect Origins and Locations - see the previously mentioned screenshot
    Seriously thank you for the feedback and letting me bounce ideas until I was able to understand
    1462 x 997 - 1M
    1441 x 929 - 1M
    September 2021
    @tam_c3df5332fc
    Glad you figured it out.
  • PadonePadone Posts: 4,023
    September 2021
    @tam I suppose you're using the daz bridge here. As for diffeo it automatically converts textures tiles to blender.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
