maybe a newbie question... where are the Actor dialers?
LeleLele Posts: 0
Hi,
just installed DazStudio 4.6.3.52 on Mac (OSX 10.9.4) via the Daz Install Manager. Installed the program and the Genesis Starter Kit
Everything works fine but: when I double click on Genesis figure I can't find, in the Posing>Editor tab, the ACTOR section... [see attachement]
Let's say I want to have a Genesis with 70%male, 25% Basic Child and 5% Basic female... how can I do this without those dials? All the pose dials (for example Head>Expressions) seems to work fine...Obviously I am missing something, but what?
Thank in advance for teh help
MD
  • PlatnumkPlatnumk Posts: 682
    Make sure the Genesis Figure is selected in the Scene Tab, Then you need to goto the Shaping Tab (if you ca't see the Shaping Tab then goto the 'Window' menu then 'Panes(Tabs)' and select 'Shaping' you should then see all of the actor diallers.
    PS. you may need to change the settings on each dialler by clicking on the little 'Cog' and select 'Parameter Settings' and putting a check mark into the box that says 'As Percent" next to the 'Default' setting
    See included screenshots
    Hope this is of some help
    462 x 253 - 48K
    582 x 221 - 54K
    594 x 514 - 112K
  • Richard HaseltineRichard Haseltine Posts: 111,758
    edited October 2014
    The Posing pane is for poses, not shapes. The expressions appear because they are in a sense poses, dynamic movements of the face rather than changes to the base shape.
  • LeleLele Posts: 0
    Thanksx PlatnumK and Richard Haseltine, I must be blind!!! It came out that what I was looking for was the Parameters tab...
    Thank you so much!!
