August 2021 - Daz 3D New User Challenge - Open Render Challenge
2
  • Aki3dAki3d Posts: 200
    edited December 2021
    Post edited by Aki3d on
  • Version B of my second idea.
    I'd noticed some light sources to make use of in the room that my character is entering so I made use of them.
    1280 x 720 - 1M
  • StargazeyStargazey Posts: 284
    "A Steampunk Traffic Jam". My entry in the Intermediate Challange.
    Although I've been using DS for a while now, I've only recently started experimenting with Iray.  This is my biggest / most complicated scene yet! Postwork done in Affinity Photo.
    1133 x 907 - 1M
  • ItsCeoItsCeo Posts: 471
    I love this! The scene is interesting with many things for me to like. I like the red tones on the machines and the little wisps of smog is perfect! Great job!
    Although I've been using DS for a while now, I've only recently started experimenting with Iray.  This is my biggest / most complicated scene yet! Postwork done in Affinity Photo.Love the smopk
     Very cool. Love the smoke.
  • OriginalSamhainOriginalSamhain Posts: 38
    edited August 2021
    Can I change my entry? I did this using tutorials from the instancing challenge and a lot of creative lighting, it just feels a bit more suitable for this challenge than my other one.
    Title: Awakening
    Challenge: Intermediate
    1200 x 800 - 1M
    Post edited by OriginalSamhain on
  • 2nd entry for Intermediate. Came up with two slightly different versions, one with and without a glow around the angel - would like to hear which one people think looks better! Other feedback, also appreciated.
    Title: Gentle Interference
    Caption: Once we find ourselves on a dark path, sometimes it takes a gentle hand to guide us back.
    2000 x 1714 - 5M
    2000 x 1714 - 5M
  • Hi everyone. In this one I experimented with using multiple figures, posing and lighting. Quite a challenge for me, especially because it pushes my rendering capabilities to the max. Suggestions and comments are always welcome.
    Title: In the moment, at Twilight Park
    Entry: Beginner
    small amount of postwork in Gimp
    1015 x 881 - 881K
  • sueyasueya Posts: 862
    This is the first version of my image for the Intermediate Challenge. I have changed the textures of the Ballroom to make it look more like a Church. I am wondering whether to add Depth of field. I would welcome any other constructive feedback
    edited August 2021
    With a more realistic lighting the render would look much better.
    Is this a poser render?
    First of all turn of this IBL or put its value very low. The IBL is "waching" out the whole image.
    turn on the ambient occlusion. Without AO every Render in Poser or 3dl looks flat without any life.
    Adjust the shadows. They are much to bright. If you've done all this, the picture will look for shure much better.
    The next thing will be the atmosphere. This render would be perfect for light wich comes through the window.
    You could use a self luminating shader for the window and the global illumination for the room.
    It will increase the render time but it is worth every minute.
    @aki3d There are two lights in the scene with the option of ambient occlusion - do I use shadows?
    I am using 3Delight.
  • TynkereTynkere Posts: 834
    edited August 2021
    Used to work commercial art at an ad agency.  An editor would’ve labeled this project “NF” -- meaning, ‘No Future.’  (Design is flawed-- don’t waste time with it, come up with something else.)  I had fun with mirrors reflecting mirrors though. ; )
    Change Log:
    Added black jacket to girl.  Photoshop showed jacket too black & clipping.  Remove image map & adjust surface too see folds in fabric.  Tweak face/neck pose.  Tweak feet.  Add noise to white trim on shoes.  They were clipping too.
    Mrs. Chow -- use different wig.  Adjust skin surface (she looked orange.)  Adjust teeth surface.  Tweak face/neck pose. Tweak feet/big toe.
    RY Stephen -- adjust surface settings for less glossy skin. Tweak face/neck.  Tweak feet/toes
    Fix vertical tile & offset on custom sign.
    Title: “Stay Healthy”
    Contest: intermediate - open
    Apps: DS 4.12 | PS-CS-3
    I enjoyed reading through the topic and seeing everyones renders.   Best wishes yes
    1947 x 1460 - 4M
    Post edited by Tynkere on
    There has to be a light with shadows turned off!
    Look inside of the trumpet, why is there light inside the instrument? It makes no sense.
    Turn on raytraced shadow in every light.
    For the global illumination GI and the ambient occlusion AO you will need the uberenvironment2 from omnifreaker, which comes with Daz under light presets.
    There is also something wrong with the shaders of the instruments. It doesn't look like metal.
    Perhaps you have used an iray shader in 3dl.
    edited August 2021
    You've been around a long time.  I admire your work.  It has a soft gentle quality.  I hope that makes sense.  Probably not because it's late!  0_o
    Anyway, I hope the following isn't seen as disruptive or disrespectful.  I'm here to learn just like the rest of us!
    So I was curious and did a quick 3Delight render.  Ubersurface2 -- G8M default mats.  For the trumpet I used an old Lumina preset.  I like AoA spots.  Using 2 of them.  One for actor and another for across the room to bring out reflections.
    Good job on composition, lights, and the background.  Preset or recipe for brass instruments and the scene will be jammin'  yes
    Best!
    1080 x 810 - 2M
    I have added some depth of field and ambient occlusion to my image. I hope I have improved the depth in my image.
    I have only just seen the comments by Tynkere and @aki3d so I will see if there is anything else to be done by following their advice.
    Any other constructive feedback is welcome.
    Much better now.
    I would work on the shader. Give some reflection to the glas of the window, to the brass of the instruments, to the skin and to the hair. The best depth effect you get, when you have something in the front, something in the center and something in the background. These three layers should be looking different from each other with the help of brightness, color, DOF.
    A much darker wall behind them would be a good contrast with the bright windows and would help to seperate the musicians from the Background. Something blurry (because of DOF) in front of the camera (candles, heads of the audience etc.) would help to give more depth. If you put a spot light behind/ above the musicians you can create a rim light on the shoulder and head. This is also a way of seperating the center from the background. One of the most important things in photography are reflections in the eyes.
    Giving the eyes a reflective surface and positioning a point light in that way, that a reflection can be seen in the eyes is sometimes a little bit of work, but the result worth it.
    More lights with lower intensity (to not wash out the shadows) giving more interesting reflections. You can also lit a plane behind the camera with a spotlight to get a bigger bright object which can be seen in reflections but doesn't make the scene brighter.
    The color of the lights are also very important. A little bit of bright orange gives a much warmer light, than the standard white, which looks very often like a cool neon light.
    I hope it helps.
    Tynkere Is that Lumina preset still available anywhere? I'm having difficulty finding a metal that looks good in 3Delight.
  • aprilshowers2065aprilshowers2065 Posts: 835
    edited August 2021
    2nd version, adjusted the tone mapping slightly so the items on the desk are a little clearer.
    2000 x 1714 - 5M
    Post edited by aprilshowers2065 on
    I have managed to implement some of the suggestions from other forum members
    Please feel free to give me more constructive feedback even though I am not sure I will have time to act on it
    edited August 2021
    Lumina Materials Library skew number is 30801.  I couldn’t find it via internet search either.  Had to log into my account.
    Good news is Wowie also has a product called Awe Shading Kit.  He put that one up at Rendo as a free download.  Unzip manually, or zip compatible with the DIM.
    Anyway, “Awe Shading Kit” has presets for metal & other common surfaces + utilities.  Works with HD Saxophone and HD Trumpet.
    Looking forward to seeing what your render looks like if you decide to get the metal to reflect more.  You have a unique style.  Be interested to see what you do with the music instruments and her microphone.  smiley
    This will have to be my final version of my image.
    I have changed the floor texture and managed to get some reflection on it.
    I did try using the Awe shader kit with some success on the instruments
    edited August 2021
    Third and probably final version; adjusted the lighting slightly, as well as the girl's hair.
    1200 x 1800 - 4M
  • Alias52Alias52 Posts: 326
    edited August 2021
    Apocalypse Soon.
    Intermediate.
    https://gcdn.daz3d.com/gallery/image/1168630/1630456064/main.jpg
    So, my computer died this month. Had to get a new power supply in it and managed to sneak in some extra RAM and a slightly better GPU. Would have liked more time to work on this. Loved the Steampunk traffic render!
    Post edited by Alias52 on
  • ann0314ann0314 Posts: 2,909
    This challenge is now closed. Thank you to everyone who participated heart
    August 2021
    Showcased Participants for the August Beginner Open Render Challenge
    calesdroid
    aki3d
    isis4444merlin
    Showcased Participants for the August Intermediate Open Render Challenge
    Tynkere
    aprilshowers2065
    OriginalSamhain
  • Very nice everyone. Some cool stuff in there.
    I hope my reply makes sense.  I'm a bit under the weather.  Where I live, a desert wind will blow in about once a year.  It turns everyone into drugged zombies on decongestants.  0_o
    So Congrats to winners!  Everyone who participated.  Being 'featured' is very humbling.  Thank you very much.  : )
  • Thank you so much!
  • Oh thank you! Congrats to all of the other winners; very nice renders everyone!
    Great work folks!
