• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
How do I make solid object morphs in Blender?
lukon100lukon100 Posts: 849
June 2021 in Blender Discussion
Suppose I want o make a simple Daz Studio morph that twists a cube, such as the default cube of Blender.
How can I do this?
I see lots of tutorials on the internet for making morphs for Daz human figures in Blender. But that process does not work on solid objects.
Can someone point me to that super rare tutorial for making Daz morphs for a simple solid object in Blender?
  • 3WC3WC Posts: 1,145
    June 2021
    Why does the process not work on solid objects? If anything it should be easier, you don't have any bone adjustments to worry about.
  • lukon100lukon100 Posts: 849
    June 2021
    I have no idea why it does not work.
    I use Morph Loader Pro to create the morph. Then when I move the morph slider control, it makes the entire object shrink or grow, rather than applying the shape change.
  • RL_MediaRL_Media Posts: 339
    June 2021 edited June 2021
    When that happens to me, it's usually because I forgot to set the proper scale(same scale as import) in the morph loader import window. You gotta click on show individual settings, then the scale box will show.
    Post edited by RL_Media on June 2021
    June 2021
    Right on. Yes, that was the problem. I got my scales inconsistent.
    But now it seems that a morph is not likely the solution I need regardless. My real goal here might better be met using a kind of rigging instead.
    I just don't know enough about rigging to select the right settings to do it.
    I posted my real goal and question as to how I can achieve it on the Daz Forum here:
    https://www.daz3d.com/forums/discussion/503326/how-can-i-rig-this-footbridge
  • MarcosGMarcosG Posts: 0
    June 2021
    What is a Morph?
  • Enchanted AprilEnchanted April Posts: 217
    June 2021
    @MarcosG A morph is a different shape of the original (base) prop or figure. It has exact the same count of vertices but these are "pushed" to another place in 3d space. For example: every character is a morph of the Genesis Base figure. Victoria 8 is a morph of the G8F Base. Every slider in the Shaping tab uses morphs for dialing in different values of the morph.
    You can make your own morphs of anything: save the thing in base resolution as an .obj and bring it into the modeling software you like, there you can change the shape, but don't change the count of vertices, save again as .obj and bring it back to Daz via Morph Loader Pro. This action will create a new slider for the thing and you can dial in the shape you created in the other software... there are lots of tutorials.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
