• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz to Blender Beta: How To Download Release Versions, Manually Install, and Replace Old Installs
Razzle-Dazzle3DRazzle-Dazzle3D Posts: 32
May 2021 edited May 2021 in Blender Discussion
We're excited to be rolling out a beta version for the next release of the Daz to Blender bridge - featuring updates to rigging and morphs, Genesis and Genesis 2 figure support, general bug fixes, and more!
Since this bridge beta must be installed manually; we've created instructions outlining the processes to download the latest (or a previous) release of this bridge, the process to manually install this bridge via the RunOnce folder, as well as the steps to replace previous versions of this bridge installed via DIM or Daz Central.
To download the beta version of the Daz to Blender bridge, please follow this Github link:
https://github.com/daz3d/DazToBlender/releases/tag/2.3.5-beta
To access any version of the Daz to Blender bridge or to reference additional documentation, please follow this Github link:
https://github.com/daz3d/DazToBlender/tree/develop
How to Download a New Release from GitHub:
  1. Go to the link listed above to find the newest release on GitHub
  2. Under Assets you will find the newest build. It will be named DazToBlender_VersionNumber
  3. Download the zip and Inside you will find the Contents needed to use the bridge. Follow the steps below on how to install the bridge
Installing via RunOnce Folder:
Please follow these steps to manually install the Daz to Blender bridge:
  1. Open a new File Explorer window and enter "%AppData%" (without the quotes) at the top of the window
  2. Navigate within this Roaming folder to  --> DAZ 3D --> Studio4 → RunOnce
  3. Now, within the Daz to Blender release folder, locate the Daz to Blender ASCII scripts located within the Daz Studio sub-folders (under ...\Daz Studio\appdir_common\scripts\support\DAZ)
  4. Drag and drop these scripts to the RunOnce folder and close out of this window
  5. Then, navigate to your install location for Blender -- by default this location is  "C:\Program Files\Blender Foundation\2.92"
  6. Navigate to your plugins folder (if you don't have one, just create one at the root) and locate Blender
    1. ​For example. "C:\Program Files\Blender Foundation\2.92"
  7. Drag and drop the "DTB" folder from within the Develop branch (under ...\Blender\appdata_common\Blender Foundation\Blender\BLENDER_VERSION\scripts\addons\) and place this folder in your Blender plugins folder
  8. Launch Daz Studio and Blender, and the plugin should run normally​
Replacing Version from Daz Install Manager/Daz Central:
  1. Go to your install location of Daz Studio. By Default that location will be
(WIN) C:\Program Files\DAZ 3D\DAZStudio4
  1. Go to the location of the Original Installation which will be: \scripts\support\DAZ\
  2. Inside of the Build Downloaded you will find the needed files under \Daz Studio\
  3. Replace the old versions with the contents here
Post edited by Razzle-Dazzle3D on May 2021
  • PadonePadone Posts: 3,998
    daz studio 4.15.0.2, blender 2.92.0
    As for 2.3.5 beta I get the following error if I try to import a G8F with toulouse hair and basic wear. Test scene included g8f-basic.duf.
    steps:
    1. in daz studio load the test scene g8f-basic.duf
    2. export the G8 figure with arms and legs jcms
    3. import in blender
    818 x 314 - 69K
    352 x 214 - 27K
    duf
    duf
    g8f-basic.duf
    146K
    Post edited by Padone on May 2021
    @Razzle-Dazzle3D @DAZ_sam @DAZ_vish So did you fix it ?
    p.s. I see that names with spaces or other special characters don't get referenced with @, as razzle dazzle above. Is there a way to get it work or are such names just not allowed ?
    May 2021 edited June 2021
    update. 2.3.6 beta works fine thank you guys for the fix. I do like the new ik controls. Going to test the other features ..
    Post edited by Padone on June 2021
    update. As for 2.3.6 beta something odd happens if I try to use the ik controls on a G2 figure. But may be the IK controls are supposed to work only with G8. The FK controls work fine with G2.
    steps:
    1. export a G2 figure with the default options
    2. import in blender
    3. activate and use the ik controls
    506 x 172 - 28K
    update. 2.3.6 beta. As for jcms I see they spread everywhere. That's not good especially for HD figures. Below an example where I exported the arm jcms for G8F and they are exported in the toulouse hair too. I removed the prefix with the new utility to better show the names.
    steps:
    1. export a G8 figure with some garments and hair, include some jcms
    516 x 204 - 36K
  • DAZ_samDAZ_sam Posts: 170
    May 2021
    @Padone Thanks for you great notes like always. I will have @DAZ_Vish look into it as soon as he can.
    I implemented a way to optimize the morphs in the cinema 4d bridge will its not perfect I will see if we can get it implemented before the next release.
    Yeah thats really weird effect from the IK Controls we still haven't had a chance to refactor the basic control rig setup and only basic fixes on Rigify it be easier to know how to fix it once the code is has been fixed. I will take a note of it for a future update.
    June 2021 edited June 2021
    update. @DAZ_Sam As for 2.3.6 general release the issues above are not fixed. Also @DAZ_Bryce reports a 2.3.7 that doesn't exist in the repository, may be he intended 2.3.6.
    https://www.daz3d.com/forums/discussion/498796/updates-daz-to-blender
    June 2021
    Thank you for the catch! That was a mistake by us actually. 2.3.7 has been added to Daz Release as well which has added support to 2.93 as well.
    Also wasn't able to get the morph fixes into the release in time but, add a beta release 2.3.8 with some morph optimizations and fixes.
    Currently the morph sliders do not work as they should as they do not take into account the parent sliders. For example Eye Blink and Eye Blink Left are both applied the driver is recieving 2, still need to work on that so they take into account the other drivers.
    @DAZ_sam As for pruning jcms 2.3.8 beta is much better, at least it excludes jcms by bone. But you can do better. That is, you can check if the bone gets any influence in the weight map, and if not the jcm for the bone is to be pruned. Below an example with the toulouse hair where only the neck and head bones get influence, so jcms for collars and shoulders don't make sense.
    As a side note I'd advise to run "remove morph prefix" by default, since morph names are relative to the object anyway, so the prefix is not needed and it just makes the name hard to read in the panel.
    Please let me know if something is not clear, or if there's anything I'm missing.
    544 x 155 - 27K
    Both great ideas! Thanks for the ideas. I will give it a shot.
    Edit:
    https://github.com/daz3d/DazToBlender/releases/tag/2.3.9-beta
    @Padone should work as you expected. Assuming I understood you correctly. Thanks again!
    Post edited by DAZ_sam on June 2021
    @DAZ_sam As for jcms 2.3.9 beta seems to work fine in general. But there's a glitch with the toulouse hair since I get collar jcms there. When I check with the weight map editor in daz studio I don't see any influence from the collar bones so I don't get it. You may want to check this please.
    Also the bug with the ik controls is to be fixed. This also affects the G8M figure, not only G2 as reported above. Below it's G8M with ik on the legs.
    463 x 138 - 21K
    345 x 167 - 20K
    2.3.9 seems the same as the beta, that is, doesn't seem to fix the issues above
  • 17720284631772028463 Posts: 0
    July 2021
    I am also in this situation(⇀‸↼‶)
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
