• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
The Shader Mixer Deciphered (Blender to Daz Conversion)
«123»
  • margravemargrave Posts: 1,822
    July 2021
    j cade said:
    There are a lot of BDSF nodes. They have an output labled "BF". Now the final output you need has an input "MT" so you have to figure out how to transform that BF output to the MT imput. As far as I can tell, you have to first convert it to an "ST" I think there is one node in aaaalll of the nodes that can do this? and its not labled "hey, If you want to be able to ever use a BDSF node ever you will need this" or put anywhere I will ever remember. You then take that ST output and there are 2 nodes to choose from that take those and output an MT.
    In canse anyone is wondering the node names I used to go from BF to MT were "Material Surface" and "Material Structs". "Material Structs"is under materials which makes sense. I don't remember where "Material Surface" is and dont feel like spending 5 minutse going through every category to find it.
    I got that part down already, and wrote about it earlier in the thread so I don't forget it, lol. Notice how I always put the full path to the node.
    I totally agree about the search option.
    July 2021 edited July 2021
    I didn't manage to replicate your setup yet, but I was playing around with the nodes in Functions -> MDL -> Material Editors alongside the Add Thin Film node, and I found out how to mix materials together. "Weighting" seems to be Daz's equivalent of Blender's "factor", the float/black and white map that determines which areas of a surface should be masked. By feeding two materials into the "Add Weighted Layer" node, I was able to successfully (?) mix them. This should be excellent for adding grunge.
    1920 x 945 - 434K
    Post edited by margrave on July 2021
  • j cadej cade Posts: 2,310
    July 2021
    Whoops you totally did. Tbf just thinking about the shader mixer makes my brain melt a bit. So reading about in it's dripping out my ears as my eyes glaze over
    You're correct about weighted mix and the mix node. I wish there were an add shader in iray, but afaik, iray takes the same philosophy as luxrender with regards to breaking physics. While I mostly agree in principal, my iray white whale is still objects with proper refraction that don't cast harsh shadows. If anyone figures that out I'll give them my nonexistent firstborn.
    Also I'd love to be able to combine 3 values into a color. While one can just use a color with values greater than 1, multiple inputs can be a bit more user friendly. I feel like it should be possible, but I haven't the foggiest how.
    Due to the paucity of Daz Shader Mixer tutorials, I decided to check out one for Substance Designer (Basics of creating an MDL in Substance Designer - YouTube). Since they both implement MDL, there's a lot of overlap in the two node systems.
    Here's a quick shader to blend between materials based on the fresnel value (i.e. the glare of sunlight striking a surface at an angle).
    In reality you'd use an IOR of 1.4 or something, but I jacked it up to 3.0 to make it more noticable.
    In Blender, you would just feed the fresnel value into a Mix Shader (which is an "Add Weighted Shader" in MDL terms), but it seems like MDL really leans on this "layering" workflow where materials are laid atop each other. They're mainly found in Functions -> MDL -> Material Editors. You can add dust layers, thin film layers, etc, and it seems like each one has its own specialized layering node instead of one multipurpose blending node like Blender.
    1920 x 942 - 388K
    July 2021
    You mean like Blender's Separate/Combine RGB nodes?
    July 2021
    Yep. In blender I like to set up my fake dispersion with IOR and spread inputs: You have your base IOR value and the Spread value gets added and subtracted from it in the red and blue chanels. You can do the same thing with with a color input but I find it less intuitive, and DS isn't all that good at handling color values that go above 1. on the other hand using IOR and spread doesn't allow the values to be asymetrical, which doesn't matter in blender as the entire set up in blender is much hackier (and vry liable to completely break physics)
    I did find an RGB combine equivalent in DS afer searching built ins>types>color>color 3 inputs
    1893 x 795 - 701K
    and some more renders of my experiments with chromatic IOR
    The blue one also has some volume, but the red one all the color is coming from the IOR
    I also didnt save anything for the first one and then crashed DS, so I need to add volume back in. But on tthe recreation I added a duplicate microfacet refraction shader - mostly so I can control the strength of the reflection slightly seperately from the refraction
    600 x 780 - 108K
    800 x 1040 - 458K
    2188 x 1207 - 537K
    Post edited by j cade on July 2021
    July 2021
    and another with volume added back.
    ... I really hope Cycles X makes Chromatic IOR possible in blender, because this is way too cool
    800 x 1040 - 457K
    July 2021
    I have no idea what kind of sorcery you're doing, but it looks great.
    July 2021
    Here's a render I did using the Thick Translucency block as a volume scatter node. I wish Daz had a smoke sim, so I could add some texture to it, but I still think it looks pretty good.
    It's entitled "In Search of Documentation: The Daz Experience".
  • TirickTirick Posts: 235
    July 2021
    With this method does the camera still need to be outside the volume?
    July 2021
    No. You can have the camera inside the volume and it will still work.
    One caveat: if you make the volume larger than a default primitive cube, you will have to fiddle with the "Volume Reference Distance" as well as the "Volume Scattering". If it's too large, it'll be pitch black inside no matter what. "Reference Distance" seems to be a scalar that goes up as the scale of your cube goes up.
    July 2021
    Oh awesome! I should add Reference Distance then as a user parameter.
    July 2021
    Here's the doc page: 2.1.9 - Thick translucent (nvidia.com)
    You need to set the IOR to 1.0, which will make light rays pass through it without refraction. That's why the cube seems like it doesn't have any walls. Other than that, I haven't had a chance to look too deep into this node, specifically.
    I put together a simple shader using your guidelines. I added user parameters for color and volume distance. I might tweak it for the other settings. I'm quite curious how bump can effect it.
    This is seriously a game changer for my renders. I've strugged to with Godrays using other methods and this just... works. The fact that it is a true volume and not just a surface scatter makes all the difference.
    Thank you for sharing this process!
    717 x 682 - 608K
    Post edited by Tirick on July 2021
    July 2021
    oh and since this is a thread sort of related to blender, the main node I've been using "Microfacet Gcx BSDF" does have a blender equivalent - In various blender shader nodes (Glossy, Glass, etc) there is a dropdown for various distributions. The default on most is GCX. Multiscatter GCX is the blender equivalent of "Microfacet Gcx BSDF"
    Multiscatter/Microfacet has much better conservation of energy when you add roughness, In both Cycles and Iray with the default glass/glossy, as you add roughness to the the default GCX shader it starts to darken whereas GCX Multiscatter/microfacet maintains its brightness.
    Now Iray is organized very differently so the disribution type is the node and you can select the equivalent of glossy, glass from a drop down in the node.
    So Iray Microfacet and then you select scatter only = cycles glossy Multiscatter
    Iray Microfacet Transmitt only = Cycles refraction multiscatter
    Iray Microfacet Scatter and Transmit = Cycles Glass multiscatter
    all of this is in pretty wordy and meaningless, way more practically the fixing of energy conservation with a bit of roughness means I can use refraction with thick walled on and not cast weird shadows
    I can use proper refractions on the eyes (its quite slow but it does eventually clear up and work)
    The Microfacet GCX shader is my new best friend
    700 x 910 - 132K
    700 x 910 - 461K
  • Mustakettu85Mustakettu85 Posts: 2,933
    July 2021
    What about all the noise blocks, turbulence, voronoi etc, haven't they been re-written in MDL?
    The "old" way of circumventing this is to multiply the "colour" by a scalar.
    July 2021
    They are all implemented in MDL, yes, but I don't think a shading language is capable of an actual fluid simulation. That would probably need to be implemented in Daz.
    I remember experimenting with the GGX, Schlick-Blinn, etc. in Blender and seeing absolutely no difference, lol.
    Oh I fogot to mention A) very good render
    and B) Iray 2021 has support for heterogenous volumes (something that would be needed for smoke sims and at the very least adding some texture to a volume) note Iray 2021 is not yet in DS but will at some point soon I'm sure
    I'm pretty sure at that point we'll be able to figure out how to add some 3d noise to the volume
    edit currently it is impossible to do this in iray:
    but theoretically it should be possible when the version of iray gets updated
    1840 x 846 - 517K
    July 2021
    Unless you want directional smoke, you don't really need a fluid sim, just a turbulence pattern in the colour and/or opacity inputs of your fog. It's an old trick; check out an ancient PRMan example render here -
    http://www.smartcg.com/tech/cg/courses/RMan/notes/Class02/Class02.html
    - or a much more recent Redshift tutorial here:
    And if you actually want a fluid sim, there's Fluidos, it generates meshes you could beautifully fill with your fog.
    July 2021
    Volumetric clouds and smoke would be really sweet.
    July 2021
    Even a very basic 2D sort of opacity masking could add some interesting visual detail.
    The funniest thing about Fluidos is that it uses OpenVDB internally... so it could give us amazing smoke sim results out of the box, without remeshing etc. But I'm not sure if Iray or Filament can handle OpenVDB natively - yet - and while 3Delight standalone has been able to for quite a while, its OpenVDB lib doesn't really work with the version built into DS because of certain tech limitations. So Fluidos has to use all those workarounds.
    July 2021
    Tirick said:
     Not currently, plug in opacity and the volume will disapear entirely
    Iray reading openVDB support is likewise a part of iray 2021, whether that gets integrated ino DS still remains to be answered but until then its not even theoretically possible
    July 2021
    Daaaamn :( How unfortunate.
    July 2021
    yeah. the only thing you can do is model complex shapes - there are some products in the store that do that for explosions and they doo look pretty good but proper heterogenous volumes will make stuff so much easier
    Let There Be Light
    It took me a while to figure this one out. The biggest stumbling block is that, for some odd reason, this does not work with Material - Fields. Even though they should be functionally identical, you must use Material - Structs to create a mesh light. I don't know if that's a bug or what.
    As it stands, the light needs an extremely high value in the "Intensity" socket. This one has about 10,000,000,000. I think there's a way to use the Luminance Units as a scalar, but I haven't found it yet. Looking at the emissive files from vMaterials, they seem to be determining emissive brightness based on calculations with Blackbody nodes and things like that. Haven't got my head around that part yet.
    Speaking of MDL, I located the MDL files implementing the Uber shader and the PBR Skin shader. They're in your main Daz installation folder, under shaders/iray/daz_3d. Be warned, they're big boys.
    1920 x 944 - 763K
    July 2021
    Aaaaaalright, I'm stubborn and an old cheater :) Found out it's possible to connect a noise generator to the transmission colour output (the volume colour won't even take! smart design move on the DAZ part), so that then when you render the cube from the outside, you get this "overlay". It's basically equivalent to doing this in postwork, but it saves the hassle of saving out a render, opening gimp, yadda yadda.
    1000 x 1000 - 1M
    And now emissive surfaces don't work at all, even though I have literally the exact same setup as last time?
    I seriously think emissives are bugged. I can't even load emissive shaders from vMaterials into a Custom MDL node.
    EDIT:
    Thanks to this post, Scene Only lights not working properly (SOLVED) - Daz 3D Forums, I discovered the culpit. My Draw Settings had defaulted to "Interactive (Biased)". While I did change it briefly yesterday, I definitely changed it back. So I'm not sure why Daz decided to use that as its new default, but...whatever. Emissives are working again.
    This time, I squared the intensity with a Multiply node, and now the lights are much easier to wrangle.
    1920 x 942 - 99K
    1920 x 939 - 700K
  • charlescharles Posts: 866
    Mesh smoke but I haven't tried playing with the shader mixer yet but could be used to improve it a lot I think. This is an interesting thread.
    1080 x 1440 - 2M
    1080 x 1440 - 913K
    Post edited by charles on July 2021
  • mcorrmcorr Posts: 1,104
    July 2021
    margrave said:
    Godrays.
    Tonemapper's set to a Shutter Speed of 1, an f-Stop of 8, and an ISO of 800. Render Settings are set to "Scene Only", with a single yellowish Distant Light outside at 200,000 lumens. The fog shader was applied to a single primitive cube scaled up so it envelops the entire attic room.
    I'd love to know how/where you found the bricks (inputs) diagramed above (went through all the resources,but found nothing) ... could you maybe attach a file so we can play with this?
«123»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
