I can't figure out the coloring on Time Honored Entrance
Hi,
I'm not sure if I'm in the right place. I just picked up Time Honored Entrance and I can't figure out how to change colors. I want the blue stone to be stone-colored, but I can't figure out how it got to be blue in the first place. It doesn't appear to be in the jpeg in the diffuse color or in any of the channels. How did Andrey Pestryakov do it?
Thanks for your help.
  • Richard HaseltineRichard Haseltine Posts: 111,800
    Is it glossy and picking up a sky colour?
  • barbultbarbult Posts: 27,620
    Maybe there is a blue map in the diffuse overlay color. Or maybe there is a geometry shell with the blue overlay. Or maybe LIE was used.
  • GordigGordig Posts: 10,818
    edited June 2021
    I've been poking around on this, and I tried removing every single base color map from everything that isn't a plant, but I still get this:
    I'm showing hidden objects in the scene view, and hidden nodes in the surface pane, but I still don't see what's responsible. This suggests to me that the custom shader he used for a lot of the objects has map slots that are somehow completely invisible to the user.
    1200 x 900 - 2M
    Post edited by Gordig on
    edited June 2021
    Here's the same scene with the Uber base applied to those same surfaces, so yeah, it's definitely some dark magic going on with the custom shader.
    1200 x 900 - 2M
    edited June 2021
    Messing around in the Shader Mixer for the first time, I figured out how to edit those colors, giving me the following:
    If you're feeling adventurous, the L5 blocks at the top of the window are responsible for those color changes, at least on the arch. I haven't touched the rocks yet, but I imagine the layout would be pretty similar. As I said, I've never done anything in Shader Mixer before, so I don't know how to make those parameters editable in the Surface pane.
    1200 x 900 - 2M
  • Oh, wow, you've really been working hard. I know next to nothing about Shader Mixer. Looks like this is my chance to learn all about it. Thank you so much.
  • It took a while to find the color control I wanted on the rocks, but here it is with stone-colored stone. Thanks for the help.
    1087 x 614 - 608K
  • jimmyzpopjimmyzpop Posts: 118
    Nice, work on the color change. It looks good.
  • abiflashabiflash Posts: 108
    Maybe you want to share how you have achieved it.
  • Sure. I followed Gordig's suggestion. I clicked on the surface I wanted to change with the surface selection tool. Then I went to the shader mixer tab and clicked on File>Import from scene>Material. Then I slid the zoom slider to 100% so I could see what I was doing and went looking for L5 (Thanks to Gordig who found that for me). Under L5-1 and L5-2 (at the top and toward the right of the Shader Mixer) there are image ID dropdowns under Inputs that have the colors. I changed those from blues to browns and now I have stone-colored stone.
