What went wrong?
Trying to make add a taxi symbo lto the side of the car, edited the image in gimp and added it but look what happened to it
  • FSMCDesignsFSMCDesigns Posts: 10,118
    The car isn't properly UVMapped which distorts the texture. You have 3 choices to try, one would be to export the car OBJ into a modeling program and change the UVMapping. two would be to use a different car that is properly UVMapped. You could also try to add an iray decal to the car,  something I have never tried and not sure if the lack of a proper UVMap would affect that.
  • oconnordavid16oconnordavid16 Posts: 136
    found this
    tried it but Blender goes not responding when I hit ok  :(
    So which prius from the sketchup warehouse is this and I'll look at it.
  • HylasHylas Posts: 2,780
    This should work, worth looking into!
    got it from deviantart but cannot seem to find it now unfortuantly so not sure what sketchup it is :(
    I tried to follow a tutorial for that on youtube and couldn't get it :(
    Sorry, the image you posted shows it listed as 2018 prius sketchup which means it is a sketchup model made in sketchup. Most of those models are usually posted here https://3dwarehouse.sketchup.com/
    could be this one but not fully certain https://3dwarehouse.sketchup.com/model/u155ed5e9-8fa7-490c-872e-c1a1e966fc84/toyota-prius so no way to add a taxi decal so
    I just checked out that model and it has no UVmapping, so no way to add any textures to it without UVMapping it first.
    Ah I see, what would be the easiest way to UVmap it?
    edited June 14
    there is no 'easy' way, just depends on the software and your learning level. blender can do it, along with hexagon (both free), pretty much any modeling app. I used ultimate unwrap 3D to do a quick box map on that sketchup model, then added some iray shaders and slapped on a logo. It's far from perfect, but it gives you an idea
    google UVMapping and you should have plenty of options
    1522 x 849 - 1017K
    Post edited by FSMCDesigns on
    will do thanks smiley
    tried to follow this guide https://all3dp.com/2/blender-uv-mapping-simply-explained/ ;
    this is the result sad
    2560 x 1440 - 2M
  • jestmartjestmart Posts: 4,260
    I don't what happened to move the verts but to UV map it well you need to create seams to segments the mesh into sections that can flatten well.
    Oh, how would I do that?
