Rendering with Solid Green Background
I am trying to create a project where I create several action scenes using various dog models and I need to export with a solid green background so I can integrate those scenes with live action videos in video software using chroma key filtering.  My trouble is trying to figure out how to create a solid background and color it green.  Can anyone point me to a tutorial that would assist in this endeavor, or help me directly?    I am desperate at this point and do not want to spend any more $$$$ in models and poses.  Thank you!
  • FishtalesFishtales Posts: 6,246
    Go up to the main menu and under Window/Panes(Tab)/Environment which will open the Environment Pane. At the top click on Type/None and choose Backdrop and change Backdrop to green.
  • margravemargrave Posts: 1,822
    First, don't do this.
    Any images you render without a background will have an alpha channel, which is absolutely, positively 1000% more efficient than chromakeying.
    Second, if you really, really want to do this--which, again, I do not recommend--you can set the backplate color in Window -> Panes -> Environment.
    To add to this, be sure to render to PNG or TIFF format, not JPG or BMP, otherwise you lose the alpha.
    OP, you could also use Canvases(Render Settings>Advanced>Canvases) to create any of the layers you might need.
  • Thanks, Just tried the rendering with alpha and it works fine with editor.  Green Screen does not work well
  • marblemarble Posts: 7,500
    Glad you asked and that I read this thread because I have been rendering to green screen (using the environment background as described above) and editing in Davinci Resolve. Next time I will try it with the alpha backround bcause the green screen usually leaves some kind of halo effect.
