• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
G8Figures UV Baking Question...
Write IdeaWrite Idea Posts: 434
June 2021 in Blender Discussion
Really not sure if this is a DAZ3D or Blender question...
In a nutshell, I'm trying to create a normal map with a G8 figure, however, most of the UV maps are outside of the UV box (not really a technical term).
1) Do I need to do a different way of exporting the figure from DAZ-to-Blender?
2) Or Is there a way to center the needed UV map to the image box?
Below are attached images of what I'm referring to.  Thank you in advance!
  • Krys KryngleKrys Kryngle Posts: 311
    June 2021
    I'm thinking you want to watch some tutorials on UDIM's.  That is the term for splitting out multiple maps on one object.  I know you can move the maps by changing the x value in the UV editor, but that is about all I know.  I tried watching videos on UDIM's but they are so intensely boring I can't finish them.
  • Write IdeaWrite Idea Posts: 434
    June 2021
    Thank you very much!
  • SpaciousSpacious Posts: 481
    June 2021 edited June 2021
    You should not need to, nor really want to, move stuff around on the UDIM/UV for the genesis figures.  The parts are all arranged well, and on multiple UDIM tiles, to start with.
    This is the video that helped me figure it out back when everyone still said blender can't do it.  He goes really fast, so it helps to slow down the playback speed.
    https://www.blendernation.com/2019/12/18/blender-2-82-new-udim-texture-painting-features/
    Like with many tasks in Blender, getting everything set up for the specific purpose is the hard part.  I guess that's the main drawback with software that can do pretty much anything.  I advise saving a blender file after you get the whole thing figured out, because then you can just keep reusing that file over and over again for every set of surfaces you create.
    Post edited by Spacious on June 2021
  • nono Posts: 43
    July 2021 edited July 2021
    I think it should be pointed out that you don't have to work with UDIMs. Frankly Blender's UDIM workflow is not that great at the moment* - it's a bit of a pain to set up. The point of UDIMs is to have a single material for all texture sets, but you may not need or even want that.
    So to answer your question 2) yes you can pretty easily move the UVs so they are all within the 0..1 range.
    The UVs for each texture set (UDIM tiles) are spaced in whole number increments. So to move the torso UVs for example, you'd want to select all of the torso faces in the UV editor and type G then X then -1. For the legs you'd select those faces and type G X -2, and so on.
    PS when you export from Daz to some file formats like OBJ or FBX, there is the option "collapse UV tiles" which will do this automatically. But the Daz to Blender addon does not have this option - maybe they should add it.
    *edit: actually blender doesn't even support baking to UDIM tiles yet so you can't even use them for your purposes
    Post edited by no on July 2021
  • PadonePadone Posts: 4,001
    July 2021
    The point of udim is not to have a single material, but a single texture set. That's two different things. Then if materials are based on pbr painting as substance painter does, it may happen that texture sets and materials are related, but this is not the case with daz figures.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
