Missing morph from OBJ file
UpiriumUpirium Posts: 730
I comissioned a face morph from someone made in Blender, and I saw previews of it being used in DAZ but I can't seem to get it to work.
I tried both genesis 8 and 8.1 male. it says it was loaded successfully but i can't see the morph anywhere. i tried genesis 2 since i have it making sur eit wasn't accidentally made for genesis 2 and got an error so i'm guessing it was made for 8. i try searching the name of it in morphs and it doesn't show up. i try readding the morph and it tells me the morph already exists.
what am i doing wrong?
  • margravemargrave Posts: 1,822
    Open the Property Hierarchy pane, select the figure that says the morph was successfully applied to, and filter your search results by the morph's name. You should be able to find it. The author might've flagged it hidden by mistake or something.
  • UpiriumUpirium Posts: 730
     i found it, it wasn't showing up under the name for some reason but i found it in paremeters/morph loader
